Panasonic vs NCC
  • demetris
    • Apr 2008
    Panasonic vs NCC
    Hi
    I have an issue with my vu duo and i need to change 3 capacitors on the motherboard(220uf 16v)
    I have found 2 different kinds that cost exactly the same 1.42 euros for 10 pieces
    i am now unable to figure out which to order.I need the community to help me out get the absolute best of those for my money to be spend wisely(and make my wife proud too )
    So the caps are:
    1. Panasonic FC series 8x11.5mm low impedance 220uf 16v
    2. Nichicon HV series 8x11.5mm high ripple current, low impedance 220uf 35v
    Thank you in advance for the help
    • 31288
    Re: Panasonic vs NCC
    where are you buying from?
    panasonic FR is usually cheaper than FC
    • michael dranfield
      • Jan 2016
      • 232
      • England
      I have used Panasonic FC and FM series for over 10 years and they never seem to fail again.The big problem with nichicon is they are widely copied by the Chinese counterfeit so you need to buy these from a trusted source eg farnell or RS .
      • mockingbird
        • Dec 2008
        • 5488
        Between Panasonic FC or Nichicon HV, Nichicon HV is the better option.
          • 31288
          as long as they arent from EvilBay.
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
          • Andre Gilbert
            by Andre Gilbert
            11-20-2024, 08:52 PM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • aa10aa10
            Panasonic Toughbook CF-33 mk1 BIOS repair
            by aa10aa10
            Good day,
            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
            01-21-2025, 06:13 AM
