Vintage 70's victrola
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    customer of mine is thinking of buying it. Says it's been sitting in basement for years (arkansas, cool, damp). He says "it tries to turn on"
    so i'm thinking capacitors. I think we have one guy who is a master of these things? Any advise?
    interior pics supposedly coming
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Vintage 70's victrola
    been unplugged for four years
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      meh, can someone move this to electronics? I'll probably get more help there
      • R_J
        • 9588
        These stereos were built well, I doubt it is a cap issue, It uses a linear power supply and if the caps were bad you would here a loud hum, I would suspect oxidized switch contacts and controls.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          he says it hums when it is turned on
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            "loud hum"
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I asked him if the hum changes with volume or changes when switching inputs, so we can narrow pre-amp, ground loop or PSU caps (I did a little reading)
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                On older stuff like that, lytics & resistors....with lytics being the number 1 suspect....but over time, resistors will drift far out of spec and cause issues.
                I've always enjoyed tinkering with older stuff like that, usually tube TV's. I was never proficient with them as far as principles (troubleshooting many times consisted of guessing and trial & error)...but they are fun!
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                  • 31213
                  pull out the spindle and lift the rubber deck mat.
                  there will be holes under it - see if it's belt or wheel-drive and if it's fucked!
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    I'm doing this blind. It's in arkansas and my customer wonders if I can fix it, we're in texas
                    • R_J
                      • 9588
                      If it hums when he turns it on it will need the power supply cap(s) for sure. It may need others, If you do get it, and you have a scope, thats the best way to find the weak capacitors.
                      I would not be too concerned with the turntable at this point, it will need a complete going over, clean the idler wheel, remove, clean & re-oil motor bushings, clean and lube turntable platter bearing and shaft.
                      Looks like a RCA model: VHT-52W I worked on a many of these but not in a long time. (the caps were not that old then)
                        • 31213
                        if you go to f-droid.com and install the store on your android phone,
                        then browse the store and install the scope, you phone can use it's mic to show waveforms and frequency.
                        handy for checking the hum for 50/60/100/120Hz
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          Main filters in the PSU are the #1 suspect if its an uncontrollable hum.....but something that old, all lytics would be suspect. Can you hear music over/under/with the hum? Like I said, I am not proficient with elderly things like this....but I do love tinkering with them....but trying to fix/diagnose it from another state might be challenging.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • redwire
                            • 3912
                            It's got FM stereo, RCA New Vista Victrola, Campobello model 1967 VTJ-61 chassis perhaps.
                            Have to look for the chassis number on the back and see if a schematic can be found. I think it would have germanium transistors and surely need re-capping.
                            They put out pretty good, I would add a stealth Bluetooth module for an aux. input or replacement for the phono input.
                            The turntable mechanical would be hardest to fix and a cartridge/needle might
                            be hard to find. I faintly remember they used idler-wheel drive, no belts.
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              Originally posted by redwire
                              ...it would have germanium transistors...
                              I'm ASSuming rather than simply short like modern silicon diodes/transistors (easy to diagnose), these would just become weak & leaky? I'm sure I've encountered these many many moons ago....but that's been many many moons ago...
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                I think the turntable is still working well, but i'll have to specifically ask him
                                • redwire
                                  • 3912
                                  It must have some silicon in the tuner to pull off FM radio at 100MHz, but you're right it's easy enough to replace germanium transistors with silicon. The power amplifiers would need the bias circuit changed for the different voltage 0.3V vs 0.7V
                                  • SolomonMan
                                    Vintage BK Precision 1403 Oscilloscope....
                                    by SolomonMan
                                    All,
                                    Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                    Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                    I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                    12-03-2023, 10:39 PM
                                  • DrDos
                                    Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                    by DrDos
                                    Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                    08-08-2025, 03:16 AM
                                  • edugimeno
                                    Diagnose real-vintage Strong-Hammer arcade machine
                                    by edugimeno
                                    Hi there!
                                    My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                                    I am attaching several pictures of the machine.
                                    It basically has 2 sides, left side has
                                    • 2 x 220->12+24v transformers
                                    • 2 relays (1 moves motor UP, other moves motor DOWN)
                                    • IGF and breakers for safety
                                    Right side is shown on pictures. It has 3 boards ( top-down)
                                    • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                                    02-29-2024, 11:05 AM
                                  • tony359
                                    Acer V58 Vintage Socket 7 Motherboard
                                    by tony359
                                    I'm trying to troubleshoot a vintage Acer V58 motherboard, ALI chipset 1541/1543. Symptoms are: it's very dead.
                                    The CPU in question, a plain Pentium 200, it works on a different board. I have checked the voltages, the clock and the reset lines. All checks out.
                                    However I have ZERO activity on the CPU data/address lines. It's like the CPU is told NOT to start but I cannot figure out how. A post-card shows "--" and there is of course no activity on the BIOS address/data lines.
                                    I checked the HLDA (Hold Acknowledge) line which could indicate...
                                    02-27-2024, 07:07 AM
                                  • icanic
                                    Panasonic TX-C81 Pro series vintage tv help.
                                    by icanic
                                    Hello ppl!
                                    Can someone help me where to start with repairing this CRT TV. I have an old vintage PRO series CRT TV from Panasonic, model is TX-C81, cant find any schematics online. I will post pictures with the problems.
                                    If someone could please tell me where could I start searching to solve the problems and what could be the cause of the problems.
                                    As you can see all colors are bleeding, it have white glow on black and that white cube is not straight at the top.
                                    But the main problem for me are the colors and white glow
                                    ohh and when brightness is a little bit...
                                    01-22-2024, 12:39 PM
