generic diffuser?
  • linuxrunner
    • Aug 2022
    generic diffuser?
    i have a 65" samsung UN65TU700DFXZA. my kid sprayed cooking oil from a spray/mist bottle onto the screen (2yr old thinking she was cleaning). oil ran down and seeped under the bezel on the bottom of the screen. It appears to have soaked/wicked into the diffuser i have a light colored splotch along the bottom of the screen that grew upwards over a day or two.
    i have not disassembled yet but judging by the way it wicked up it looks like its been absorbed into the diffuser so i don't have a lot of hope of cleaning it.
    i checked Samsung parts site but they don't list the diffuser, i have found a number of places that seem to sell generic diffuser screen. could i purchase a generic sheet of diffuser and cut to fit? any reason why this would need to be original part?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: generic diffuser?
    There is usually more than one sheet behind the LCD, one for diffusing the light then two polarizing filters.
    • linuxrunner
      • Aug 2022
      i assumed the polarizing filters were plastic and could probably be cleaned. any idea what the diffuser is typically made from? perhaps the oil is just wicking up between the sheets and not soaking into them and thus i could clean it out.
      • nomoresonys
        • 12206
        • U.S.
        Usually have the scan drive boards at the bottom, don't want them getting soaked with oil. I would carefully lay it flat to try to keep the oil from dripping down on them, really no choice but to strip it down and try to carefully clean it up, then maybe let it dry for a while before reassembly, it's a big screen and very easy to break, if it breaks thats ballgame. Maybe check youtube for backlight replacment to see how to dismantle if needed.
        • nomoresonys
          • 12206
          • U.S.
          this one is probably very similar: https://www.youtube.com/watch?v=nxO1QWuM7sU
          • jkruns
            M1 A2338 screen and touchbar issues after cleaning up liquid damage
            by jkruns
            This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
            My patient is an A2338 Macbook Pro M1 (late 2020).
            It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
            04-22-2024, 06:45 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
