Yet another recapping question
  • Felayga_
    • Oct 2004
    Joy of joys when I pop open my computer one day to find 8 capacitors leaking on the top and 1 visibly bulging (all nine identical), obviously needing replacement. I've checked some of the stores in my area for exact replacement capacitors (1000uF, 6.3v required), and the closest I can find is 3300uF 6.3v capacitors.
    So, my question to you experienced-type peoples would be: would this cause any serious problems, replacing 1000uF with 3300uF?
    (sorry if this is a repost, but I couldn't find anyone asking questions about more than a 1200-1500uF gap)
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    that sounds like too big a step up.
    not to mention they are likely too big to fit.
    • Junkrepair
      Calculating ESR from tan delta -- tan delta's dependence on capacitance
      by Junkrepair
      I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
      I found this nice little description of the conversion:
      Calculating capacitor ESR from Tan(delta)
      https://forum.digikey.com/t/calculat...-from-tan/2633
      It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
      06-12-2023, 02:45 PM
    • ssl6
      MSI K7T266 Pro (Ver. 1.0)
      by ssl6
      Hey Everyone,
      Long time lurker, but I think this is my first time posting.
      Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
      I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
      11-09-2023, 01:00 PM
    • Oldschool297
      RELAND SUN 6.3v 3300uf Low or High ESR?
      by Oldschool297
      I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
      https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
      08-14-2023, 04:32 AM
    • proxneo
      Recapping Sony ICF-SW55 - verifying cap values
      by proxneo
      Dear reader
      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
      At the moment, I have selected replacements based on the following list of values:
      3 x 470uF 10VDC
      3 x 4.7uF 35VDC
      4 x 47uF 50VDC
      8 x 22uF 6.3 VDC
      1 x 220uF 6.3VDC
      5 x 100uF 6.3VDC
      Which...
      06-21-2023, 12:38 AM
    • Uy181
      Capacitor Replacement: Advice Needed
      by Uy181
      So I have a couple motherboards I am recapping that I do not have capacitor replacements already in my used inventory. I am wondering which capacitors that are currently in production for 2022 that I can use to replace the following capacitors:
      "SAM YOUNG" NXC series 6.3v 3300uf
      "Nichicon" HM series 6.3v 1000uf
      "Nichicon" HM series 6.3v 3300uf
      "United Chemi-Con" KZG series 6.3v 820uf
      "TK" ATWY series 6.3v 820uf
      Thanks!
      05-28-2022, 04:36 PM
