Fake Rubycons?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Fake Rubycons?
    I pulled these from my Foxconn board as I was seeing ridiculous ripple. After pulling them I find that their ESR was off the scale.
    As I didn't have any spares I ended up jury rig soldered capacitors that were too big for the allotted space, unfortunately it didn't solve the problem despite their horrid ESR.
    But this is most strange, are these fake? Surprised they went basically OC. Then again the area around these caps did get quite warm... plus probably 14 years old ...
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Fake Rubycons?
    They look real to me. Classic K vent. Correct bottom bung.
    --- begin sig file ---
    --- end sig file ---
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Re: Fake Rubycons?
      They are probably genuine.
      Rubycon MBZ does not like heat, well better said none of the high aqueous ultra low ESR models do.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Re: Fake Rubycons?
        Ah okay, thanks. Assuming they are 105°C caps I'd think they could survive some heat. The stricken board has a lot of bad caps on them and I've been trying to find and replace the clearly bad caps and these stuck out. As replacing them didn't change the outcome (they were over 5Ω ESR), I'm at a loss what these capacitors were actually doing...
        There are a bunch of other caps that have also burst but as I don't have spares on hand I had to make the decision to replace the ones who aren't filtering properly first (by 'scope).
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Fake Rubycons?
          14 years = 122,640 hours.
          Datasheet says
          https://cdn.badcaps-static.com/pdfs/...a384835b7e.pdf
          2000 hours for 105C.
          Or
          2000 hours at 105C
          4000 hours at 95C
          8000 hours at 85C
          16,000 hours at 75C
          32,000 hours at 65C
          64,000 hours at 55C
          128,000 hours at 45C
          MBZ might have lasted its lifetime depending on temperature of the motherboard.
            Great Sage é½Šå¤©å¤§č–
            • 31013
            Re: Fake Rubycons?
            looking at the state of the print, i'd say they got pretty warm.
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              Re: Fake Rubycons?
              They look genuine to me as well.
              Board may have ran very hot if you have a lot of them bulging. Either that or the board sat too long on the shelf and the electrolyte at through the foil layer (on that note, 6.3V and 10V electrolytics tend to be more susceptible to that than their 16V siblings.) Or as retiredcaps suggested, maybe they reached the end of their service life.
              As for the motherboard still not working... nVidia chipset??
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                Re: Fake Rubycons?
                If the whole board is full of swollen capacitors it could have come out of a poorly ventilated and/or cooled case, or maybe certain FETs or coils on the board, neighboring said capacitors, dissipated too much heat over a prolonged period of time.
                “The electrolyte ate through the foil layer”... well, I guess certain series whose foils are smaller (though also carefully etched to increased the surface area) and oxide layers are thinner so as to obtain larger capacitance and voltage values in smaller case sizes (miniaturization) may be more susceptible to this problem. But good series and brands should use ultra pure foil and proprietary oxidizers, depolarizers, and corrosion inhibitors in the electrolyte to eliminate a number of issues regarding long term storage, suppress any excessive hydrogen gas, and rein in the aggressive tendencies of the H2O based electrolyte. Rubycon’s main plant, in particular, borders upon a spring of incredible purity, which should go a long way to control the pH balance in the electrolyte. To my knowledge, long term storage for non-aqueous capacitors is only an issue in terms of foil deterioration rather than volatile electrolyte.
                Of course, all those precautions don’t completely negate the possibility of failure even in the best case scenario (although they may significantly minimize it), and after enough time I guess even those aforementioned additives lose their effectiveness. But in this case I’d guess all the caps died from excessive heat.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  Re: Fake Rubycons?
                  Look genuine to me. They just wore out.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Re: Fake Rubycons?
                    Actually it's a intel chipset graphics board, no dedicated GPU.
                    The board is a mishmash of different brands, these caps I don't know what it's connected to but they were close to the PLL. The chipset filter caps are a different set of caps that are also in bad shape but the waveform was not as bad as these. The CPU VRM caps have also burst, but probing with a scope they still look functional unlike these.
