Recap a single bad cap?
  • Yatti420
    • Mar 2008
    • 130
    Hi All,
    I have an eMachines T5212 I use for Folding @ Home.. Runs Ubuntu and has had its processor downgraded to a celeron D from a pentium D.. 1GB RAM in Ultra Coolers.. Runs with a decent amount of heat.. Ultra PCI slot blower cools the hdd and northbridge... Stock Case fan & heatsink.. Artic Silver 5 used.. Last time when I was inspecting the caps I came accross a single bulging cap.. I diddn't get time to break the comp down to get brand or anything..
    Should I replace a single bad cap? Is it worth it? Replace all the caps?
  • Leopard
    • Mar 2008
    • 109
    • Finland
    Re: Recap a single bad cap?
    Replace the bad cap and all caps that are of the same brand on the board as the badcap is. Well, you don't have to replace the low capacity ones, but 330uF and up should be replaced.
    • Yatti420
      • Mar 2008
      • 130
      They are all the same brand.. I don't think I have egnough experience to do an entire mobo.. Ill be lucky to get the 1 done properly lol.. Here is some more info.. 1 blown cap is right beside heatsink and a coil.. 1000uF 16v KZG written on the side i think.. Pics soon.. Thanks..
      • Yatti420
        • Mar 2008
        • 130
        • Yatti420
          • Mar 2008
          • 130
          Heres the pic of the bad cap.. Can I just do the 3\4 caps of equivalent rating right around the processor power cord thing there?? I don't want to brick the board.. I guess I could go cap by cap slowly.... I have Sanyo WG 16v 1000uf still will these be an adequate replacement?..
          • Yatti420
            • Mar 2008
            • 130
            I just purchased 3 equivalent KZG caps.. Ill probably just do the 1 and see what happens.. Have a good Christmas everybody..
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              WG and KZG are the same grade so WG should be fine.
              KZG have problems with heat so definitely replace those near the CPU and VRM's.
              Mann-Made Global Warming.
              - Dr Seuss
              • Yatti420
                • Mar 2008
                • 130
                Hmmm.. I can do the 3 inline with the KZG.. Or the 4 total with WG.. eMachines stock heatsink will get a fresh application of Artic Silver 5 which should help with heat..
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Artic silver only helps get heat get from the CPU to the heatsink faster.
                  The heatsink is still as hot as it was before (or hotter) but the CPU is cooler.
                  Problem with caps is from being near a hot heatsink so Artic silver won't help caps.
                  At least replace all KZG near heatsink.
                  - Dr Seuss
                  • Yatti420
                    • Mar 2008
                    • 130
                    Noted about artic silver 5...
                    I think I will do the 3\4 around the heatsink.. My eMachines finally finished the big work unit it was on.. It was very large and took close to two months.. I pushed it on an ailing cap.. I just opened it back up and found the cap right next to it bulging at the top..
                    Oh well I get to do atleast two caps and hopefully not mess anything up.. I find the hardest thing is to clean the holes properly.. I've sucessfully done my dell 15" monitor and went 1 out of 2 on linksys 4 ports so far.. (the one router must of had other bricked components..)
                    • Yatti420
                      • Mar 2008
                      • 130
                      I've recapped the eMachines two bad KZG caps with some fresh ones.. Suprisingly I diddn't check sizes.. The 1s I pulled were 8mm wide and around 12mm high i think.. The 1s i put in were like 10mm wide and 10mm high.. (Both KZG \ Same voltage and capcitance..)
                      Found a third bad cap underneath the heatsink (was poorly placed and soldered is probably touching the heatsink.. The botton looks like its ready 2 come out.. bung thingy?)
                      The specs on that cap look like from the same company (NCC) but different series.. TMV Series... It is 4v and 680uf.. Only 1 is blown which is covered by the heatsink..
                      Pic to come soon..
                      • Yatti420
                        • Mar 2008
                        • 130
                        I hope this works..
                        Let me know if it doesnt...
                        Should I replace this small cap? What does it control?
                        The caps I replaced initially were beside the heatsink in a row (see other pic)
                        Do these control\regulate the voltages that the processor gets?
                        Can I replace the blown one with an aluminum silvery1 one beside it?
                        My eMachines is running again now.. Stability issues in ubuntu seem to be gone when the processor is under extreme load from protein folding..
                        With this many caps going so quickly should I be looking at my PSU??
                        Thanks..
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          I can't see in photo well enough to tell anything.
                          If it's blown you should replace it.
                          As you have blown KZG you should replace all of those.
                          As the TMV is 4v it is probably on Vcore CPU voltage.
                          TMV seems to be an OEM only part and there is no data table available.
                          You should probably replace it with a solid polymar as it -probably- is one.
                          Yes, suspect PSU.
                          - Dr Seuss
                          • Yatti420
                            • Mar 2008
                            • 130
                            So replace it with an identical cap? When you refer to solid polymer do you mean it has solid electrolyte? I was thinking (if possible) replace it with an aluminum one shown next to it (red writing on top...) Will these handle the heat better?
                            • Yatti420
                              • Mar 2008
                              • 130
                              Here is a closer picture (attached) ...
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                From what I can tell the TMV is a hybrid polymer like the red Fujitzu next to it.
                                Not quite a 'solid' polymer but not a 'wet' electrolyte cap either.
                                They have a semi-dry electrolyte.
                                Those don't fail very often so it's probably either a random dud cap or a PSU issue.
                                http://cgi.ebay.com/ws/eBayISAPI.dll...m=290213956950
                                - Dr Seuss
                                • Yatti420
                                  • Mar 2008
                                  • 130
                                  Thats where I was looking aswell.. I will probably just recap it with the same equivalent.. I was just wondering if its possible to use a cap similiar to the red fujitsu.. All solid aluminum shell etc.. Are their any benefits?
                                  Thanks..
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    The TMV and the Fujitsu are the same kind of cap.
                                    The sleeve is only a way to mark them.
                                    - Dr Seuss
                                    • Yatti420
                                      • Mar 2008
                                      • 130
                                      Ok thanks for all the info..
                                      • Yatti420
                                        • Mar 2008
                                        • 130
                                        Finished with the TMV cap under the heatsink.. Everything still works so far.. Noticed another cap bulging up near the ram slots.. This one is probably due to heat as I have 2 sticks in ultra heatsinks which don't seem to work to well - probably not designed to be side by side touching.. This one I believe was 6.3v 1000uf NCC.. Im sure it was KZG series..
                                        Ill check again tommorow..
                                        What is the difference between KZJ 6.3 1000uF and KZG 6.3 1000uF? Pretty much appear the same.. Are they interchangeable?
                                        • goodpsusearch
                                          Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                                          by goodpsusearch
                                          Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                                          First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                                          05-05-2024, 02:04 PM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • amelbye
                                          is it ok to replace a dual output transformer with two single output transformers?
                                          by amelbye
                                          Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
                                          Now that's a challenge - luckily...
                                          08-21-2020, 08:51 AM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
                                        • RetroComputingGrotto
                                          Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                                          by RetroComputingGrotto
                                          I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                                          As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                                          What is your advice/opinion on whether or not on old(er)...
                                          04-03-2024, 08:30 AM
