Xytronic LF-389D capacitor quality
  • Delirious
    • Sep 2016
    • 29
    • Norway
    Hello!
    Some time ago I got myself a new soldering station as I was planning to start doing some more soldering. This soldering station is mains powered so it is not comparable to other larger soldering station. I have not really been using it much, but I read that the Xytronic stations might have bad caps so i decided to open it up.
    So as far as I can see there are only 2 caps:
    VLSOM 470 uF 25V
    STONE 100 uF 25V
    So the question is if I should replace them with something better? If so what would you recommend? I can get Rubycon and Panasonic quite easily. See the attached pics for more info.
    Any input is appreciated!
  • Fast Alpha
    • Feb 2013
    • 245
    • United Kingdom
    Re: Xytronic LF-389D capacitor quality
    https://www.rapidonline.com/xytronic...tation-85-6780
    You saved my money.
    Did you buy it from here?
    I don't know about soldering, but there are bad sellers from UK.
    http://www.hse.gov.uk/pubns/indg305.pdf
    • Delirious
      • Sep 2016
      • 29
      • Norway
      You saved my money.
      I don't know about soldering, but there are not very helpful around here.
      I got it for about 45 pounds at Elfa Distrelec some time ago. So I thought the price was pretty good.
      Were you planning on buying it?
      • Fast Alpha
        • Feb 2013
        • 245
        • United Kingdom
        I edited my message after you replied to it. Yep I was going to buy it but then I saw your photos. Not now!
        I need a 60W good long lasting solderint station, any ideas that are good?
          • 31289
          http://www.banggood.com/BAKON-950D-7...-p-982824.html
          is the best value i have ever seen.
          you can spend the difference on this:
          http://www.banggood.com/T12-Series-S...-p-932701.html
          you even get a discount if you buy them together.
          • Delirious
            • Sep 2016
            • 29
            • Norway
            Haha! Glad I could help you The BAKON looks good and I can vouch for Banggood.
            Still would people recommend me to change the caps?
              • 31289
              i would - i always change the chinese caps in stuff.
              i wouldnt panic though - i would still expect them to last a year or 2.
              • Delirious
                • Sep 2016
                • 29
                • Norway
                Thanks, Ill probable change them sooner than later.
                • mariushm
                  • May 2011
                  • 3799
                  The soldering station doesn't use a switching power supply, it's just plain rectification plus capacitor, so we're looking at 100-120 Hz and low temperatures insides (they won't be as hot as near switching ICs or diodes).
                  So for these purposes, the capacitors inside will be fine and should last a good amount of time, no need to hurry to change them.
                  And when you do decide to change them, no need to go with very low esr capacitors or polymers (no benefit going with that), just pick something with long life rating.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    wimpy transformer compared to what i see in other stations.
                      • 31289
                      yes, but afaik it's a 36v iron, not a 24v one.
                      • Delirious
                        • Sep 2016
                        • 29
                        • Norway
                        Okay thats good to know. Is there a downside with low esr capacitor except for price?
                        • mariushm
                          • May 2011
                          • 3799
                          It depends.
                          Some linear regulators don't like very low esr capacitors. For example *1117 linear regulators prefer capacitors on the output with esr between 0.1 ohm and 1 ohm, some polymer capacitors of very low esr capacitors can have esr below 0.1 ohms
                          With such an output capacitor, the output voltage could oscillate or the linear regulator could reset from time to time, making the station reset.
                          On your pcb, U2 is most likely a linear regulator (probably a 7805, which in general isn't very picky about capacitors) ... U3 is probably a LM358 opamp which again doesn't care about capacitors....
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            STONE capacitors are garbage. Replace. I would just change both for peace of mind, it'll take you 5 minutes. Use general purpose series like Rubycon YXA.
                            A working TV? How boring!
                            • Fast Alpha
                              • Feb 2013
                              • 245
                              • United Kingdom
                              It is from Hong Kong, I cannot use it as the plug is not a UK one!
                                • 31289
                                that's a European SCHUKO plug you fool!
                                • Fast Alpha
                                  • Feb 2013
                                  • 245
                                  • United Kingdom
                                  http://www.henrysdjpacentre.co.uk/ek...plug-519-p.jpg
                                    • 31289
                                    http://www.ebay.co.uk/itm/162046586628
                                    • Fast Alpha
                                      • Feb 2013
                                      • 245
                                      • United Kingdom
                                      So that is a good buy is it, nice one with the adapter.
                                      So I buy and try then you will fly.
                                        • 31289
                                        the iron is among the best - second only to JBC and Metcal
                                        the base looks o.k. - nice of them to show internal pics.
