Hi forum members i'm new to this motherboard capping thing. 5 days back my pc started showing unusually high temperatures in the cpu vcore ,hdd and other components some thing like cpu=72 c, HDD= 65 c etc and i started getting really worried then the next the the computer totally started giving weird errors like blu screen and hangin and shutting etc untill 2 hrs later it stopped even booting... i used the pc anyliser (ordered from ebay 6months ago) and it atleast give me an idea that the cpu is fine the i checked the other parts one by one till i came to conclusion that the board was the culprit. then the next day a friend ofmine came to fix his pc to my place i made his pc and connected online to check for solutions of what could be the problem. after nearly half a day of searching i landed on badcaps forum and read that capacitors regulate voltage(and symptoms of bad ones were the same as mine..) so i checked board again and found 15/16 capacitors were bulging and of those 6 were in critical condition i.e. blown from the bottom..... that evening i went to nearly all the electric shops but could, get the required capacitor i.e. 820uf 6.3volt 105 c the closest i could get was a capacitor with A -->(1st issue =A=?? what brand...??? even shopkeeper doesnt know...)written on the top 1000uf and 6.3volts 85c-->(this is the second issue the 85 c instead of 105c ) which is worrying me i replaced all the caps with these ones and started up the pc and it booted and is working but i didnt use pc for more than 15 mins as i thought i'd ask here for advise as what to do
1. 1000uf 6.3v 85c--(is the only cap available in my area)
2. online ordering---(didnt find a site in india to order from as order from out is to expensive cause at that rate i'd get a new board)
3. i used these and i want to know that how long it might work till i get the rated ones from one of the metro politian cities)....
please advise as i didnt turn on my pc yet and still using my friends PC...
(OK, just kidding. It's Toshin Kogyo). They are one of the most unreliable brands I know of.
