Panasonic TX-C81 Pro series vintage tv help.
  • icanic
    • Jul 2018
    • 16
    • Croatia
    Hello ppl!
    Can someone help me where to start with repairing this CRT TV. I have an old vintage PRO series CRT TV from Panasonic, model is TX-C81, cant find any schematics online. I will post pictures with the problems.
    If someone could please tell me where could I start searching to solve the problems and what could be the cause of the problems.
    As you can see all colors are bleeding, it have white glow on black and that white cube is not straight at the top.
    But the main problem for me are the colors and white glow
    ohh and when brightness is a little bit higher I have lines like on picture on the left side.
    Thank you!
  • Diah
    • Feb 2013
    • 6374
    CRT issue at Red gate, need to clean with high V line adapter... or you can DIY it by disconnect the circuit socket on the CRT Tube. feed the fitment of R Gate. and use the Tv High V line to spark the R gate. you can do it for all other G and B
    or the CRT coil need to add magnetic or new adj
    • icanic
      • Jul 2018
      • 16
      • Croatia
      Thank you for your response.
      Uhhh, sorry man but you talk to me like on Chinese
      I have a lot experience with repairing electronics but don't have experience with CRT's.
      Is there any simpler way to explain it :-)?
      You mean I need to disconnect circuit from the neck?
      • Diah
        • Feb 2013
        • 6374
        ok...please learn Chinese them i can response in future to you again,
        • icanic
          • Jul 2018
          • 16
          • Croatia
          Sorry, I did not wanted to insult you, it was just a joke on my expense.
          Just wanted to tell you that I did not understand a lot of things that you said to me (technical stuff not language).
          I saw your post about sending picture from backside but did not have time to respond.
          I will send pictures when I get TV dissasambled if you are still interested to help me.
          • icanic
            • Jul 2018
            • 16
            • Croatia
            You wanted to tell me to do CRT Rejuvenation?
            • kasfamily
              • Aug 2014
              • 765
              • Russia
              Hi ...
              • csmith
                • Aug 2014
                • 42
                I would just enjoy the TV the way it is. Looks to me to be the limitations with the technology of that time.
                • Andre Gilbert
                  by Andre Gilbert
                  11-20-2024, 08:52 PM
                • gtremblay
                  LG 42LV5400 problems with vertical band (20cm) with only somes colors
                  by gtremblay
                  I get this TV which power up but no LG Logo display or whatever.
                  Try to "bake" the mainboard at 385 for 10 minutes without success.
                  So, I order a new mainboard which at first.... has the same problem
                  since the shipping cost was almost the price of the board itself...
                  Again, I try to "bake" it 385 for 10 minutes but then, the TV start and everything seems fines! Nices colors, bright screen...
                  But... here's the problems:
                  With some flashy colors (blue sky or yellow (like in simpson)) there's 3 bands on the...
                  08-05-2019, 05:07 PM
                • jean luc ferre
                  laptop hp g72 b52sf screen problems
                  by jean luc ferre
                  on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                  the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                  i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                  i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                  06-07-2025, 03:27 PM
                • Hondaman
                  USB problems?
                  by Hondaman
                  Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                  (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                  I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                  08-12-2024, 03:26 PM
                • DrvLikHell
                  Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                  by DrvLikHell
                  Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                  The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                  07-05-2024, 02:54 AM
