Dead Cap???
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    Dead Cap???
    Hello eveyone just wanted to ask if the cap direcly below the "JUSBLAN1" label is a dead cap. I noticed there is some kind of corrosion coming out but its now the usual venting we see on other caps. and take note its corrosion (dark brownish) instead of the "crap" (light brownish) that comes out of a venting cap.
    http://img524.*************/img524/3484/dsci0808pe0.jpg
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • Super Nade
    • Jun 2006
    • 294
    Re: Dead Cap???
    Are you talking about the one closest to the FET?
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Dead Cap???
      hard to tell by that pic.
      you could be seeing flux residue from the fet.
      more paste is used on those larger parts so more flux.
      cant identify the caps.
      • grss1982
        • Mar 2007
        • 225
        • Philippines
        Re: Dead Cap???
        The capacitor directly below the "JUSBLAN1" label.
        Anyways I don't know if this means anything but my mobo's sensors "-12v" entry is indicating something like "-64v"
        • starfury1
          • May 2006
          • 1256
          Re: Dead Cap???
          short answer, if it doubt replace (or at lest test it)
          it does look like something on the top of the can and possibly coming from under the sleeve
          or like KC8 has mentioned but it doesn't look like a popped can
          (bit hard to tell due to flash reflection)
          possibly the cap is OK I am thinking and just crap on the can.
          -64V no idea
          Yeah it may help knowing what brand type they are ?...
          if they are crap , as you know... rip them all out and replace them all regardless .
          Cheers
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Dead Cap???
            Some caps will leak dark brown.
            I have an inverter board here with leaky/vented Elite brand caps and the 'stuff' is very dark brown.
            Mann-Made Global Warming.
            - Dr Seuss
            • grss1982
              • Mar 2007
              • 225
              • Philippines
              Re: Dead Cap???
              replaced power supply with a know good one (a reliable HEC brand that has worked ok for me), and the -64v reading disappeared. :-) I'm qoing to observe it for a while. Actually I'm letting it run prime 95 and 3dmark2001se for about 1 week.
              • double_DD
                How can I be sure that my EC chip is dead?
                by double_DD
                As the title suggests, how can I be sure that my EC chip is really dead?
                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                03-12-2025, 07:47 AM
              • disorder
                ps5 edm-033 dead after hdmi/usb ports destroyed
                by disorder
                hello guys,
                i need help to repair a edm-033 ps2
                history : as always hdmi port and usb ports destroyed after unplugged
                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                so i changed it
                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                i don't see any projection of liquid metal on pcb.
                01-14-2025, 12:48 PM
              • zunasthegreat
                Chieftec GPS-450-AA with dead 20N60C3
                by zunasthegreat
                Hello everyone hope all doing well!
                I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                09-01-2024, 07:12 PM
              • Beton
                Finding a dead short component
                by Beton
                Hi guys!
                I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                I have a bench PSU and if I try to inject voltage the voltage...
                12-10-2021, 01:05 PM
              • FiguringITout
                MSI Raider GE75 - Not posting, probable dead CPU
                by FiguringITout
                Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                07-25-2024, 07:27 AM
