Greetings. I was wondering how much higher voltage rating would be ok. The caps that need to be changed are 1000uF 6.3v and the replacements I can get for the easiest and cheapest are rubycon 1000uF 25v Y K . Will these do or are they too high voltage?
voltage difference limit?
Tags: None
Re: voltage difference limit?
Dear Friend,Originally posted by maximus7001Greetings. I was wondering how much higher voltage rating would be ok. The caps that need to be changed are 1000uF 6.3v and the replacements I can get for the easiest and cheapest are rubycon 1000uF 25v Y K . Will these do or are they too high voltage?
Choose only those capacitors which ESR/impedance is low.Comment
It's not a good idea to change capacitors on a PCB with capacitors that have a higher rated voltage , usually only the uF value can be bumped up , and not more than 80% of the original rated amount of uF. If you have a 6.3volt cap requirement and you use 25volt caps , the new caps will not run at the same rates up or down when running , this could cause instability problems or worse.
If 80% of the cap's original uF rating is bumped up 100% , you are entering the next ranges of caps that don't belong in those traces. Heat may be all that will result but is a tell-tale sign of a problem. Not to mention , it could change other voltage values on the mobo or component. Up or down.Comment
>> It's not a good idea to change capacitors on a PCB with capacitors that have a higher rated voltage. <<
-> BOGUS!!!
It is in fact a standard practice!!
.Mann-Made Global Warming.
- Dr Seuss
1000mf at 6.3 volt,
I would for sure jump to 10v
but up to 25v could mean they are way larger not just can size
but possably in lead size.
I know I would not be dremel drilling out holes
to fit the wrong part on a multi layer board.JimComment
That too.Mann-Made Global Warming.
- Dr Seuss
maximus7001
Look at digikey.com
They sell 1000uF in a number of series' that are superior in esr and ripple ratings to YK.
They ship to canada.Mann-Made Global Warming.
- Dr Seuss
What is this for?
What is original cap?
You may need to look at ripple rating/ESR too depending on what this is going into.
[They have links to data sheets too]
http://search.digikey.com/scripts/Dk...me=565-1630-ND
http://search.digikey.com/scripts/Dk...me=493-1707-ND
http://search.digikey.com/scripts/Dk...me=565-1486-ND
http://search.digikey.com/scripts/Dk...me=565-1878-NDMann-Made Global Warming.
- Dr Seuss
If running higher voltage capacitors is a good practice , then why not just install 50 volt or 100 volt capacitors all over the board , as they do come in all shapes and sizes?
I wouldn't exceed the voltage of any capacitor to any higher voltage , especially in specific areas where there are tiny onboard parts that may be overloaded by such an installation. I would say that it is perhaps not a good idea to more than "double" any capacitor's range.
Smoke is a tell-tale sign of too much voltage
The voltage stated in a capacitors ratings is a LIMIT not a goal.
What you say is idiotic.
- Examples right in your face:
16v caps on a motherboard are on 12v power. - NOT 16v power.
Both 10v and 6.3v caps on motherboards are used on BOTH 3.3v and 5v power.
- NOT 10v and 6.3v power.
10v is OFTEN used in place of 6.3v on BOTH 3.3v and 5v power because they are larger physically and tend to have lower ESR and higher ripple.
- 10v cap on 3.3v power is normal from the factory on some boards and in MOST PSU's.
Go find a 2200uF 50v cap and tell me how big it is.
- And how much it costs.
- Tell me how you are gonna stuff 10 of those in next to your heatsink on you mobo.
- Dr Seuss
One good solid proof of not being able to change voltages is with fuses in your fusebox at home. Install a 15amp fuse in a 30amp socket and run the power to see what happens to the fuse , it will blow right away with no recourse for the fuse.
Most times the fuse will blow upon installation even though it is of the same voltage but the conduction plate inside the fuse is only rated to withstand 15amperes , not 30amperes. One other good example is your car's air conditioning fuse - it is usually one of the only 30amp fuses in the box , if you install a 20amp fuse temporarily , your heater/air fan will run slower than normal for a while , and then it will blow the fuse because current draw can reach 30amperes. (where the fuse can not run)
Why are you talking about "One good solid proof of not being able to change voltages"?
You are comparing 2 fuses with different CURRENT CAPABILITY 15amp versus 30amp not different voltage rating.Originally posted by chipperOne good solid proof of not being able to change voltages is with fuses in your fusebox at home. Install a 15amp fuse in a 30amp socket
You can only overload a circuit when you place a CAP which is higher in uF and not in V rating compared to the original CAP.Originally posted by chipperI wouldn't exceed the voltage of any capacitor to any higher voltage , especially in specific areas where there are tiny onboard parts that may be overloaded by such an installation.
