Symptom question
  • DaveAtFraud
    • Jan 2008
    • 13
    Symptom question
    I have an Abit KG7-RAID that I have been using for a home server that may have bad capacitors (they look a little bulged). The symptom I'm seeing is backups sometimes fail. I first saw the problem with amanda reporting:
    /home lev 0 FAILED [compress got signal 11, /bin/tar got signal 13]
    but other partitions completing with no problems. I tried to reproduce the problem by running what I think is the same command amanda uses:
    /bin/tar -X /etc/amanda/exclude-list/exclude.txt -cvf - /home | gzip -v -c > /share2/dave/Home.tar.gz
    Sometimes this command completes with no problems, sometimes I get a seg fault and, least frequently, I get a kernel panic. The system is stable otherwise and running a backup is probably the only significant load the system sees. CPU temperature appears to be fairly nominal (110F to 115F) and I gave the system a thorough cleaning to try to eliminate overheating as a possible cause of the problem.
    This system is old enough that I wouldn't have a problem replacing the MB if the capacitors are the problem. On the other hand, the system is more than sufficient for our needs so I don't want to shell out for a new MB unless this really is the problem. Will bad capacitors cause a load related instability?
    Thanks,
    Dave
    Quitely implementing RFC 1925 wherever I go.
  • starfury1
    • May 2006
    • 1256
    Re: Symptom question
    well not the guru here
    but Maybe its more likely your psu although if you are using it as a home server
    (is it on a lot of the time? ok since you got a link to it its probably 24/7?)
    possibly both given age
    normally bad caps will cause hangs and reboots but I suppose it does depend on the actual MB.
    not sure of caps used and some are dogs...but if they "look a little bulged" recap is probably a very good idea. (given age and use too)
    what is brand Model is the PSU used in it?
    Welcome, cheers
    • DaveAtFraud
      • Jan 2008
      • 13
      System is on 24x7x365. It's my own little corner of the internet. Other than a few reboots for software updates or powerdowns to replace hardware it's been running continuously since December 2002.
      I'll probably just replace the MB and PSU since this is also does my web and mail serving. If I need to spend the money, I'll spend it. I just don't want to trash something that's still good because it might be the problem.
      What is brand Model is the PSU used in it?
      The PSU is an Antec SmartPower 400w (yes, I've seen the Antec thread here). MB is an Abit KG7-RAID.
      Welcome, cheers
      Thanks,
      Dave
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the antec is the prime culprit here.
        open it up and look at all the bulging/leaking fuhkkyu caps.
        i would do a preemptive recap of the mobo and psu if it were mine.
        • DaveAtFraud
          • Jan 2008
          • 13
          I've got a spare PSU someplace. I'll swap it in and see if things improve.
          Sad thing is that I specifically bought Antec PSUs because they had such a good reputation at that time. I think my spare is fairly generic but low run time (got used by my nephew for a couple of weeks when he needed a spare).
          Thanks,
          Dave
          • PedroDaGr8
            • Oct 2006
            • 130
            By the way the cap company is actually fuhjyyu and it tends to be the biggest problem. A simple quick visual inspection could give you all of the answers that you desire. No need to be afraid of it, just look in at the motherboard see if any of the caps are bulging or are of known bad companies such as GSC or OST etc., open the PSU (usually 4-6 screws and it opens fine) see for bulging caps. That will save you time and let you know what it could be. Rather than switching parts and waiting for an error to occur
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              should have put the real name with the common name after it.
              btw the o.p is encouraged to post pics of the mess in that antec and the board.
              • starfury1
                • May 2006
                • 1256
                Other than a few reboots for software updates or power downs to replace hardware it's been running continuously since December 2002.
                Thats like 5 years.... 43,800 hours of up time.....not a bad "innings" really considering. (cricket speak)
                so going by the above, its on the way down and will only get worse as time goes on, and the caps age (dry out) more.
