Fake Rubycon YXA 16v 2200uf 10x20 from eBay?
  • MegaOne302
    • Apr 2009
    • 94
    Is this cap real? I see no Rubycon 10x20 YXA 16v 2200uf caps on the datesheet.
    5
    Fake
    0%
    1
    Real
    0%
    4
    The poll is expired.
    Does an idiot make a sound if no one’s there to hear them talk?
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Fake Rubycon YXA 16v 2200uf 10x20 from eBay?
    Yes they exist, here attached you find the datasheet.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • MegaOne302
      • Apr 2009
      • 94
      I only see 12.5x20 at 16v 2200uf. The next down 2200uf 10x20 at 10v.
      • MegaOne302
        • Apr 2009
        • 94
        Take a look at the item.
        RUBYCON 16V 2200UF ESR Motherboard Capacitor JAPAN X 5 Item number: 400008355022
        • Gianni
          • Jul 2008
          • 681
          • Italy
          Sorry MegaOne302 I missed the part "10X20".
          I don't know what to say, maybe they made a mistake in the description.
          AFAIK there are no 2200uF 16V with lead spacing 3.5mm and diameter 20mm even for other brands.
          Ciao
          Gianni
          H. J. Brown
          • MegaOne302
            • Apr 2009
            • 94
            Real or Fake?
            Should I just trash them?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              looks like they are real.
              or the faker went through a bunch of trouble to make them look good which is unlikely.just because they do not show that size in the datasheet does not make them suspect.many mfrs.offer custom sizes .
              • MegaOne302
                • Apr 2009
                • 94
                Great...
                Thanks,
                Joe
                • linuxguru
                  • Apr 2005
                  • 1564
                  Some of the genuine Indonesian-made Rubycon YXGs, etc. look a lot like the ones in the pics - I'm guessing they're OK, but it's safer if they're stuck on a paper strip in a rectangular carton, or in a 200 pc. bag with Rubycon Indonesia legends on it.
                  Cut-lead caps or loose (unbagged) Rubies are suspect, but not necessarily fake. You'll need to do further investigation to verify them.
                  • MegaOne302
                    • Apr 2009
                    • 94
                    Anything I could do besides ESR testing, something with a DVM?
                    • MegaOne302
                      • Apr 2009
                      • 94
                      Just tested @ .15 ESR
                      They are junk…
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        ouch
                        sigpic
                        (Insert witty quote here)
                        • MegaOne302
                          • Apr 2009
                          • 94
                          It's funny because all my new 16V 1500uf MBZ test @ .08/.09 ESR, but the specs says the ESR should be .013. Are the ESR meter readings accurate, showing the true ESR?
                          I did the two resistor calibration; it's a Blue ESR meter.
                          • MegaOne302
                            • Apr 2009
                            • 94
                            Opps, forgot to short the leads to zero the meter out. The 16V 1500uf MBZ now read .01/.00 ESR. Just wish there was one more digit on the display.
                            The Rubycon 10x20 YXA 16v 2200uf now read .07 ESR, still bad for a motherboard.
                            • gdement
                              • Jan 2007
                              • 690
                              From looking at the datasheet, they don't appear to be low-ESR types.
                              • MegaOne302
                                • Apr 2009
                                • 94
                                I know that now; they were advertised as LOW ESR caps!
                                • linuxguru
                                  • Apr 2005
                                  • 1564
                                  70 milliohms is about right for the 2200/16/10mm YXA - these are probably authentic, and ok for use on the VRM input (+12v) side. However, there are much better caps in similar dimensions - for instance, Panasonic FJ 1800/16/10mm with ESR ~0.02 ohms, which are better replacements for the same application.
                                  • lucky13
                                    • Aug 2007
                                    • 412
                                    Isn;t that the date code 0436?
                                    That means 2004 ?
                                    Could the esr slowly migrates up?