Just my 2 cents
Gianni"In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
H. J. BrownComment
The Voltage is a Limit Rating. Nothing more nothing less. If the new cap is a higher rated voltage and there is room to install in the same spot it is ok to use, period. Its kind of like using a 1 gal pot for 1/2 gal water, any volume below 1 gal will work. You want to stay above the highest possible voltage the cap will ever see. Most high quality company's use 35% to 50% tolerance over rating to ensure stability. Low quality company's use only a 10% to 15% margin to cut cost. This is why Fisher & the like cost more but you get what you pay for.....Comment
Chipper, you are a moron.
Going with you failed attempt at an analogy: Using a cap on a voltage UNDER it's LIMIT would correlate to using a fuse on a circuit that pulls LESS amps than the fuses' rated LIMIT. - With your numbers - 15 amps through a 30 amp fuse will not blow the fuse.
What I've told you is correct and very VERY VERY basic electrical knowledge.
- Dr Seuss
sounds like someone needs a bit of study in basic electrical!Originally posted by chipperOne good solid proof of not being able to change voltages is with fuses in your fusebox at home. Install a 15amp fuse in a 30amp socket and run the power to see what happens to the fuse , it will blow right away with no recourse for the fuse.
fan will run slower?
ROFLOL!Comment
Originally posted by GianniWhy are you talking about "One good solid proof of not being able to change voltages"?
Just my 2 cents
Gianni
To be more "specific" , lets look at how rectifiers work . Rectifiers convert AC current into DC current for distribution in circuits. "Specifically" - rectifiers will work differently depending on "how" they are set up and what current is made available to them. In fact , if the wrong current is supplied to a rectifier (which usually has paired IC's and a voltage regulator (3)) , the capacitors may never "unload" , causing them to burst. Meanwhile there has also been an abnormal taxing of power placed on the source power supply and it's attached components.
One other such example is on a tv's video board controller chips , if they receive the wrong current (voltage) , they will fail over time or in most cases be instantly damaged without recourse. If you read any of the PDF documents on specific IC's or any processor chips , a warning is usually at the end that explicitly tells you that their products "will-not" work properly or extensively in ranges other than specified by the manufacturer.
In conclusion if you hooked up a capacitor that was 100v to a regulator IC that is supposed to operate on the normal circuit voltage of 25v , the very first thing that will happen is the voltage regulator will run at maximum resistance full time and it will fail sometime shortly afterwards depending on the severity of the overload. Since voltage regulators are attached to dependant circuits for "reduced or regulated voltage" - they too can sustain damage or worse , they can cause a fire.
You can only get away with increasing the voltage flow or volume on something that has no other circuits depending upon the capacitor , like a single fan for example. But IC's are Integrated Circuits - not single circuits.
As far as comparing cars or anything else - if you installed a 100volt electrical supply to your 12volt car wiring , all of the insulation would heat up and eventually be burning until the wiring caused a failure of the system integration.Comment
Originally posted by kc8adusounds like someone needs a bit of study in basic electrical!
ROFLOL!
Definately a fan with a lower rated fuse than what is required will run slower if at all , if the fan circuit depends on the fuse link for power.Comment
by quicknameI'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
I decided to verify that the batteries were... -
The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
Internal soft-start results in small inrush current and extends battery life.
The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...-
Channel: Common Parts Library - Datasheets
10-07-2024, 05:02 AM -
by BradbeatHi,
I have a PGOOD pin down on this chip and I’m wondering if it could be because there is 5,2 v on VREG5 ( the high limit according to the datasheet is 5,1v ).
if yes, why is it to high?
the motherboard board is LA-G881P.
thank you.
here is some measurements :- VIN = 16,3 V
- VREG3 = 3,299 V
- VREG5 = 5,203 V
- SW2 (repos) = 3,423 V, pikes at ~16,4 V
- VBST2 = 8,592 V → VBST2 − SW2 = ≈ 5,17 V
- VO1 = 5,28 V (stable)
- EN1 = 3,08 V, EN2 = 3,04 V
- VFB1/VFB2 ≈ 2,1 V
ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
Highly Integrated Narrow VDC Battery Charger for Notebook Computers
The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
Narrow VDC applications where the system power source is
either the battery pack or the regulated output of the charger.
This makes the max voltage to the system equal to the max
battery voltage instead of the max adapter voltage. Operating
at lower system voltage can improve...-
11-05-2024, 04:43 PM -
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?... - Loading...