                (any electrolytic cap does have a finite life)
                Yeah from what I read around here
                (it does depend I suppose on exact model)
                The recap of the Antec with quality caps does make for an OK supply, is my understanding (its actually "not" a junk supply just bad choice of caps used)
                (stand to be corrected on the above thought)
                I would most defiantly recap the MB and PSU plus rework solder joints in psu heavy sections.
                considering its use.
                but if you are happy to replace both and reload/install all software you could get a better server out of that these days.
                If you are happy with it as it is performance wise in a reliable working condition then recapping is the best alternative.
                Its not that hard but does required a bit of practice to get your soldering skills up to par and of course a soldering iron or 2, read the FAQ's on recapping
                If you don't want to attempt a recap yourself then get a quote on a recap from TC (forum owner) or other approved forum members in your part of the world.
                A local "decent" electronics repair shop should be able to do this work for you but I myself would much prefer to deal with someone that knows and fully appreciates the true nature of MB, PSU recapping
                As KC8 said, crack open you PSU and post some photos of it and the MB too if you don't mind
                As the old saying goes a picture is worth a thousand words.
                BTW may understanding is, it is preferred if you post photos on the forum site rather then off site links.
                (they tend to die and change and your left with txt and no photo)
                but I think thats up to you
                (the site does snuffle them for prosperity thought ).
                Anyway the choice is yours
                please keep us posted on the situation, thanks
                HTH Cheers
                • DaveAtFraud
                  • Jan 2008
                  • 13
                  Not sure if my digital camera is up to capturing the details but I'll see what I can do. I'll wait until the MB is out of the case though to get a picture. I'm thinking the top bulges will be much more apparent with an oblique shot.
                  The system is in an Antec case (at least the case hasn't given me any problems) so I have the side panel off as I'm typing. No problem checking to see what the capacitors on the MB look like. Checking the PSU will have to wait until I have a replacement since I'm off the net when the system is down (someday I'll look into having someone host me but then I don't have any more fun).
                  I'm just hoping the MB and PSU hold together long enough for me to make a decision as to how I want to replace them. Lots of options. I'm thinking I'll pick up a decent replacement PSU tomorrow and do a quick swap. If the PSU isn't the problem, I end up with a spare PSU. If the PSU is part of the problem, tomorrow is trash day.
                  Cheers,
                  Dave
                  • starfury1
                    • May 2006
                    • 1256
                    well it not going to fail over night
                    (although stranger things have happened)
                    But yeah get another "decent quality" PSU and try it since you basically want to keep the box in service
                    since you are in some respects abusing it it needs to be a decent one with decent caps but yeah server grades arn't cheap I suppose
                    I am not really the best guy to recommend a psu thought
                    But maybe a Seasonic s2 series or whatever it is consumer job I think the range all use decent jap caps
                    Corsair HX 620W is built on the seasonic guts not sure but think the HX520 uses jap caps too and seasonic built
                    VX series are from another psu builder but I believe still are good supply but may not quite be the same as hx in regards to caps
                    (I mention these cause they are a little cheaper but still somewhat a quality supply)
                    You requirement is "long term reliability" not grunt power of psu
                    (but a little extra never hurts)
                    Sounds like you going for the rebuild so may as well go for one you can reuse
                    Depending on what level of crap the other supply you mentioned you had is, it could tied you over (thats if you still got it)
                    post what it is for comment
                    MB caps sounds like they aren't too bad
                    (but caps can fail and show no physical signs of failure)
                    psu is more likely your trouble spot at this point
                    MB sound like its on the start of the slippery slope
                    (like KC8 said its more a preemptive move a recap now for the MB)
                    What you tend to find is as they start to fail you get more system hangs and reboots
                    it could take it a year (or more depending) to get to that level were its hanging rebooting very frequently.
                    (but as they go down the possibly becomes more a good chance of happening and usually right when you don't want it to)
                    So you probably got a little bit of breathing space with the MB.
                    Anyway a new psu will soon tell and make sure you crack open the old one to confirm the condition of caps.
                    keep us posted on your findings, the more conclusive outcomes we have the better
                    Cheers
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      Most actual PSU`s are not intended for an high 5v & 3.3v load. So may be it is the smartest option to recap & refan the Antec.
