Is the Panasonic FC suitable for this circuit?
  • Zeroexpo
    • Jun 2014
    • 14
    Hi Guys,
    I'm almost finished building a PLL Transmitter, but wanted to pose a question to the experts here before continuing with the build.
    I used Panasonic NHG general purpose Capacitors everywhere where Electrolytics needed to be fitted, but for C68, C69, and C70 in the area I'm pointing at with the pen, I'm thinking about using some Panasonic FC as these are the only Cap's I have left; I believe they're low ESR.
    I also plan on using one in parallel with the output of a 7805 regulator, as I believe low ESR are ideal for power supply applications - but I might be wrong. Can anyone confirm?
    So, are the FC series suitable in these parts of the circuit, or shall I just order some more NHG or alternative general purposes Cap's?
    What's the worst that can happen?
    Many thanks in advance.
  • brethin
    • Dec 2008
    • 1907
    Re: Is the Panasonic FC suitable for this circuit?
    The FC are better than the NHG so as long as the lower ESR isn't a issue in your circuit you should be fine. I see nothing that should be a issue with the lower ESR based on the provided schematic. Others may see something I don't so please get other opinions.
    • selldoor
      Slow Learner
      • 7870
      I think you will be ok with the FC they are not particularly low esr just better than a GP cap. Worst that can happen - you have to replace them later if someone comes up with a definite reason for not using them.
      If you can find a datasheet for the IC they are nearest to it may say on it that the caps should
      be or not be low esr.
      • Zeroexpo
        • Jun 2014
        • 14
        Thanks for the replies Guys.
        I've posted another image of the schematic, and although the quality of my camera phone isn't too good you can still make everything out.
        Again, the pen is pointing to the area in which I'm planning on using these low ESR Panasonic FC Cap's - and the IC's that they're mostly connected to are IC4 which is a 74ALS74, and IC5 which is a 74HC4059E; A CMOS flip flop and CMOS divide by counter respectively.
        The Capacitors are in close proximity to transistors, and one of them looks like it's sole purpose is for timing as it's connected between the base and emitter of TR13.
          Is there a place I can download the diagram/manual of what you posted?
          • Zeroexpo
            • Jun 2014
            • 14
            Hi mate,
            The documentation, schematic, and build instructions are here under "PLL Pro 3", the 4th link down (16MB) as far as I'm aware - http://www.gareth.net.nz/nrgdocs/
            There is actually a part kit available on eBay UK as we speak, and that's where I've bought mine from.
            If you have no success at the site above, just PM me and I'll send a scan of my build instructions, etc'.. via eMail.
              Thanks for the link, I just want to see how it works.
              • Zeroexpo
                • Jun 2014
                • 14
                I'm about to finish building my 2nd one, and have just commenced building a Pro IV latest version this evening - I'm about 50% into the build.
                These NRG kits have a good following in the Pirate Radio scene, albeit they're quite large.
                I was going to put one on air for an hour or two, but always bottle it - and instead use it into a dummy load as an "all house" transmitter.
                • Alimash
                  op amp circuit function?
                  by Alimash
                  I am repairing a ups which doesn't turn on ,it has the following ICs:
                  SG3525 used to drive inverter mosfets.
                  couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                  A LM358 and TL074 for control mechanism and of course the uController.
                  The SG3525 is shutting down every time the ups is turned on.
                  I want your help to know the function of LM358 and TL074 in the system.
                  I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                  07-31-2025, 07:45 AM
                • Astonished
                  Fixing the Charge Circuit of the Batteries of the DC Motor
                  by Astonished
                  Hi friends of electronics
                  What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                  The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                  Please help me fix this circuit.
                  (the datasheet of the IC: https://pdf.datasheet.live/28...
                  01-28-2025, 06:24 AM
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                  11-20-2024, 08:52 PM
                • rddube
                  Lenovo L490 Ram voltage circuit malfunction
                  by rddube
                  Hello friends,
                  Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                  I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                  07-15-2025, 04:41 PM
                • quickname
                  Cyberpower 1500AVR UPS repair
                  by quickname
                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                  Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                  I decided to verify that the batteries were...
                  11-12-2023, 09:57 AM
