memory test fail -bad capacitor
  • srt1
    • Aug 2013
    • 177
    • india
    i have motherboard asus make. it have problem in bios post it showing memory test fail. and press F1 to continue. so i checked for bad cpacitor i saw some 3 bulged cap.and replaced with new one. but stil same problem. it didnt fix memory error. then i changed all capacitor on motherboard that have no sign of bulging.. but problem still have . am sure it is not because of bad memory bcz i tried many memory stick that working on other motherboard also i chnged psu ,.. no success.. what could be the reason for memory fail?. i am pretty sure not bcz of memory slot.. out 5 memory stick 3 are worked without error and only 2 have problm but the same 2 sticks working on other mother board perfectly
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: memory test fail -bad capacitor
    Try cleaning the contacts on the memory slots as well as the memory module itself...
    • srt1
      • Aug 2013
      • 177
      • india
      i tried cleaning slot but stil same problem... i have 5 memoery sticks i tried every one only 2 have problm,, but same 2 sticks perfectly working on other two motherboards .. the asus motherboard hv two memory slots i tried cleaning the two .. but no success
      • Sparkey55
        • Jan 2010
        • 1523
        In order to be more able to help you we need more basic information.
        What model of ASUS motherboard is it?
        What are the brand and series of the bulged caps?
        What did you replace them with and where did you get them?
        Please post some good quality pics.
        • srt1
          • Aug 2013
          • 177
          • india
          i replaced all capacitor except 100uf 16 volt. some of 100uf 16volt i removed and checked its value is good. so i guess all remaining may be good.capaciotrs i used in this motherboard are YAGEO,G-LUXON AND CAPXON all are 105c . the motherboard is compaq bd-70g.. i think its asus make. here the some pics
          http://s11.postimg.org/xlt0bl3o3/201..._52_20_906.jpg
          http://s24.postimg.org/ulfscfl3p/52_11_97.jpg
          http://s9.postimg.org/hfru1e0kv/2013..._04_38_239.jpg
          http://s8.postimg.org/bbip74p6d/2013..._52_03_234.jpg bulged capaciotrs teapo 1000uf 6.3volt i replaced all with 1000 uf 10volt g luxon . Nichicon 3300uf 6.3volt are no sign of bulging but i measured its value it was very low.. So i replace all 3300uf with yageo 3300uf 6.3 volt. .can u someone help me to solve my issue? Is it capacitor related or northbridge chip bad?
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            start by posting some pics and using proper caps.i doubt the ones you used are up to the task and might even be worse than the ones you took out.
            • srt1
              • Aug 2013
              • 177
              • india
              I used capaciotrs are Yageo 3300uf 6.3volt ,g luxon 1000uf 10volt,and capxon 1500uf 10volt. Which brand is bad ?
              • Sparkey55
                • Jan 2010
                • 1523
                All of them.
                • larrymoencurly
                  • Oct 2004
                  • 960
                  New or used? Because I would think that brand new ones, regardless of brand, would work OK, if they have the right specifications for capacitance, voltage, ripple current, and ESR. I'm not familiar with Yageo, but I've had G-Luxon caps fail in 2 years. CapXon has a really bad reputation, and some bloated on me in 4 years in a couple of my lightly used Antec Basiq power supplies.
                  I've seen memory work perfectly in some motherboards but not others. What memory modules do you have? Anything with a heatsink on it or whose memory chips don't have clearly legible brand markings of a real chip company (Micron, Samsung, Hynix, Nanya, etc.) is suspicious.
                  • srt1
                    • Aug 2013
                    • 177
                    • india
                    All r new . I checked its uf it is ok.. But i dont know its ESR . All r 105c. Memory module dont have heat sink. The brands are hynix samsung winbond micro max and corasair. I have samsung 512mb two stick out of 2 1 have no problem at all.i test woth memtest also. but other one have problem giving error.but the same one no errors on other motherboards. also have two hynix. thy are 256 mb. out of 2 one have errors on this motherboard.
                    • lexwalker
                      • Feb 2011
                      • 307
                      • Malaysia
                      Are you using Memtest86+ to check for bad memory chips? Sometimes if the contact cleaner does not work, then use a flat heat screwdriver and scrape the contacts on the DIMM slot.
                      Not familiar with Yageo, but G-Luxon and CapXon are really bad choices as they are infamous for badcap problems. For your information, Teapo and G-Luxon are practically the same company.
                      Being 105C does not mean they are suitable. Do you know that there are also 105C general purpose capacitors? Thus always check the capacitor specifications first. Usually for motherboards, use 105C ultra low impedance/ESR capacitors.
                      • larrymoencurly
                        • Oct 2004
                        • 960
                        How warm do the new caps get, compared to good caps on other motherboards? Because maybe that could indicate if the ESR is much higher than it should be, unless the capacitors are conducting heat through the circuit board (I've seen that with capacitors located next to north bridge chips and voltage regulator transistors or chips).