                      • DaveAtFraud
                        • Jan 2008
                        • 13
                        Played vulture at the local CompUSA going out of business sale and picked up a CoolerMaster 500w PSU for $60. I figure I'll swap PSUs tonight. Since I'm not exactly an electronics handyman, I figure I'll swap out the MB and then see if I can fix it when breaking it doesn't mean that I'm off the 'net. Same for the old PSU. If I'm successful, I can retire my old "crash and burn" test system: a 733MHz PIII.
                        BTW, I'm wondering if the MB lasted as long as it did since the system is always on. I'm thinking the capacitors have had very few cycles of charging and discharging. That's about all I know about capacitors so they may have some other use on a MB.
                        Cheers,
                        Dave
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Not true with the older PSUs. That's only true with PSUs of 2005 and later, because of changed ATX specs. Because the later ATX specs use the +12V for the Vcore VRM.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • bgavin
                            • Jan 2007
                            • 1355
                            I have a whole lot of KG7 in client service, and have recapped most of them.
                            470 16.0 8.0 20.0 4
                            1000 6.3 8.0 12.0 1
                            1000 10.0 8.0 15.0 15
                            1500 6.3 8.0 15.0 9
                            3300 6.3 10.0 25.0 6
                            The above table is from my spread sheet:
                            uF voltage diameter length count
                            It will look awful when the board compresses the columns. I recapped all the above with MCZ. IMO, it is worth recapping these boards, just to salvage the investment in XP-2000 processors.
                            Memtest86+ fails 100% on Test 5 for this board. Ignore it. It is a diagnostic bug peculiar to Athlons, AMD-761 and some other obscure conditions. All my boards operate propely, yet all fail Test #5.
                            Be sure to flash BIOS to the "DS" version.
                            • starfury1
                              • May 2006
                              • 1256
                              humm yeah spec on psu not totally sure off hand "which is why the not the best guy thing"
                              and yeah spec etc have changed.
                              Cooler Master I have read of problem(s) with
                              (not sure of model(s) and don't recall what they were)
                              I nearly got one for this box (now using Corsair HX620W )
                              (it was the only thing in stock at the time and not all that cheap, cooler master)
                              If memory serves they don't have the best of caps (but few do),
                              I think problem(s) were more minor thing.
                              Still it should last a while and isn't a crap supply I don't think.
                              but again I'll stand to be corrected on the above re the Cooler Master PSU
                              Thing is, now you are aware of the issues and know what to look for if its starts getting flaky and you suspect HW prob
                              Now too is the test,
                              but like I said crack open that Antec to confirm stuffed caps.
                              that should help you rest a little easier about the system.
                              I would say the cycling (or lack of) also possibly really more so the heat remaining at a more constant rate
                              (not much expansion and contraction of the MB and components )
                              may have helped in its longer life and minimal issues
                              so keep it well ventilated and clear of dust.
                              (make,use dust filters of some kind if your not already)
                              When the VRM powers up,
                              the caps used for the CPU Voltage (output VRM caps) are changed via the VRM circuit at a limited rate.
                              (so inrush current to them is limited)
                              In other words their just not dumped across a voltage and allowed to suck as much current as they can.
                              Thats my understanding anyway
                              I should have mention , I have read of HDD stopping in server and never starting up again so hope you had everything backed up before shutting it down.
                              (only what I ve read but they are a mechanical device)
                              from the sounds of it you do regular backups anyway.
                              (again how much truth is in that I don't know but it sounds very possible to me)
                              Anyway like I said if you like the system and it works well for your needs
                              recap is the real best way to go for the MB
                              if it was me Id have a spare MB
                              (knowing me, probably system)
                              I could put into service
                              Maybe on you next computer fair hunt see if you can find a not too abused spare MB
                              (thats just a thought and of course you would have to make sure its works ..then get it recapped)
                              These days you can get a lot of grunt for not too much outlay so maybe thats really the way to go.
                              is this the MB?
                              http://www.techspot.com/reviews/hardware/abit_kg7raid/
                              http://www.ocworkbench.com/hardware/.../kg7raidp2.htm
                              just a thought really and only mention it cause of how you are using it.
