Overvolting/reversing a polymer cap
  • Rodalco
    • Feb 2019
    • 7
    • New Zealand
    Re: Overvolting/reversing a polymer cap
    I am in for blowing stuff up. Have 240-270 Volts with 32 Amps with 35 Amp variac to test with. Cap bank with 5 x 20 UF 6.6 kV Caps, but 14 Caps in total. Then 630 Volts at around 10 Amp to experiment with. Did a TV test with an old CRT TV which worked up to nearly 500 Volts AC.
    First smoke the TV out with some smoke tablets, then ramp up the voltage to 320 and 420 and 490 Volts till the TV popped. great fun.
    https://www.youtube.com/watch?v=mnMnOn_uU8U
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      To be honest, blowing up capacitors is not fun to me. The sole reason for blowing up the caps is to match behavior, assuming similar behavior means similar design. Yeah it's a bit of correlation is not causation but all these capacitors look so much alike, they all behave like capacitors, etc.
      So, how to tell them apart? Destructive testing. Yes, opening them is destructive as well, but capacitors are all still spiral wound foil. So how else to tell them apart? Testing (inspecting) for dryness is kind of "soggy" (how do you tell? touch it? need it to evaporate?)
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        I put a 16v poly in a monitors 25v line. It worked fine all night, next day, sounded like a firecracker went off. Can was popped off
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8711
          Interesting... so the videos aren't correct or not always typical?
          Did the lead fuse or did it actually out gas?
          Are you sure you have a real poly?
          ... do we need to open them, sniff them, and see if we get high on the https://www.badcaps.net/forum/showthread.php?t=74467 vapors to tell what it is?
            • 31287
            solids can change, gas or heat-up(and potentially burn or explode)
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8711
              Well, I never expected melt, but heat expansion is possible as well as electrochemical activity. Just wondering if the movie presented is typical behavior if subject to improper conditions.
              The movie still didn't demonstrate reverse polarity, so that's still a mystery
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • Perry Babin
                Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
                by Perry Babin
                I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
                This is for the primary side of a switching power supply in a car audio amplifier.
                Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
                10-16-2025, 05:20 AM
              • Perry Babin
                How do organic polymer caps compare to liquid electrolytic for reliability
                by Perry Babin
                I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                If not organic polymer, what would be the caps that could take the most abuse?
                08-18-2025, 04:04 PM
              • questore
                nvme and wifi error after liquid metal spill
                by questore
                Someone brought me a liquid metal damaged motherboard.
                First I have removed alll liquid metal from the board.
                0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
                Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
                There are 2 things that not working.
                1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
                2. nvme devices are not detected on either of the 2 slots....
                11-11-2025, 01:16 AM
              • chth96
                Should I replace polymer capacitor?
                by chth96
                a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                Is this ESR value of polymer capacitor correct?...
                11-18-2022, 04:22 AM
