Recap Help with P3TDDR motherboard - bad cap ESRs seem okay???
  • themadcapper
    • Oct 2007
    • 7
    I'm looking to recap several SuperMicro P3TDDR motherboards, as the NSRY 1000uF 10V 105degC capacitors all seem to be going bad. Some are bulging, some appear to have slightly leaked. Now here's the big question. I checked all these seemingly bad caps with a Bob Parker ESR meter, and even the seemingly bad ones are showing 0.03 to 0.04 ohms or so. So, does this mean that they are really okay, or is it possible that they are failing once under the strain of heat, etc. Note that all these boards still post, boot, etc. They just intermittently reboot, and I can only seem to trace it back to this capacitor issue. The next thing is that I got a deal on a huge bag of QVS 1000uF 10V QZR 105degC capacitors to use as replacements. But, ironically, these caps seem to have an ESR of 0.08-0.10, nearly double the NSRY caps used.
    So, the question is, can the QVS caps be used to replace the NSRY caps, or is that ESR difference simply too much, and can all these seemingly bad caps still give good ESR readings on an unpowered motherboard at room temperature?
    I read all the FAQs and unless I missed it I couldn't find any direct references to this particular issue.
    Appreciate any help you all can offer! :-)
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Recap Help with P3TDDR motherboard - bad cap ESRs seem okay???
    never heard of those qvs caps.post a pic.they are probably not high quality low esr.
    i use panasonic fm 1500@6.3 on those boards.
    you are likely measuring several good ones in paralel with the bad ones.
    recapping has fixed every one of the p3t boards i have done.
    • starfury1
      • May 2006
      • 1256
      Assuming you measured them while in the pcb
      Now bear in mind, ESR for the sake of simplicity is like a resistor
      So if you have say a 10 ohm resistor in parallel with a 2 ohm resistor the total resistance would be still less then 2 ohms so you wont see the 10 ohm resistor.
      ditto the caps ESR
      so to be sure you need to remove and measure each one.
      As to if they fail under heat etc "yes"
      the ESR will go higher as it gets hotter (normally with good caps)
      so the lower the ESR the better
      (thats if I understand it right)
      since you say some are bulged etc ..they are history
      you should replace all caps in the VRM if you want max life out of them and it
      Since they are all still working "now" would be a good time to recap them
      As to those caps well if they measure cold, higher then the ones in there I wouldn't use them...go with the Panasonic FM as KC8 said
      (I think you would just be replacing trouble with more trouble but thats only my opinion not the guru here)
      VRM circuit is not really a place you want to try and cut any corners on I think
      I've never heard mention (that I recall) of those caps either.
      HTH cheers
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • themadcapper
        • Oct 2007
        • 7
        That definitely sounds like the case then - they do always tend to be grouped together. But, thinking about that.. wouldn't it be then nearly impossible to ever detect bad capacitors still on the motherboard due to that very issue? It seems like they'd have to be taken out regardless to accurately test them. Regarding the Panasonics, so you're saying it's okay to change them to the higher 1500uF at the low 6.3V instead? I did see something about that in one of the FAQs. Is there any advantage to using lower voltage/higher uF caps? Do they tend to last longer? Also, where do you generally order your caps for the best prices? I also included a picture from the bag of caps I got ahold of on ebay - there are 500 of these babies in the bag. It's ashame that it sounds likely I won't be able to use them though.
        Thank you both btw for your excellent advice!
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          i will have to hunt around for a datasheet on the q caps.
          i went to the 1500@6.3 due to unaceptable(to me) hash on vcore.
          highest voltage these 10v parts see on a mobo is 5v.
          vcore is1.4?
          • themadcapper
            • Oct 2007
            • 7
            Actually, the vcore's on these motherboards are 1.7 V. Also, what do you mean by the hash on vcore? Is that like the ripple current? Also, what kind of scope do you need to check those stats (ie Mghz, etc)? Would something like the osziFOX work (https://cdn.badcaps-static.com/pdfs/...ac761080af.pdf)?
            • gdement
              • Jan 2007
              • 690
              That is a problem, and this is why I think accuracy does matter with ESR meters. If you're measuring only 1 cap then a bad one will stick out with an obvoius, very bad reading. But since the important caps are always going to be in parallel, a bad bank of caps might still only show a moderate reading. And if any of the caps are still in good condition then the reading might look close to normal in circuit.