                              The reason I asked was those chipset fans fail a lot from what I understand and although a non OCed system, the passive heatsink might handle it you might want to look a using a totally passive heatsink (little larger one) for the chipset.
                              (and thats if its got one)
                              Bgavin may have some input on this, and thanks mate for posting the cap list
                              like I said not the Guru here and these are only ideas that are open to correction or better ones
                              keep us posted
                              Cheers
                              • DaveAtFraud
                                • Jan 2008
                                • 13
                                I'm guessing that a lot of people got burned by bad caps in the supply chain. I seem to remember that CoolerMaster was one of the PSUs that Tom's Hardware liked at one point.
                                May have to wait until this weekend unless a crash forces my hand. I've been job hunting for a while and I have a short notice interview tomorrow.
                                I should really move the server to the basement. My cat likes to hang out with me when I'm computing. I'd swear she sheds continuously.
                                I don't have the foggiest idea how stuff works at the electronics level on a system. Some day I'll probably take the time to learn what's going on at the trace level.
                                All of the critical drives are Linux software RAID 1 (mirrored). At least when I put the system together I could power down, pull a ribbon cable off of any drive and then power up and the system would work.
                                Anyway like I said if you like the system and it works well for your needs recap is the real best way to go for the MB
                                Assuming I can successfully recap the KG7-RAID, that's what it will become.
                                Maybe on you next computer fair hunt see if you can find a not too abused spare MB (thats just a thought and of course you would have to make sure its works ..then get it recapped)
                                is this the MB?
                                That's it. The Highpoint RAID is fairly worthless. Back to the test mentioned above, if I tried it with the Highpoint RAID instead of Linux software RAID, the Highpoint BIOS would detect the missing drive and then go to a screen that asked whether it should continue or not. No way to set it to continue by default or after some delay. So I used the Highpoint RAID as JBOD.
                                keep us posted
                                Cheers
                                Picked up a new MB (MSI K9N), CPU (Athlon 2X 5600+), RAM and video. I'm thinking I'll swap my old desktop (Tyan Tiger MPX with 2x Athlon 2400+ MPs) into the server role and use the new MB, etc. for my desktop. That minimizes my down time since I can pretty much just pull the drives out of the old server and stick them into the Tiger enclosure. I don't really need an SMP server since the old 1700+ could keep up but that's the easiest upgrade path. I'll play with the KG7 board "off line" when putzing with it for several days or weeks isn't a problem.
                                Cheers,
                                Dave
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  As to:
                                  >>> I should really move the server to the basement. My cat likes to hang out with me when I'm computing. I'd swear she sheds continuously <<<
                                  Passing thought.
                                  Shave the pussy for better cooling. ~ ~ ~ Ahem....
                                  Mann-Made Global Warming.
                                  - Dr Seuss
                                  • DaveAtFraud
                                    • Jan 2008
                                    • 13
                                    Originally posted by PCBONEZ
                                    As to:
                                    Passing thought.
                                    Not a good idea. She still has her claws and knows how to use them:
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Ouch!
                                      - Dr Seuss
                                      • bgavin
                                        • Jan 2007
                                        • 1355
                                        I run Alpha PAL8045 coolers on all my KG7 boards. This is the massive HSF that bolts through the board using the four holes around the CPU socket. I use Panaflo 12U series fans, and they never let me down. The temperature delta averages 11C on most of my machines.
                                        I've been installing Sparkle ATX-350PN supplies for these boards without a problem. This is the PSU with the 120mm fan. It is populated with TEAPO and OST caps in the larger capacities. I have not yet found a source for Rubycon ZL, so I have not bothered recapping any of the Sparkle yet. They run quite cool.
                                        I run a customized version of the DS bios on these machines. Mine sets the Safe and Performance mode defaults to values that work for me. When this board first came out, the advice was to change the SLEW from Auto to 7 (Max). I've been running all these boards this way for years, and they are all stable.
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • SDNarcia
                                          Dell 15R-5521 keyboard problem (KBC?)
                                          by SDNarcia
                                          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                          As additional information,...
                                          07-20-2024, 10:47 PM
