unknown 462 mobo with many popped sanyos!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    had a pos psu but no bad caps in it.
    nearly every sanyo on this board is blown.
  • gg1978
    • Dec 2004
    • 431
    Re: unknown 462 mobo with many popped sanyos!
    Wow, never seen a blown Sanyo, let alone more than one.. Are they marked as Sanyo WG's??? You might have had a CPU overheat condition there, looks like the caps closest to the CPU suffered the most.. I've got a KT7 with some blown Nichicon HD's on the VRM input side, and it was obviously overheated as the board actually changed color in the VRM section to a darker shade of orange. Of course the CPU survived somehow..
    • Rainbow
      • Aug 2005
      • 1375
      Maybe someone tried to do a fanless system?
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        btw this is a transcend board.
        it had good airflow.
        i bet the "gutless wonder" AN psu was to blame here.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          the psu may have contributed to the failure but caps blowing their bung out is an indication of bad manufacture / poor raw materials. do they look like fakes?
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • AdrenalinTL
            Macbook Pro A1707 - Dead - Battery 'popped'
            by AdrenalinTL
            Hi Peeps.
            Just a quick question please as I am by no means an Apple fundi at all.
            Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
            Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
            Don't want to go buy a battery for no reason.
            Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
            07-18-2024, 09:52 AM
          • Stachujones
            Dell XPS 13 9370 unknown USB devices in device manager
            by Stachujones
            Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
            Device manager says "unknown device, failed to request device descriptor"
            Can somebody point me in right direction what to check?
            I updated bios to the newest version and thunderbolt controller firmware still no luck
            04-05-2025, 07:35 AM
          • jake-b
            dell e6540 boots to black screen (no dell logo)
            by jake-b
            good morning all,
            i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
            01-08-2024, 10:29 AM
          • Cerberuska
            Mobo MSI B550-A PRO password popup
            by Cerberuska
            Hello guys,
            I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
            BIOS I updated to last one.
            any suggestions?
            And same thing for two different 5600G, and yes, MoBo supposed to support it.
            Thank you...
            11-10-2024, 01:23 PM