              For this reason, I'd be suspicious if the circuit's ESR is even slightly higher than normally expected. The Vcore circuit on most motherboards usually reads 0.01ohms on my meter, so if I found 0.03 at Vcore I'd be swapping them out.
              It can help to know which caps are in parallel with each other, as this gives you an idea of how low the ESR should be on that circuit.
              • starfury1
                • May 2006
                • 1256
                Well I'll let KC8 answer for himself on that,
                cause me don't really know, I think he means noise, ripple voltage, garbage at unacceptable level to him.
                (this maybe possibly caused by higher ESR)
                I really don't know enough to get into the detail of what causes what at what temp or current, frequency etc.
                Not in regard to what you have (with the caps) but generally speaking and my understanding is the reason you may find lesser quality caps fitted at 10 Volts is the ESR is less for a higher voltage caps, this allows them to use lower quality
                (read as cheaper) to run the VRM circuit with.
                This does not mean they will last as long as a good quality cap or have optimal performance for where they are used
                My guess is you are only or most likely only find low ESR quality caps at 6.3 volt (or 16V)
                Since the circuit will not require any more then this you can use them cause there voltage rating is not going to be exceeded.
                The whole thing can get quite complex and there are a few discussions threads on all of this.
                Kc8 by the sounds of it has done some investigative work on it and has given a recommendation of a cap that should be quite suitable to the task and from his experience works with the MB's (and works probably quite well)
                This is not saying what you got wont work and last for a period of time,
                just my personal thoughts are it wont last as long as the panasonic FM would
                BUT this really does depend on quality of the QVS cap I suppose.
                (but being spec @10V and Higher ESR doesn't sound good for this application)
                I cant seem to find data on them
                the only site I found with a logo similar
                Was QVS discount Electrical wholesale...no electrolytic capacitors listed
                (as far as I could find)
                http://www.qvsdirect.com/
                could find no PDF's specs either?
                so I dont know what they are or who actually made them.
                As to having to pull each cap...well yeah yes if you want to be sure
                (the above post is the theory of it)
                Normally the best way to test a component is to remove it from circuit.
                Here again if you find 2 or 3 popped etc, its really a must anyway to replace the lot
                (so you don't need to bother testing the caps just recap)
                Anyway the choice on caps is yours, and I can understand why your are considering the caps
                me personally would use the FM's
                There are better caps but bangs per buck they are good value
                heres the pdf link if you want to have a look Panasonic FM PDF
                HTH Cheers
                • starfury1
                  • May 2006
                  • 1256
                  ok I stand corrected the FM do have a 10 Volt in the pdf...
                  I think its RS components just has 6V3 16V listed for low ESR caps
                  more often then 10 V (if any?)
                  this maybe the case with a few suppliers I guess
                  • themadcapper
                    • Oct 2007
                    • 7
                    Here's an interesting update. I just took off one of the bad looking NSRY caps from the motherboard, and the ESR meter immediately showed around 1.5 ohms. Each time I would try again it would edge up and seemed to settle (for now) around 2.8 ohms - kind of weird, but definitely a bad cap! Now here's what's really odd. I compared again to the QVS caps I have. When I measure them right from the base of the capacitor (as opposed to from the ends of the wires) I'm actually showing an ESR as low as .04 to .05 ohms!! When I measure from the end of the cap's leads, I'm getting closer to .09 ohms or so. How does that make sense? Maybe I'm introducing some noise or something holding the leads to the meter probes. Strange, but either way whether it's .05 or .10, 2.6 ohms is definitely a far cry from a good cap!
                    On a separate issue, one thing I am still curious about is why they put the caps in parallel as opposed to using one bigger cap. Does that add some extra degree of reliability? It doesn't seem it would because in the end if one goes bad it's still screwing the rest of them. Maybe it's just so they don't need to stick one big one as opposed to a few little ones?
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      0,05ohm is not that bad, actually many even good quality PSU caps have esr as high as 0.068ohms per 1000uF.
                      Any way, in your case it is obviously a badcap problem ;-)
                      Adding caps in parallel is to lower the esr further.
                      And sure, it is probably a better approach then using very few ultra lowest esr caps which are in most cases not that durable then the other series.
                      Imagine those very high currents a modern VRM has to provide, e.g. 55A (sure, only for a very short time) for a soket A CPU and probably a little more for some Intel ones.
                      At such high currents, even a very low esr would cause a significant voltage drop and poor regulation.
