UCC made where?
  • WeaselXP
    • Oct 2015
    • 107
    UCC made where?
    I recently received a few packets of different KZN and other series, some of them are labeled " country of origin " Japan, some say China. Is this normal and should I be worried?
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    Re: UCC made where?
    Is it normal: I'm going to say "yes". Just because they are called "Japanese", most capacitors are going to be made in China or Taiwan, even if they are from Panasonic, Rubycon, or NCC. In general if a cap is "chinese" or "taiwanese" or "Japanese" typically is used to refer to the the company that makes them.
    • WeaselXP
      • Oct 2015
      • 107
      Re: UCC made where?
      OK, thanks. I noticed that most of the Panasonics were made in Malaysia as were most of the Nichicons. Rubycons were mostly from Japan. The UCC KZN's I got were made in Japan, China and Malaysia. Somehow I figured that they would make a series in one place. Guess not.
      • japlytic
        • Oct 2005
        • 2086
        Re: UCC made where?
        Where did you buy these capacitors from?
        • Behemot
          • 4845
          • CZ
          Re: UCC made where?
          IIRC Rubycon is the only on of them who has no fab in China, only Malaysia or somewhere around that corner.
          • WeaselXP
            • Oct 2015
            • 107
            Re: UCC made where?
            Digikey.
            • capwizard
              Cheap China, Japan Tv actually are made in the British!
              by capwizard
              Let me ask a question first. is British making any TV ?
              Foxconn is going to Produce 100 inch TV over American at Wisconsin, invited by Trump.
              01-12-2019, 10:02 AM
            • elmontador
              LG RL4 (i made a mess)
              by elmontador
              Hello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful...
              09-02-2025, 03:31 AM
            • handsworth
              Tv taping method made easy
              by handsworth
              Just wanted to share some information that I ran across when attempting to do the tape method on a tv with a shorted panel. I normally use magnifying glasses however while watching a you tube video, the person was using their phone. It seems that the Iphone has a magnifier app and wow, it works great. I have Iphone 11 and the app is built in. Pictures attached are screen shots. Made taping the pins a breeze. Also useful when reading the tiny print on the boards. Hope this helps somebody. ...
              02-11-2025, 09:07 AM
            • rumi409
              LG OLED C1 Pixel Cleaning Made Picture Worse
              by rumi409
              ​​​​​​ Hi,
              I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
              11-15-2024, 01:09 AM
            • 13mh13
              Aluminum SMD caps vs thru hole caps (reliability)
              by 13mh13
              The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
              https://i.postimg.cc/kGrR6BpZ/image.jpg
              I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
              I have not tested/replaced those alum. SMD electro PCB caps.
              Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
              All the thru hole electros I removed / replaced on this CDP (and most...
              04-05-2024, 07:41 PM
