Re: Swapping japanese/generic electrolythics with solid-states
Yeah, Asus and Asrock (for some time, I'm not sure they still do it) ... used the reverse notation for capacitors where the filled side of the circle represented the positive.
Good to keep in mind as HP if I remember correctly often uses OEM motherboards made by Asus
I had an A8N, and I believe someone I knew had an A8V. Just remember one thing. These Asus boards have the capacitor half-moon mark on the POSITIVE side of the capacitor.Leave a comment:
for the asus a8v, i think u missed a cap near the cmos battery right by the mosfet. i have this exact same board and the cap and mosfet there actually regulates the 5vsb supply for the board. i recommend replacing that as well so u have 16 kzg caps to replace not 15.Leave a comment:
For the non-VRM caps of the ASUS A8V board, none of the caps need to have very good ESR spec, despite the originals being KZG. This is because older ASUS boards from that vintage use linear regulators pretty much throughout the board. Thus ultra-low ESR caps are not a requirement at all.
Originally posted by SnayperskayaThe green PCB is the Intel one, it's a server board that handles quite some load into it. I haven't seen any bulged (top) on it, just some sizzling. The board operates OK, I just want to recap BEFORE anything goes bad since I've heard the sizzling noise when using high power CPUs.
Originally posted by SnayperskayaWhat bothered me is that the board hadn't a single cap bulging or leaking (from the top) last time I've played with it, a year and half ago. Looks like bad caps can go poof even when not used at all.Leave a comment:
For both of these boards, they probably failed due to simply being a problem series (in the case of KZG) or maybe because the power supply had a bad 5v / 5v stand by circuit.
On the green board ... all but the one above the chipset and the one near the 24 pin atx connector are used as additional filtering for 5v in PCI slots and USB ports.
Not really worth spending extra money on polymer capacitors to replace those.. you can use any 820uF 6.3v .. 16v electrolytic capacitors with low esr ... can also be higher, 1000-1200uF would be safe to use. You can go up in voltage (if you have for example 820uF 16v capacitors left from another project for example you can use those), just make sure they're not too tall to block cards ... for example for the capacitors near the pci slots.
You can use any low ESR electrolytic capacitors .. panasonic fm, fr, nichicon hm, hn, nippon chemi con kze, ky , rubycon zlg , yxg, zlh, zlj
You can replace the 10v rated Nichicon capacitors with 6.3v rated capacitors, those are also used with 5v or less...
The second power supply also has some capacitors that only filter usb ports (they're near the usb connectors or headers) but that one has more of those near the cpu socket and memory sticks, probably that board uses a dc-dc converter that uses 5v to 1.8v or whatever the voltage used for memory is.
The first one uses 12v to produce the lower voltages for memory, because there's more sticks and makes more sense to use 12v for conversion.
For the Asus board:
Re-cap the VRM. Those caps are approaching almost 15 years now. I have opened up 15 year old Panasonic FL/FJ. They do not look pretty inside (electrolyte concentrates on the bottom - for lack of a better way of putting it at the moment). The VRM high and low are 8mm. For the high use 16V 270uF-470uF polymers or better, and for the low use 2.5v-4v 680uF or better (You can get 2.5v 1500uF polymers in 8mm if you're prepared to pay).
For the Intel board:
Just replace the electrolytics with polymer equivalents (and do the same for the Asus - i.e. replace all the non-VRM caps).
If you want to save money, use something like Panasonic FR or equivalent for these non-VRM caps.
If you need help finding caps, let me know.
Thanks. So I should go for a full recap on the Asus. I'll check the specs on the VRM caps (Rubys next to the CPU side, Panas to the IO side) later. What bothered me is that the board hadn't a single cap bulging or leaking (from the top) last time I've played with it, a year and half ago. Looks like bad caps can go poof even when not used at all.Leave a comment:
I've checked (eye only) two boards ATM:
ASUS A8V:
NCC KZG:
15x 820uF @ 6.3V
INTEL S5520HC:
NICHICON:
10x 470uf @ 10V
NCC KMG:
2X 470uF @ 16V
Apparently the failed/failing caps aren't responsible for the VRM. The Asus have some Panasonic and Rubycons there while the Intel have polymers.
The Asus got some bulged ones (so I think replacing all of them would be wiser) and the Intel have caps sizzling when operating at a high-power level (2x 130W CPUs).
If you need help finding caps, let me know.Leave a comment:
The first one uses 12v to produce the lower voltages for memory, because there's more sticks and makes more sense to use 12v for conversion.Leave a comment:
ASUS A8V:
NCC KZG:
15x 820uF @ 6.3V
INTEL S5520HC:
NICHICON:
10x 470uf @ 10V
NCC KMG:
2X 470uF @ 16V
The Asus got some bulged ones (so I think replacing all of them would be wiser) and the Intel have caps sizzling when operating at a high-power level (2x 130W CPUs).Leave a comment:
For the motherboard, you can safely use polymers to replace non-VRM caps. I recommend getting a bunch of 6.3V 820uF 8mm polymers for this purpose.
