is there a brand of smd ceramic capacitor use in iphones? or they are generics
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
I don't see any other visible damage anywhere else on the board....3 Photos-
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by Sparklingxwhat is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
09-12-2024, 01:04 AM -
- Loading...
