remember the nrsy fakes?check this out!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    http://cgi.ebay.com/1000uF-16V-55-10...QQcmdZViewItem
  • linuxguru
    • Apr 2005
    • 1564
    Re: remember the nrsy fakes?check this out!
    Probably Nicon - they don't claim that it's UCC NRSY. Some of the other equipment being auctioned off (resistive loads, etc.) suggests that it is an industrial PSU manufacturer being liquidated.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      The NRSY I have come across (which admittedly isn't many) have had a series number on the cap in addition to the NRSY logo.
      - That means on those NRSY is the *BRAND*.
      For the NIC caps with NRSY on them NRSY is the *SERIES*.
      It's not about fakes..
      It's a crap brand that happens to use the same letters as a NIC series.
      Interesting that the -series- on the NRSY -brand- caps match the series name of some Jackon's.
      - Perhaps Jackon OEM's for NRSY (brand) ???
      Mann-Made Global Warming.
      - Dr Seuss
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • jlafaye
        Zotac RTX 3070 Ti Trinity no power
        by jlafaye
        I am trying to troubleshoot & repair a Zotax RTX 3070 Ti Trinity for which I was not able to find schematics nor board view.
        The card came up with no apparent short circuit but was missing some voltages; unfortunately I cannot remember which ones as it was two weeks ago. While probing I accidentally shorted 2 pins of an IC (cannot remember which one either) and burnt GS9238 which I understand to be a 5V power supply.
        I replaced this GS9238 but unfortunately I am not able to get back the 5V.
        Checked the soldering twice, even tried another...
        03-16-2025, 10:47 AM
      • soopacrucial
        Samsung Syncmaster 740BF repair
        by soopacrucial
        Hi folks,
        I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
        Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
        10-29-2024, 02:40 PM
        Sacon FZ revival experiment
        by momaka
        So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
        https://www.badcaps.net/forum/showpo...&postcount=548
        … and here:
        https://www.badcaps.net/forum/showpo...&postcount=585
        … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
        The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?...
        01-26-2022, 08:43 PM
      • VaporGame
        UE40D5000 no display or reaction to either remote or touch
        by VaporGame
        I recently pulled out my tv from the attic that I remember bricking as a child with the service menu. I remember at the time it came on but didn't react to anything. I have tried a factory reset from the remote and a EEPROM reset but neither worked. I get no led light.
        Here are the things i already tried and did:
        • Checked the power supply (There was a burnt transistor but looking online its a common issue and its not crucial for the tv to run)
        • confirmed the power supply outputs the correct voltages
        • many remote button combinations
        • confirmed the backlight works (lights up when motherboard
        08-29-2024, 11:14 AM
