Replacement smoothing cap for a 24V board.
  • Henke
    • Oct 2022
    • 41
    • Sweden
    Hello.
    I found a bad smoothing cap efter the 230-24V transformer. The specific one are mounted on the negative side of the diode after the transformer on the 24V side. It supplies +24vdc and -24vdc
    it's a 50V 22uF one. The closest I found at home is rated 100V, 39uF. Can I use that or what could fail?
  • Per Hansson
    • Jul 2005
    • 5897
    • Sweden
    Sure you can use that as replacement.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8763
      No problem with that replacement cap.
