Mix up of Cap. types
  • hkfriends
    • Jun 2005
    • 5
    Dears,
    I need to re-cap my motherboard (PCChips) for 8 pieces of 3300uF 6.3V
    my problem is : can I mix up of
    4 x Rubycon MCZ (10x25 ) 105C Ultra Low ESR
    4 x Rubycon ZL (12.5x20 ) 105C HIGH RIPPLE LOW IMPEDANCE (Bigger in Diameter Size)
    All are spec. with 3300uF 6.3V 105C
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Mix up of Cap. types
    it will be ok to mix them, both are low esr and you will have no probs. But if you wanted the best overclock it would be best to use only MCZ as they are one of the best caps you can get.
    what about the other caps on the board, do you have only 3300uf?
    • hkfriends
      • Jun 2005
      • 5
      the MB suddenly cannot be power up. and found that 8 cap of 3300uF 6.3v are not in flat.
      how can I know the cap (new) are correctly solder. Can I test them with voltmeter
      My PC still cannot be powered up
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        i didnt understand. have you recap the board already and still no power up?
        it is not likely to be a bad solder. if you have contacted the pads with the solder then there is no problem. difficult to make a mistake there.
        mistakes are made when you force the caps out or force the new caps in or if you heat the pads for a very long time. or even if you reverse polarity when you put the new caps in.
        do you have other caps on the board which are 1000uf and above? maybe you have fail in other caps. you know caps can be flat and still bad inside. replace all caps from bad manufacturers that are 1000uf and above.
        maybe you have other problems though. need to check VRMs for damage.
        https://www.badcaps.net/forum/showthread.php?t=600
        your PSU is tested ok right?
        post some pics of the board?
        • hkfriends
          • Jun 2005
          • 5
          thanks for your advise. sorry that i'm a little bit hurry in my last post....
          OK the situation is:
          1. I have recap all 3300nF 6.3V (total in 8 pieces) which are all bad in shape.
          2. This is my fist time for the recap soldering job. I double check the solder is firmly to hold the cap. but I worry the solder is not melt down in between the PCB layer and the cap pin.
          3. Before the recap job, once I press the power on button. the CPU fan will swing a little and nothing to POST.
          4. After the recap job, the CPU fan has no swing behaviour, the board is no POST. (that's why I guess may be the soldering job has problem)
          5. I didn't check any >1000uF cap in my board (may be check it later) I will try to take some photos here....
          6. BTW, I'm newb to check VRM. Is there any graphic presentation here / or photo.. I know what is VRM in my board. but don't know where is VRM in/out/ground...
          thanks again.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            this is what the purpose of the lead port is. Basically it is a foil which surrounds the hole and joins the solder pad on the front and rear of the board. It makes the connection to the traces in the layers of the board. If the lead port is not damaged then when you solder to the pads on the rear of the board, the connection is good no problem.
            • MD Willington
              • Sep 2004
              • 702
              What model is the PCChips mainboard?
              Ya'll think us folk from the country's real funny-like, dontcha?
              The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
              • hkfriends
                • Jun 2005
                • 5
                oh, my god.... may be I destroy the foil surrounds the hole...
                • hkfriends
                  • Jun 2005
                  • 5
                  I think it is a 925 model with socket 478 DDR + SDRAM mATX
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    hkfriends: are you gonna post some pics?
                    • ajdrenter
                      Picking caps for Antec SU-380
                      by ajdrenter
                      In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                      https://www.badcaps.net/forum/showthread.php?t=14159
                      It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                      05-13-2023, 10:40 AM
                    • ahmedtou
                      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                      by ahmedtou
                      help me please
                      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                      I will share all the details with you, including the disc information.
                      Code:
                      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                      Current Profile: BD-R
                      Disc Information:
                      Status: Empty
                      State of Last Session: Empty
                      Erasable: No
                      Free Sectors: 12,219,392
                      Free Space: 25,025,314,816 bytes
                      Free Time: 2715:27:17 (MM:SS:FF)
                      Next
                      08-27-2025, 08:49 AM
                    • EFritz20
                      Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
                      by EFritz20
                      I have a few busted Rubycons MBZ 3300uf 6.3v that are used for VRM purposes on a socket A motherboard. According to spec 12 mOhm with 2800 ripple.
                      I have used the search engine and it appears the Panasonics are the ones to get, but those are topics already years old and these electronic ultra low ESR caps aren't availably anymore .
                      I can't seem to find any available caps on the known sites that are in spec of these Rubycons. Also i can't find Polymers with 3300uf or even close to that. Closest ones i found where 2000/2200uf ones but...
                      05-20-2021, 10:22 AM
                    • withalligators
                      Looking for best replacements for Capxons, but can't find data sheets
                      by withalligators
                      Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                      1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                      1 x Capxon 1000uf35v...
                      03-25-2022, 02:30 PM
                    • omon
                      Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
                      by omon
                      I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
                      This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
                      I'm attaching the pictures of the bad cap.
                      Thank you so much!...
                      04-28-2021, 05:43 AM
