upside down pics when posting?
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Hi everybody just wondered why when i post pics they end up upside down?
    i also tried rotating them so they were upside down when i posted them and they were still upside down confused?
  • jasonbay13
    Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
    by jasonbay13
    it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
    PU200
    pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
    pin 8 vreg3 = 0v
    pin 13 en = .2v
    pin 1,6 entrip1,2 = 0v
    b+ and b++ = 19.5v
    +5valw = 0v & 25+ohm to ground
    +3valwp = 0v & 25+ohm to ground
    i cleaned the board up just a little and can get more pics.​
    where should i be looking? thx...
    09-25-2025, 10:54 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • AJ847.63e
    HP Spectre x360 -DA0X36MBAE0 wont turn on after battery change - Chip identification required
    by AJ847.63e
    i all,
    Cab anyone identify this chip? Pics attached. It's marked L8=6E 74L.
    History: laptop came from a e-cycler. Dropped off a few laptops wanting to get rid of them so he asked if we wanted them, apparently he tried swapping the battery on this one and acidentally broke the tip of the battery connector and plugged the battery in upside down.
    All readings on the battery pin seem normal though (comparing to a working same model board).
    Connecting the charger you can see the above mentioned chip pulsing so it looks like its going into protection mode, but checking...
    02-13-2025, 11:32 PM
  • playit
    ccfl lcd laptop repair help, pics attached
    by playit
    this lcd first started showing green lines horizontal ,with flickrs then one day stopped showing rest of the screen , now it just like in the pic , i can see mouse at top,also the icons at right end of screen , i also tried to look around the cable wires ,adn loosened it ,but its the same result . i tried the flex test , the monitor changes to white ,and different colours, but dint show the actual picture , external monitor vga connection is good, so please guide me what next to do . please verify the pics, thank you ....
    03-15-2023, 05:08 AM
  • SluggerB
    Help with trying to fix phone that is not charging (Pics inside)
    by SluggerB
    I have two TCL A30 phones.
    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
    New Phone: Works fine, bought as a donor board to try and repair Old Phone
    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
    08-12-2024, 08:11 AM