                      • themadcapper
                        • Oct 2007
                        • 7
                        Just wanted to let you all know that I've now used the QVR caps to replace about 35 bad caps over three P3TDDR boards so far with great success (I've got about a dozen of these machines)! One of the boards just konked out yesterday... It wouldn't even post anymore. After the recapping, it's running beautifully again - hasn't even flinched! Some of the bad caps I pulled off were at 4 ohms or more, some that were starting to go bad may have been about .75 to 1 ohm or so. I don't know how great the quality of these new caps are, but they certainly seem to work for now! I got the technique down pretty well so I can chug along right through the process, so it wouldn't be a big deal to fix it again even if some start to go bad down the road (2 years + maybe?!) The important part is I now know the nemesis that's plagued me for a while with these - just in time! Amazing how these companies - even big "quality" server companies like SuperMicro - build in "planned obsolescence"! Luckily for us they decided to go cheap on the only parts of the motherboard that are relatively easy to replace!
                        Thanks again for all of your help! I'm going to be making an episode of our internet shows on this topic (www.vlogolution.com - youtube:vlogolution) - this forum will certainly be mentioned as a prime source of data on the topic...
                        • pc-mike
                          • Sep 2011
                          Hi themadcapper:
                          I don't know if you are still on this forum, but you mentioned you have several servers with Supermicro P3tDDR motherboards. If you ever do upgrade those machines, I have a customer who is running a (legacy) server that had that same P3tDDR motherboard and who would be interested in purchasing either a spare motherboard or a whole spare server with that motherboard in it. Let me know if you want to sell one. mschw@athenet.net
                          • Logistics
                            • Apr 2007
                            • 721
                            I know... FORUM NECROMANCY! But I run a P3TDEI and at the moment it has a 1.45 Vcore with the 1.26GHz-S Tualatins, and I noticed most of the CPU's in the PIII line, except for the Tualatins, depending on their speed, have different Vcores throughout. So I don't know where that 1.7V Vcore which was mentioned earlier came from.
                            I'm considering selling one of my P3TDEi 1U racks with dual Tualatin 1.26-S's, but I want to polymod my dual 1.4-S just for fun. I'll post a thread when I get to that.
                            Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Heh, me too. Only i'm running an ASUS CUV4X-DLS - i need that AGP slot so a server board was out of the question.
                              A working TV? How boring!
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                P3TDDE with a pair of 1.4GHz Tualatin-S's.....8x AGP. I didn't polymod it, just recapped the taicon lytics that it had, never had any trouble out of it.
                                <--- Badcaps.net Founder
                                Badcaps.net Services:
                                Motherboard Repair Services
                                http://folding.stanford.edu/
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  That there is a pretty nice board Topcat. Let me know if you have one for sale, as my Asus mobo has some issues with the USB, regardless whether i'm using the onboard ports or a VIA PCI USB 2.0 card, it corrupts large files. And it has nothing to do with the overclock running the PCI clock above spec, as it does the same thing at stock.
                                  Btw, does the Supermicro board support any overclock option? I guess not, but that's not a big deal as it can likely be hacked.
                                    ASUS P5GC-MX motherboard recap
                                    by momaka
                                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                    So here is what the motherboard looked like with its original caps:
                                    CPU VRM area up close…...
                                    01-27-2021, 11:59 PM
                                    no-name Radeon 9600 XT recap and cooler
                                    by momaka
                                    I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                    This one was actually suggested to me by ChaosLegionnaire....
                                    11-06-2020, 07:54 PM
                                  • varunviolin007
                                    Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                    by varunviolin007
                                    Hi guys,
                                    I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                    I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                    Looking for someone experienced with older PC boards who uses...
                                    07-29-2025, 11:53 PM
                                  • Foetuss
                                    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                    by Foetuss
                                    Hi all
                                    Hope this is in the correct place.
                                    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                    Could use some double checking to see if I'm not doing something stupid .
                                    Pictures of the boards are attached.
                                    What I will be replacing with what : (planned)
                                    Soltek Golden ::
                                    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                    01-18-2025, 11:44 AM
                                  • goodpsusearch
                                    Got 4 LG L222WS 22" for free - psu recap
                                    by goodpsusearch
                                    Got 4 CCFL 16/10 monitors for free.
                                    The resolution is almost Full HD (1680x1050)
                                    VGA Input only is a bummer though.
                                    Uses cheap TN panel with terrible viewing angles.
                                    Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                                    All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                                    01-15-2022, 05:36 PM
