Overvolting/reversing a polymer cap
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Just curious, have anyone videoed over volt or reverse connected polymer capacitors and posted how they fail?
    IIRC most of the videos I've seen are of cheap wet aluminum capacitors which are fairly spectacular, but what about polymer - do they mainly fail the same way? Or not?
    The wet aluminum capacitors will expand due to vapor generation of the liquid electrolyte and could blast off. Polymer capacitors have two transition phases from solid to liquid and then liquid to gas... so do they do the same thing or simply immolate on board?
    • 31287
    Re: Overvolting/reversing a polymer cap
    there is a vid on jtube,
    a bussbar with a line of poly's on it - they short out - presumably, because on most the leads melted!!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      So they fail like tantalum caps in which they simply short out? hmm... okay...
      Well, after they short then they differ I suppose, tantalum capacitors tend to immolate, but not polys?
        • 31287
        the poly's may have flared if they had been flush on a board - who knows.
        • bestsystem
          • May 2011
          • 59
          heatup and smoke, charred the bottom
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Reason why I'm asking:
            Destructive testing to prove a cap is a polymer cap versus an aluminum wet electrolytic
              • 31287
              or just cut into it.
              esr test will be conclusive anyway - the worst poly still blows away the best wet caps.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                If one doesn't have an ESR meter that has enough resolution, that's not an option...
                Was wondering about cutting into it and sensing any sort of moisture, but that's no fun
                • llonen
                  • Sep 2014
                  • 495
                  • hampshire
                  Well this is all the inspiration I need, what values did you have in mind and you you be prepared to send said samples for 'testing' I can currently manage 30 volts at 20 amps or 60 volts at 15 amps. Let me know if you want to do this I can video the results
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8711
                    Great, you can buy the stj clickbait capacitors to test
                    • llonen
                      • Sep 2014
                      • 495
                      • hampshire
                      I am not buying perfectly good capacitors to slaughter, but if some one wants to send me some for destructive testing I will be more than happy to oblige and put the results up on my youtube channel. Who knows if there is enough interest I might rebuild my old high voltage capacitive discharge rig which was good well up-to 20,000v.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8711
                        Who said they were perfectly good capacitors, that's what we're trying to find out if they are or not
                        So if you had to go buy some brand new Rulycons would they be considered perfectly good capacitors
                          • 31287
                          lol
                          that psu output sounds familiar.
                          is it military surplus?? wayne kerr???
                          • PeteS in CA
                            • Aug 2005
                            • 3583
                            • USA, Unsure of Planet
                            It's been 10 years or so, but I think that when I tortured some polymer caps - 8X or 10X their ripple current rating - they just deteriorated slowly. I probably declared victory when they reached 2X their initial impedance.
                            PeteS in CA
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8711
                              Heh, the intent for killing these "clickbait" polymer caps was to compare how they explode compared to wet aluminum capacitors to determine their internal design. Yeah it's not accurate at all but there's at least one person here who's interested in watching them explode if at all...
                              Question too for using more current than they're designed to handle is how long did it take at 9x current rating to reach 2x impedance... 1/10 of their rated lifetime? 1/100th?
                              • llonen
                                • Sep 2014
                                • 495
                                • hampshire
                                Well I have put the offer out there, Uk mailing address to be supplied via private message to interested party's. If you want to send me a selection of test subjects I will oblige in over volting and reverse volting them for your viewing pleasure. Bench test voltages available in case you missed are 30 volts @ 20 amp and 60 volts & 15 amp, results to be published on my youtube channel. The 20,000 rig was probably mostly military surplus parts I still have some of the parts but would have to hunt around to resurrect it, oh fond memories.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8711
                                  Darn, already done ... https://www.youtube.com/watch?v=BNaVokFOxjo
                                  So all I need to do is abuse it and it better not pop, just short out...
                                  • llonen
                                    • Sep 2014
                                    • 495
                                    • hampshire
                                    Needs more voltage, or lower voltage polys, I have had another look at the power supplies I have here, I can get up-to 60 volts with 32 amps available, on the high voltage side I can relatively easily get up-to 10kv @ 1uf. That will be around 50 joules assuming I can get it to full charge, it looks though I no longer have the 20kv caps though. I wont be checking this thread now so if there is any interest just pm me.
                                    • Heihachi_73
                                      • Jun 2012
                                      • 713
                                      And if not, "I ain't having it, where's my hammer?"
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3583
                                        Pretty sure it was hundreds of hours if not over a thousand. Not bad for 2000 hour (at max ripple and temp) parts. It was ~10 years and two jobs ago, so hazy memories.
                                        PeteS in CA
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          Replaced emmc.
                                          Terminal log
                                          UART
                                          AC_ON
                                          E-B
                                          FDE enabled
                                          06-01-2025, 02:11 AM
                                        • Perry Babin
                                          Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
                                          by Perry Babin
                                          I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
                                          This is for the primary side of a switching power supply in a car audio amplifier.
                                          Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
                                          10-16-2025, 05:20 AM
                                        • Perry Babin
                                          How do organic polymer caps compare to liquid electrolytic for reliability
                                          by Perry Babin
                                          I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                                          If not organic polymer, what would be the caps that could take the most abuse?
                                          08-18-2025, 04:04 PM
                                        • questore
                                          nvme and wifi error after liquid metal spill
                                          by questore
                                          Someone brought me a liquid metal damaged motherboard.
                                          First I have removed alll liquid metal from the board.
                                          0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
                                          Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
                                          There are 2 things that not working.
                                          1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
                                          2. nvme devices are not detected on either of the 2 slots....
                                          11-11-2025, 01:16 AM
                                        • chth96
                                          Should I replace polymer capacitor?
                                          by chth96
                                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                          Is this ESR value of polymer capacitor correct?...
                                          11-18-2022, 04:22 AM