                    There are still a bunch that haven't burst, the only ones that have burst are the CPU (make a wild guess at brand... yep Nippon Chemi con KZG IIRC) and northbridge/chipset graphics chip VRM capacitors that burst (These...I believe were OST), and then these Rubycons. There are also some more caps on the CPU VRM but I don't recall what brand they were at the moment...
                    The OSTs were just simply dead just like these Rubycons. But the KZGs appear to still be doing their job despite popping. Probably not for long, but I wonder what I should do with this motherboard overall, I botched removing an OST and have jumper wires...
                    As for making the machine working again I decided to remove half of the memory - one pair of the 1G DIMMs - and the machine started working a lot better than before. Then I stuck in a pair of 512M DIMMs back, the machine appears to still be working and stable once more, unlike with just the Rubycon capacitor swap. Maybe it was just bad RAM even though the waveform at the capacitor is better than before?
                    Anyway the OSTs I had swapped earlier and those were very needed.
                    I really need to stock more caps but this is my own computer, not someone else's computer I need to fix...
                    • kevin!
                      recapping PCB.
                      • Jul 2013
                      • 195
                      • EspaƱa
                      Re: Fake Rubycons?
                      I think they are genuine. I recently replaced a faulty Foxconn motherboard with VRM capacitors leaking, and they are also rubycon, but not MBZ, they are MFZ series.
                      Gaming pc:
                      nVidia RTX 3080 TI, Corsair RM750I.
                      Workshop PC:
                      Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                      Server:
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Re: Fake Rubycons?
                        I'm starting to think the "F" in the series letters, stands for Foxconn.
                        Like the MFZs in post-version-1x XBoxes, IIRC.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        "”Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mí mismo
                          • 31013
                          Re: Fake Rubycons?
                          i thought the MF stood for Mother-Fucker given how small they are!
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Re: Fake Rubycons?
                            lol!
                            Arc A770 16 GB
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Re: Fake Rubycons?
                              The Foxconn board has been the most troublesome board, but at least it seems always to be caps, caps, caps... unlike the other stricken board I have -- a Gigabyte -- and I still have no clue what's wrong with it (it has all solid electrolyte caps, at least it says so...)
                              Should put the solid caps on the Foxconn, or at least get a whole set of solid caps for it... Just that it needs too many for a mostly worthless board (socket 775, microatx, DDR2, chipset graphics)
                                master hoarder
                                • May 2008
                                • 12170
                                • Bulgaria
                                Re: Fake Rubycons?
                                MFZ is supposedly a very closely-related series to MCZ in terms of specs, if not equivalent.
                                They are really good caps, but don't do too well with heat, like most other ultra-low ESR aqueous electrolytics. The ones that failed there under the CPU heatsink don't surprise me at all. Despite being right in the flow of air from the heatsink, a lot of times they heat up a lot from the VRM. And the small case means they probably aren't rated for many hours endurance. So I'd say that's also a board designer mistake there (or was it? perhaps the manufacturer intended for them to fail after all.)
                                Either way, on socket 775 board like that with small caps under the heatsink, I always use polymers.
                                Well, with so many bad caps, I'm surprised it even started or tried to work. I usually don't even power on motherboards when I see them bad like that. Doesn't matter if you scope the outputs for ripple - bad caps are bad caps. Get rid of them and then it should work. (Unless of course the board uses an nVidia chipset - then all bets are off for any reliability.)
                                Eh, I wouldn't say s775 is worthless. With a low-end C2Q like the Q8200, Q8300, or Q9400, which can be had for pretty cheap, it will still make a great browser PC. 4 GB of RAM minimum if you intend to run a lot of tabs. Otherwise if less than 4 GB, Win7 32-bit will still get you good mileage even today. And with 8 GB of RAM and a decent older mid-range GPU like GTX 460 or 560 or Radeon HD6850, it will play most AAA titles from up to 2015 decently (like GTA V and Dirt Rally, for example.)
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Re: Fake Rubycons?
                                  I'm still using the Foxconn board as a PVR with an E6700 and it's down to 3GB RAM. I wonder if getting a Qxxxx is worth it if I can't get 4GB to run in it anymore (Linux 64-bit rustc/gcc/llvm is probably the most cpu hungry app I run and they eat lots of RAM...may have to downgrade to 32-bit).