For the VRM, it depends. Which board do you have?Leave a comment:
Thanks, but I'd like to have a superior model, actually. I'd rather pay a little more into quality/lifespan.Leave a comment:
I've got another board with faulty NCC KZGs... What would be my best choice for replacing those?Leave a comment:
You won't find a solid polymer capacitor at 450V.
http://br.rsdelivers.com/product/rub...CE%BCf/7672832
This capacitor would be a good match if it fits (might not, pretty tall package)Leave a comment:
Really? It's my fault that eBay is full of low-quality items and shifty sellers? I'm not buying THAT. Did you even read the feedbacks in question? Many of the negative ones were complaints about the parcel never arriving (Not seller's fault, parcels get lost or stolen, it happens), and a lot of the neutral ones were about the parcels being delivered slowly or the cost being too expensive. None of those are the seller's fault. Postal service mistakes, thieves, or people not reading the auction are to blame.
Think about that last one. A person orders an item, pays for it, knowing full well what the purchase price is, then leaves bad or neutral feedback complaining that the cost was too high - those are the kinds of people who make eBay stupid... If you can't read, don't bid!
And, be realistic. No shop will ever attain 100% positive feedback, because there will always be an idiot buyer somewhere who will complain no matter what. The postal service damaged their item, you give them a full refund, and they'll still complain because they were "inconvenienced".
Maybe I'm biased, because I've sold a lot of second-hand gear etc I didn't want\need online, but if you're complaining that eBay is full of crappy sellers (I'm not saying it's not - it is), then you've never tried selling anything, because as soon as you do, you'll find out just how many crappy buyers there are too.
I've had them all, the idiots who bid and never contact, the ones who never pay, the ones who change their mind 20 times and then decide they don't want the item, the ones that break it and try to blame you, the ones that say it was stolen when the tracking shows they signed for it, the ones that re-arrange 5 different pickup days over 3 weeks but never show up.... etc.
I'm not defending bad sellers, but there's always two sides, and the buyer is not always the innocent victim. When you have a high-volume seller attracting many buyers (and at the low price-point, there's going to be a higher percentage of cheapskates and idiots to start with), they are going to get a proportionally higher number of unfair bad feedbacks. They'll also get a higher amount of well-deserved bad ones too, because they are indeed selling cheap junk.
BUT, bad sellers don't have free reign to do whatever they want - because it's YOUR decision to bid. They don't have a gun to your head, they're not forcing you to buy their trash.
And, nowhere in my previous post did I recommend that anyone should buy parts from such a seller!Last edited by Agent24; 04-02-2018, 05:25 PM.Leave a comment:
Out of 400,000 feedbacks, that is not a lot, and over half of those are probably from idiot buyers who didn't read the description properly, or did something else stupid.
That said, I wouldn't go on eBay either, but that said, if all he wants are 450v mains filter capacitors and they're not in an Active PFC circuit, then even the cheap multicomp ones would probably be fine (I'd prefer the Vishay), IF they are not fakes or factory seconds etc - which on eBay you never know!
Much better to buy from a real electronics supplier, although some decent places (like Dipmicro) are on eBay and are fairly trustworthy.
Now, if divy had filled in his user-profile properly to include his actual country, we might be able to recommend a decent supplier near to where he lives...Leave a comment:
Hi my TV power supply I have change capas 220uf 450vdc which capas to good to buy https://m.ebay.co.uk/itm/MAL21594722...QAAOSwEK9UCJ9R https://m.ebay.co.uk/itm/CAP-ALU-ELE...&ul_noapp=trueLeave a comment:
Hi my TV power supply I have change capas 220uf 450vdc which capas to good to buy https://m.ebay.co.uk/itm/MAL21594722...QAAOSwEK9UCJ9R https://m.ebay.co.uk/itm/CAP-ALU-ELE...&ul_noapp=trueLast edited by divy; 04-01-2018, 01:10 PM.Leave a comment:
No, but it will never have the same ESR rating in equal sizes, the solid polymer caps always have much lower ESR.
And in some circuits this can cause problems.
In others it can be a benefit, depends on the circuit...Leave a comment:
Would it have any bad consequences, considering both to be of the same ESR rating, size and capacitance? On overall circuits, not only motherboards and VGAs.Tags: None
by HondamanI ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
Does anyone have experience...-
by BleedCapI already posted this on vogons.
Its a 3d printed custom bracket for socket 478.
I used this AM4 bracket as a base design.
Its to be use with cheap generic clip based cpu cooler.
Reason for doing this is:
- Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
- New generic cooler is cheaper and can use bigger fan (less noise)
I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
The processor that I was using is P4 2.4Ghz prescott....-
by linuxrunneri have a 65" samsung UN65TU700DFXZA. my kid sprayed cooking oil from a spray/mist bottle onto the screen (2yr old thinking she was cleaning). oil ran down and seeped under the bezel on the bottom of the screen. It appears to have soaked/wicked into the diffuser i have a light colored splotch along the bottom of the screen that grew upwards over a day or two.
i have not disassembled yet but judging by the way it wicked up it looks like its been absorbed into the diffuser so i don't have a lot of hope of cleaning it.
i checked Samsung parts site but they don't... -
by DannyxGood day folks. It's been a while since I've DIY-d anything, so the other day I was thinking if it's possible to use the key fob of my car as a remote for other automation stuff. I have quite a few generic 433Mhz remotes and modules I picked up on Ali for various projects, but instead of having another remote dangling off the key chain, I thought I could use the car's own fob for more than unlocking my car when I'm near it. Say I come home and wish to switch on a light at my front door.
I already tried putting one of my generic receivers in pairing mode and hitting one of the 2... -
by zwectI got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...07-21-2025, 05:53 PM
- Loading...
