Variable resistor potentiometer has different reading when mounted on the board
  • waigy
    • Nov 2009
    • 93
    In my fusion FE-402 car amplifier the gain pot is an RK097G.
    I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
    The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
    I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
    I then took the pot out the board and it now measured 22k.
    I tried putting it back in the board and it goes back to 10k.
    Is this normal and if so what pot should I order?
    On this amazon page it is available as a 20k and 10k.
    https://www.amazon.co.uk/RELAND-SUN-...0B15MS2MZ?th=1
  • truclacicr
    • Apr 2019
    • 356
    • australia
    Your pot is 20K. When it is installed in the circuit, there would be other components connected to the same points, and these would reduce the measured resistance. I expect that when the pot is removed you will measure 20K on the PCB. When you parallel the circuit's 20K with the pot's 20K, you get a combined resistance of 10K.
    • waigy
      • Nov 2009
      • 93
      Ok thanks
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        Need help to replace burned resistor in 350w atx psu
        by mikey5791
        Hi to all forum members,
        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
      • flat-earther
        Hoover FM216LI cordless vacuum refuses to charge
        by flat-earther
        I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
        I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
        5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
        So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
        06-06-2025, 03:14 AM
