Pulled polymer cap still attached to the MB
  • Adrian_
    • Mar 2017
    • 40
    Got on hand a motherboard that has a small polymer cap knocked slightly out of place (still attached). It is just surface mounted (no holes) and due to other components in the area is next to impossible to de-solder using an iron. Would it have any chance to work if I manage to pull back the legs all the way inside?
    Sorry if this sounds like a silly question, but I'm not so familiar with the inner workings of the polymer caps.
    • 31214
    Re: Pulled polymer cap still attached to the MB
    no.
    the cap is probably damaged internally
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Funny, I was doing exactly this to "fix" "accidentally" broken LIQUID electrolytic capacitors...
      ... that was before I learned what ESR is...
        master hoarder
        • May 2008
        • 12175
        If the cap is knocked enough that one of its leads is broken and/or not making contact anymore, just rip it out and use a regular radial leaded electrolytic cap with its leads soldered onto the spot of the SMD cap. Easy way to get this repaired without hot air.
        Also, for stubborn SMD caps, I often find that removing them with brute-force is easier and (surprisingly) less damaging most of the time than trying to desolder them with an iron. My method is, put a flat head screw driver onto the lower plastic piece of the SMD cap and use a hammer to knock the cap off the board. This works only for SMD caps soldered to thick ground and power planes. Otherwise, you run the risk of ripping a board trace.
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
        • Perry Babin
          How do organic polymer caps compare to liquid electrolytic for reliability
          by Perry Babin
          I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
          If not organic polymer, what would be the caps that could take the most abuse?
          08-18-2025, 04:04 PM
        • plyanthony
          Razer Blade 15 no external display with attached screen disconnected from motherboard
          by plyanthony
          Computer in question : Razer Blade 15 2020 Base Model
          Model# RZ09-03286E22
          BIOS CHIP: WINBOND W25Q128BV
          What I'm trying to accomplish:
          I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
          What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
          W/Stock BIOS - 1.06:
          Disconnect the...
          02-01-2023, 09:35 PM
        • OriginalDaggers
          XBox 360 All Polymer Capacitors
          by OriginalDaggers
          As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
          I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
          If I have things right, I can replace them TO
          x9 : 1500uF 16V 10x20mm
          TO: 470uF Nichicon FPCAP R7
          x2 : 820uF 6.3V 8x12mm
          TO: 2.5V 820uF Nichicon FPCAP R5
          On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
          What's a good replacement for the smaller...
          This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
          02-20-2024, 12:49 PM
        • bhachi
          GALIO Rev A M11 ( HP Pro Tower 280 G9 PCI Desktop PC ) Schematic Needed Or if anyone can tell me the IC details attached
          by bhachi
          Hello There,
          As subject line suggests, can anyone provide the schematic for the same ?
          or can anyone through some lite on the IC/MOSFET/BUCK number ( pictures attached )...
          07-31-2025, 07:23 AM
