Hitachi Mains Cap?
  • jayjr1105
    • 281
    Hitachi Mains Cap?
    I just bought a new power supply and I've never seen this brand before.
    I know the Primary filter cap quality isn't super important in a switching PSU but was just curious.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • mariushm
    • May 2011
    • 3799
    Re: Hitachi Mains Cap?
    Seasonic uses them a lot, and I don't see any complaints.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      I've seen Hitachi 450V caps quite a bit, including in server PSUs. They seem fine.
      PeteS in CA
      • jayjr1105
        • 281
        Thanks guys. Wasn't overly concerned but I've opened up a few PSU units and never saw a blue mains cap.
        Ryzen 3600x
        FX-8802 Iron
          http://www.hitachi-chem.co.jp/englis...itors/003.html
          • jayjr1105
            • 281
            4000 Hours seems low for a "japanese" cap doesn't it?
            Ryzen 3600x
            FX-8802 Iron
            • PeteS in CA
              • Aug 2005
              • 3581
              Different series have different life ratings. Keep in mind that the rating is for operation at max temperature, ripple current and applied voltage. If the real temperature and ripple current are lower, the expected life will be much greater.
              PeteS in CA
                master hoarder
                • May 2008
                • 12175
                Not anymore. All these "new" Active PFC PSUs tend to stress the primary caps a lot more. So having Japanese caps in there matters.
                Even more important is how the APFC circuit of the PSU is designed. I'm not sure if this is a coincidence or actual link, but in the last several APFC PSU repairs I did with blown APFC stages, it seems that the primary caps went bad because they weren't rated for a high enough voltage (typically only 400V), probably for the manufacturer to save money. What's concerning is that both Japanese and non-Japanese caps were affected.
                So I would say that just about any APFC PSU with 400V-rated and/or non-Japanese primary caps is asking for trouble down the road.
                As for Hitachi primary caps - they are okay. I don't recall seeing any failure with them.
                • kevin!
                  recapping PCB.
                  • Jul 2013
                  • 195
                  • España
                  They are very good capacitors, do not worry about their reliability.
                  Sony also uses hitachi for its PS3.
                  Gaming pc:
                  nVidia RTX 3080 TI, Corsair RM750I.
                  Workshop PC:
                  Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                  Server:
                  • bestsystem
                    • May 2011
                    • 59
                    i never seen a failed primary capacitor, even in taiwanese brands
                    usually the output caps on DC 12V 5V rail fail first
                    • R_J
                      • Jun 2012
                      • 9590
                      Then you haven't repaired many units. I have seen hundreds, The latest was in a HP Brick power supply for an aio computer, the cap was a Rubicon 150µf/400v And it looked ok but the top was not quite flat and measured 115µf and would cause the P.S. to blow the fuse.
                        master hoarder
                        • May 2008
                        • 12175
                        On old PSUs *without* APFC - YES, the primary caps rarely go bad.
                        But on PSUs with APFC, I've seen plenty of failed primary caps.
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                        • chopduel
                          Bad mains power causing TV malfunctions?
                          by chopduel
                          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                          • TV would randomly turn off then back on.
                          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                          12-29-2024, 03:20 AM
                        • wolf1976
                          hitachi 50hk5600 problem with display
                          by wolf1976
                          hi
                          i have the above tv and the display starts distorts the display at only in applications like you tube
                          after and on the didital channels
                          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
                          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
                          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
                          09-13-2025, 02:26 PM
                        • massimomax
                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                          by massimomax
                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                          Post in English !!!
                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                          02-28-2025, 07:27 AM
                        • dragometin
                          Hitachi 40HYC42
                          by dragometin
                          TV Model: Hitachi 40HYC42
                          Power Supply: 17IPS71
                          MainBoard: 17MB95M
                          Panel: VES400UNDS-2D-NO3
                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                          Is there any variants on 17IPS71 power supply's?
                          UART output pins 10 and 12 on scart connector:
                          Code:
                          12:24:04.595
                          08-08-2024, 05:53 AM
