Dick Smith Oz-Caps
  • Neo2_000
    • Apr 2005
    • 180
    Dick Smith Oz-Caps
    Some of the first caps I bought were an assorted pack from Dick Smith Electronics here in Oz.
    Their representative staunchly defended the quality of the caps when I explained to him the Badcaps problem.
    Among them were "Hitano" brand 470uF x 25V. Going by the scant markings, I can only guess that they were: EHR SERIES High Temperature Radial Type 105C.
    http://www.hitano.com.tw/electrolytic.html
    Has anybody had any encounters with these or any comments to offer?
    Thanks,
    Neo.
  • bushytails
    Moderator
    • Dec 2004
    • 217
    typically cap assortments (at least the ones I've seen) contain Good Caps, however they're very rarely low-esr or of size/voltage ideal for motherboard repair...
    --Randy
    • Agent24
      Dick Smith Q-1760 linear power supply filter capacitor question
      by Agent24
      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
      It has at least one problem.
      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
      I have already ordered a replacement potentiometer, so that's not an issue.
      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
      All are CapXon...
      10-21-2025, 05:39 PM
    • Wilderone
      Dick Smith GE6992 Flashing Backlight every 10 secs
      by Wilderone
      Hi, wondering if I can get some assistance with this TV please.
      Backlight starts flashing on/off roughly every 10seconds after the TV gets warm. (10-20 minutes)
      I have stripped it down to the LED'S thinking I may see the culprit but all strings seem okay & test okay with LED Tester.
      Each LED string (4) measures 130v & drops around 2v when it flashes & back up to 130v.
      Power Supply number; tv6501-zc02-01
      Mainboard number; ms33930-zc01-01
      Panel number; V650HP1-PS6
      I have a basic Multimeter &...
      01-31-2019, 05:20 AM
    • CdDvdFlash
      DSE GE6878 possible TV receiver dying remote not working well
      by CdDvdFlash
      For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
      07-03-2024, 03:55 AM
    • GEARELECTRONICS
      Samxon capacitor esr
      by GEARELECTRONICS
      I need your advice.
      -SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
      -Is this esr reading realistic?
      Thank you
      05-29-2023, 07:26 AM
    • Jackplug 123
      Sony KD-49XE8396 49" Bravia LCD TV
      by Jackplug 123
      Hi There,
      When this set developed this fault a member of the family passed it on to me,while they bought a newer set.
      On power up via the separate 19v SMPSU, a dark screen,backlights and sound OK.
      On removing the rear cover later, I checked the TCON board and ordered a replacement just in case.The replacement board made no difference.Prior to replacing the TCON board,I cleaned all 3 ribbon cables with iso prop alcohol.
      Disconnecting one of the two LCD ribbons going to the LCD/Gate driver boards,managed to get half a working RHS screen with half the SONY logo "NY"...
      12-30-2022, 11:24 AM
