can you help me where I can buy this cap?
  • manotari
    • Mar 2013
    • España
    Hi everyone. I'm new here and really glad to find this forum. I'm wondering if anyone can help identify this cap for me.
    Is of VGA, the MATRIX 7970, with the problem that the computer stops dead.
    I think it's the cap, as it was mounted upside down, as you can see in the picture (PCE 101).
    I put the link in the forum, where the photos
    http://foro.noticias3d.com/vbulletin...=409006&page=3
    Can anyone tell me where to buy it?
    FP10K
    26BZ
    271
    16
    Sorry for my English and thanks.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: can you help me where I can buy this cap?
    Its a 270uf 16v cap but cant tell from the pic how it is mounted can you post a close up pic using manage attachments.
    Could be one of these
    http://es.rs-online.com/web/c/?sra=o...0+uf&x=32&y=11
    Are you sure its upside down - it would not have worked from new
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Manotari, no need to apologize for your use of English. I've seen and heard worse from Americans (including myself when I make a lot of typos)! The "26BZ" is probably a date code, factory code, or both. The "FP" could mean it's a Fujitsu polymer cap.
      PeteS in CA
      • manotari
        • Mar 2013
        • España
        This is the photo of the capacitor appears backwards
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Yes it does look to be upside down - the cap you want looks like the top one in the link I gave you. You should check the physical size to make sure it will fit.
          • manotari
            • Mar 2013
            • España
            thanks for your help
            • Kanny
              • Mar 2021
              • Россия
              Good afternoon, help me find FP10K 81Cz 561 6.3, ASUS HERO XI motherboard. I would like to find the original, not the analogue. Or something more "powerful".
                • 31287
                it's just a 560uf 6.3v polymer.
                see what brands you can buy in your country - NOT on ebay or ali-express.
                • Kanny
                  • Mar 2021
                  • Россия
                  Are the frequency characteristics the same for everyone?
                    • 31287
                    the only variance is ESR and ripple handling.
                    ESR - lower is better
                    ripple-handling - higher is better
                    • Kanny
                      • Mar 2021
                      • Россия
                      https://www2.mouser.com/ProductDetai...y3PA3nwDWRJQ==
                      Is this its full counterpart?
                        • 31287
                        it will probably be fine - but make sure the diameter and the spacing between the wires is a match or it wont fit the board.
                        i know nichicon has several pitch options on their caps.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5045
                          • US
                          Re: Identifying a capacitor: FP10K
                          caps aren't more 'powerful' per se. You can improve the filtering by finding one with a higher ripple current. It's a functional polymer. Probably 820uf, 6.3v. Just guessing
                            master hoarder
                            • May 2008
                            • 12175
                            Re: Need help identifying polymer capacitor on motherboard
                            Check the link in this post by Dicky69:
                            https://www.badcaps.net/forum/showpo...90&postcount=3
                            Should be for a bunch of United Chemicon PSE polymer caps, which are known good brand and equivalent to the FP10K's, which I think are Nichicon (formerly Fujitsu) FunctionalPolymer caps.
                              master hoarder
                              • May 2008
                              • 12175
                              Yup, FP = Funtional Polymer
                              561 = 560 uF
                              6.3 = 6.3V
                              I already replied to him in another thread, but just going to link it again, in case it's missed:
                              https://www.badcaps.net/forum/showpo...3&postcount=14
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                Moderation note: merged and deleted several posts by Kanny across the board.
                                Kanny: if you cross-post again like that your account will be banned!
                                  Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
                                  Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
                                  I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
                                  09-13-2024, 06:47 AM
                                • jimbofz
                                  upside down pics when posting?
                                  by jimbofz
                                  Hi everybody just wondered why when i post pics they end up upside down?
                                  i also tried rotating them so they were upside down when i posted them and they were still upside down confused?
                                  12-24-2021, 03:15 AM
                                • StardustTinker
                                  Advice for transplanting surface mounted capacitors between laptop boards?
                                  by StardustTinker
                                  I am attempting to repair a Dell Latitude E6440 laptop that was damaged when an end user shoved something into a USB port so hard that it destroyed the port and sheared off a surface mounted capacitor located behind the USB port; effectively preventing the laptop from powering up.
                                  The capacitor is round approx. 5mm diameter by 5mm height with a plastic 'foot' and two small soldered pads visible (can't recall the specs printed on the top).
                                  In order to repair it, I'm thinking of replacing the capacitor by transplanting a similarly marked capacitor from a donor board taken from...
                                  11-15-2022, 12:05 PM
                                • France_53
                                  Vestel tv, how to flip the image?
                                  by France_53
                                  Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                  05-12-2024, 05:22 AM
                                • waigy
                                  Variable resistor potentiometer has different reading when mounted on the board
                                  by waigy
                                  In my fusion FE-402 car amplifier the gain pot is an RK097G.
                                  I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
                                  The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
                                  I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
                                  I then took the pot out the board and it now measured 22k.
                                  I tried putting it back in the board and it goes back to 10k.
                                  Is this normal and if so what pot should I order?
                                  On this...
                                  11-12-2024, 04:44 AM
