Replacement smoothing cap for a 24V board.
  • Henke
    • Oct 2022
    • 41
    • Sweden
    Hello.
    I found a bad smoothing cap efter the 230-24V transformer. The specific one are mounted on the negative side of the diode after the transformer on the 24V side. It supplies +24vdc and -24vdc
    it's a 50V 22uF one. The closest I found at home is rated 100V, 39uF. Can I use that or what could fail?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Sure you can use that as replacement.
    • CapLeaker
      Leaking Member
      • 8303
      No problem with that replacement cap.
      • boosti45
        Macbook pro logic board replacement parts quesion
        by boosti45
        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
        08-21-2024, 05:23 AM
      • tuner2000i
        Philips 65PUS8518/12 distorted image after main board replacement
        by tuner2000i
        hello everyone,
        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
        07-15-2025, 01:15 PM
      • Cvrado
        Led TV Board Replacement, same part number and model, different size
        by Cvrado
        Hello my friends!
        I have a question that I think you can answer and help me with!
        I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
        So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
        My concern is that the board won't draw enough voltage to the bac...
        03-02-2024, 05:05 PM
      • eum
        PSU Board repair or replacement Ecler Nuo 2.0 DJ mixer
        by eum
        I try to repair this fly-back type PSU, I diagnosed (identifiable) dead N-MOS and fuse, but there are 3 smd resistors on the bottom that burned and became unreadable.
        The support in charge of the brand in France managed to get me the schematics from Ecler, but it didn't include the PSU board. After a while they finally told me that the unit was too old so they don't have the PSU board schems.
        I can find replacement PSU board online, but only for the Nuo 3 or 4 or 5, and it seems they ar compatible with each other, as I often find boards compatible with these...
        07-28-2023, 03:05 PM
