Recapped mobo effecting RAM?
  • Wizard
    • Mar 2008
    • 2296
    Re: Recapped mobo effecting RAM?
    Second post:
    More comment on VIA; once I get stuff ready to go in, then I'll turf my last VIA-based computer with intel at work also XP. This pc is last one to go. Then I'll have pile of VIA working boards to sell off.
    Cheers, Wizard
    • Newbie2
      • Sep 2005
      • 885
      I used to have a QDI Advance 3 motherboard (old Super Socket 7 board with VIA chipset) that came in with 3 bad caps. Replaced all of the 1000uf 6.3V caps on the board with Nichicon HE series caps of the same capacitance and voltage, and with 128MB of RAM installed on the board it would freeze up to the point that the cursor is stuck and the keyboard doesn't respond. Trying Windows 98 and Windows ME made no difference. I put the same RAM into another computer of the same era that used PC100/PC133 memory, and it didn't freeze there.
      Putting in 1 stick of 64MB PC100 RAM solved the freeze up problems, but putting back the 128MB PC100 RAM the freeze-up problems came back. It was a bizarre case for me, so later I gave up and scrapped that motherboard for parts.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • jake-b
        dell e6540 boots to black screen (no dell logo)
        by jake-b
        good morning all,
        i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
        01-08-2024, 10:29 AM
      • Aimbit
        Xbox One Controller - Phantom stick activity (sticks completely uninstalled)
        by Aimbit
        Hi All,
        I bought some used Xbox one controllers "as is/untested" and they both have the same issue. The joysticks go wild for no reason while plugged in.
        https://youtube.com/shorts/YTYtjUPkBX0?feature=share
        I removed both joysticks assuming it was an issue with the sticks, but the video posted here is the activity of the sticks with no sticks installed! My only guess is one of the tiny IC's that reads the inputs is broken. There are two small ones near either joystick, and then one larger one. I found a replacement on Aliexpress for the larger one...
        02-15-2024, 11:26 PM
      • Cerberuska
        Mobo MSI B550-A PRO password popup
        by Cerberuska
        Hello guys,
        I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
        BIOS I updated to last one.
        any suggestions?
        And same thing for two different 5600G, and yes, MoBo supposed to support it.
        Thank you...
        11-10-2024, 01:23 PM
      • mrsith
        Dell G3 17 3779 - no display after mobo replacement
        by mrsith
        Hi guys,
        I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
        Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
        04-30-2023, 05:11 AM
