Panasonic vs NCC
  • demetris
    • Apr 2008
    • 3
    Panasonic vs NCC
    Hi
    I have an issue with my vu duo and i need to change 3 capacitors on the motherboard(220uf 16v)
    I have found 2 different kinds that cost exactly the same 1.42 euros for 10 pieces
    i am now unable to figure out which to order.I need the community to help me out get the absolute best of those for my money to be spend wisely(and make my wife proud too )
    So the caps are:
    1. Panasonic FC series 8x11.5mm low impedance 220uf 16v
    2. Nichicon HV series 8x11.5mm high ripple current, low impedance 220uf 35v
    Thank you in advance for the help
    • 30944
    Re: Panasonic vs NCC
    where are you buying from?
    panasonic FR is usually cheaper than FC
    • michael dranfield
      • Jan 2016
      • 232
      • England
      I have used Panasonic FC and FM series for over 10 years and they never seem to fail again.The big problem with nichicon is they are widely copied by the Chinese counterfeit so you need to buy these from a trusted source eg farnell or RS .
      • mockingbird
        • Dec 2008
        • 5484
        Between Panasonic FC or Nichicon HV, Nichicon HV is the better option.
          • 30944
          as long as they arent from EvilBay.
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
            11-20-2024, 08:52 PM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • aa10aa10
            Panasonic Toughbook CF-33 mk1 BIOS repair
            by aa10aa10
            Good day,
            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
            01-21-2025, 06:13 AM
          • Mnawar27
            Panasonic CF-H2AU24EF3 bios locked
            by Mnawar27
            Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
            I need help to remove it,
            thankyou all.
            SN; 2FKCA26876...
            11-16-2024, 08:00 AM
