Ceramic cap lable weird??
  • Helping Friendly
    • May 2014
    • 5
    So I can't figure out the value of this cap? Here's what it says:
    Mexico
    52L
    30K
    1KV
    I think its 10, 20, or 30 pf. Not sure though
    Any help would be forever grateful! Thanks
    • 31058
    Re: Ceramic cap lable weird??
    it's obviously 1000v
    the 30k may be a stability figure.
    52L is a challenge.
    maybe 500pf
    got a foto for size?
    • capkid
      • Oct 2010
      • 1339
      30pf would be my thought, also. I believe the 52L is ignored. It could be some sort of manufacturer marking.
      LG Plasma Mal-Discharge Correction Service
        Can we see the pictures and also show us where in the circuit it is being used at?
        • Helping Friendly
          • May 2014
          • 5
          will do pic when I get home form work. It is sort of a brightness cap in a guitar amp. Its a small ceramic cap "normally" 10pf or 20pf but can vary from amp to amp. Mine seems on the dark side but I wouldn't know the difference cause this is the first amp I have owned of this particular model. (Mesa Boogie Mark 3) Hmm....
            Diagram, a little hard to read.
            • Helping Friendly
              • May 2014
              • 5
              SO I figured out it says S2L and not 52L
              30K
              1kV
              so most likely a 30pf huh?
              • capkid
                • Oct 2010
                • 1339
                I'm fairly certain it's 30pF. The K is the tolerance (10%).
                Hopefully, this info is accurate: http://m.wikihow.com/Read-Capacitor
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  • USA, Unsure of Planet
                  I believe S2L is the temperature coefficient (see page 2).
                  PeteS in CA
                    Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook Specification for Upgrade or Repair
                    This specification for the Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPANISH MEXICO HDWR COMMERCIAL PLAT boardview and SPANISH MEXICO HDWR COMMERCIAL PLAT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                    09-07-2024, 12:40 AM
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
                  • chth96
                    by chth96
                    03-09-2024, 10:03 PM
                  • Loki_Fido
                    (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                    by Loki_Fido
                    Hi folks,
                    This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                    I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                    BIOS - XMC 25RU128CH10 (1.8v)
                    What the heck is this? I looked all over the MB. This is the only bios.
                    When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                    03-20-2025, 01:57 AM
                    APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                    This started a few days ago and does this about every 8 hours
                    After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                    The battery backup is about 3 or 4 years old
                    Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                    06-02-2024, 02:30 AM