                                  The Gigabyte board currently has a S775 preshott in it...
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    Re: Fake Rubycons?
                                    I've seen a few of those in the past. I replaced them with 560uF 4v polymers.... Low profile enough to clear heatsinks (same size as the originals). Never had one come back on me.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • kevin!
                                      recapping PCB.
                                      • Jul 2013
                                      • 195
                                      • EspaƱa
                                      Re: Fake Rubycons?
                                      Thanks for the advice I will keep that in mind for the future, because the size of these capacitors is rare.
                                      This motherboard is full of badcaps, all the capacitors have to be replaced. It has all the samyoung NXC capacitors in bad condition, as well as various teapo, and lelon .
                                      If I think the same, these MFC if they did not get to be in stress conditions, they would have had a longer useful life.
                                      That if the board has worked 44,000h (according to the SMART of the HDD).
                                      The board was recently cleaned, I suspect that this computer has been working with the heatsink covered for a long time, the computer came from a carpentry, and since there is a lot of dust in suspension, it must have been working with hardly any refrigeration and the capacitors have been damaged by heat.
                                      I do not know the history of the computer, but the motherboard is clean and this indicates that the client had problems with the computer, and it was probably cleaned by a technician, but the computer was still not working properly due to badcaps.
                                      The MBZ are also very problematic with the heat, but if they are well refrigerated they will not present problems, I even have a 2001 MSi board with Rubycon MBZ in the VRM and they are perfectly fine.
                                      I have never seen the Rubycon MFZ series, the ones that I have seen are MBZ, surely they are custom MBZ for OEM.
                                      Gaming pc:
                                      Workshop PC:
                                      Server:
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        • Bulgaria
                                        Re: Fake Rubycons?
                                        The ones TC suggested will indeed work.
                                        I have a number of 2.5V 820 uF Sanyo SEPC, Nichicon LF, Lelon OCRZ, and other similar polymers from Xbox 360 console motherboard and dead GPUs, so I use those instead. Same height as the 4V, 560 uF polymers, but higher capacity.
                                        Yes, MBZ and MCZ are fine, as long as they are cooled well *and* used. I find that a lot of my old-stock ultra-low ESR caps tend to discharge and even reverse-charge in storage rather quickly (less than two years) if not used. So if you have old equipment with those caps, it's a good idea to power it up once in a while and use it.
                                        Like I mentioned, MFZ is a custom-order series closely related to MCZ and *not* MBZ.
                                        MCZ and MFZ are the lowest-ESR aqueous electrolytic caps you can get (or could get... they are no longer being made) from Rubycon. Only Nichicon HZ is slightly better and pretty much the "king" of ultra-low ESR caps. Like MCZ and MFZ, they also don't do well with heat, but generally seem to be a little more stable, so long as they have a manufacturing date code after year 2005 (so anything from 2006 and onwards is good... i.e. H06xx and newer.)
                                        • paparazzo79
                                          Fake magsafe 2 charger
                                          by paparazzo79
                                          Hi guys.I bought Macbook Pro mid 2014 15 inch model which did not came with charger.
                                          I got new charger but judging by the specs seems it is fake one.Sadly I live in Bosnia and genuine charger is rare to find.
                                          what to do?Should I use the fake one?
                                          Will it damage the macbook?...
                                          10-02-2024, 08:18 AM
                                        • Galraedia
                                          Fake Caps in Xbox 360
                                          by Galraedia
                                          I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
                                          02-04-2023, 09:55 PM
                                        • eliemgh
                                          t470 have fake charging
                                          by eliemgh
                                          i have t470 have fake charging...
                                          09-14-2024, 06:11 AM
                                        • thesame
                                          Lenovo TB-X605F fake charging after charging connector replacement.
                                          by thesame
                                          Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
                                          04-03-2024, 03:14 AM
                                        • Olkus
                                          Elna capacitors - fake?
                                          by Olkus
                                          I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                                          09-01-2023, 02:45 AM