                        I'm not familiar with MicroMax, but I've had many problems with Corsair, none with those other brands. Can you test more extensively in motherboards where all the memory apparently works OK? Also try other diagnostics, like MemTest86 version 3.xx (instead of MemTest86+) and Gold Memory version 5.04 (harder to find than version 6.92, but the free version of 6.92 does fewer tests than the free version of 5.04). Sometimes one diagnostic finds errors that others can't detect, and it may take a long time, like 12 hours. I would say if Gold Memory and MemTest86 find no errors when each diagnostic is run for at least 12 hours and the memory is run in dual channel mode, then the memory is OK, and the problem is with this Compaq/Asus motherboard. It's possible that Compaq released a BIOS upgrade to improve memory compatibility, but don't flash the BIOS except while running the 100% good memory.
                        • Sparkey55
                          • Jan 2010
                          • 1523
                          In your first pic I see what could be a problem. Make shure that you have a shorting cap on pins 1 and 2 of JP2, normal cmos operation. That pic does not show any jumper on it.
                          • srt1
                            • Aug 2013
                            • 177
                            • india
                            [QUOTE=lexwalker;365787]Are you using Memtest86+ to check for bad memory chips? Sometimes if the contact cleaner does not work, then use a flat heat screwdriver and scrape the contacts on the DIMM slot.
                            Wen post strating it also showing error in bios - memory test fail..
                            • srt1
                              • Aug 2013
                              • 177
                              • india
                              Being 105C does not mean they are suitable. Do you know that there are also 105C general purpose capacitors? Thus always check the capacitor specifications first. Usually for motherboards, use 105C ultra low impedance/ESR capacitors. [/QUOTE]
                              I checked its specification as per thier series.. Its saying all r low esr and high ripple current suitable for motherboard. The yageo capacitors i used in vrm section ,i checked its specification in data sheet its clearly mention ther suitable for output of vrms in motherboards. So i think capacitors are good suitable for motherboard even if it bad brands. Butnithink its nt a cause for this memory fail bcz all r new
                              • srt1
                                • Aug 2013
                                • 177
                                • india
                                Yes i shorted and tried but stil same problem
                                • srt1
                                  • Aug 2013
                                  • 177
                                  • india
                                  I'm not familiar with MicroMax, but I've had many problems with Corsair, none with those other brands. Can you test more extensively in motherboards where all the memory apparently works OK? Also try other diagnostics, like MemTest86 version 3.xx (instead of MemTest86+) and Gold Memory version 5.04 (harder to find than version 6.92, but the free version of 6.92 does fewer tests than the free version of 5.04). Sometimes one diagnostic finds errors that others can't detect, and it may take a long time, like 12 hours. I would say if Gold Memory and MemTest86 find no errors when each diagnostic is run for at least 12 hours and the memory is run in dual channel mode, then the memory is OK, and the problem is with this Compaq/Asus motherboard. It's possible that Compaq released a BIOS upgrade to improve memory compatibility, but don't flash the BIOS except while running the 100% good memory.[/QUOTE]
                                  The memory modules all r good bcz these memory i am currently using in my current pc almost 4 years. Stil its not give any crash or freeze also i have two spare motherboards i used same on it .dont have any problem on it . The 256mb giving error in bios and in memtes also.in memtest it giving error with in one minute.. The 512mb some times cause not posting also. But same memorys r perfectly working on other mother boards
                                  • Sparkey55
                                    • Jan 2010
                                    • 1523
                                    Pull the battery to clear the bios. Make shure that the cmos battery reads at least 2.8 volts. Go into the bios settings and select the default safe setup. Restart and then run memtest again. Also that board may require low density memory modules, needs to be checked.
                                    • Sparkey55
                                      • Jan 2010
                                      • 1523
                                      Is the 512 mb stick DDR or something else. If single sided could be High Density ram.
                                      • srt1
                                        • Aug 2013
                                        • 177
                                        • india
                                        I measured it voltage is 2.96 . I removed and cleard cmos and loaded default safe in bios .but stil same problem. I heave 2 256mb ram hynix brand both are same chip number 4 chips in one module so i asume 64mb each chip .the difference in two module r one have more number of smt camacitors and resistors on it. It not not giving any error .but othr one less number of smt components.this module giving error.
                                          Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:21 AM
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                        • chth96
                                          How can I test non-polarized capacitor?
                                          by chth96
                                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                          06-02-2024, 07:31 PM
                                        • ktmmotocross
                                          laptop onboard memory test and identify bad chip
                                          by ktmmotocross
                                          Hello.
                                          Know somebody how to successfuly test bad onboard memory and maybe even bad chip localization?
                                          Have newer asus that show memory related BSOD. After reball still the same. how to test if it is some ram chip or maybe bad ball under cpu or even cpu
                                          07-16-2024, 05:33 AM
