How to not recap :)
+ More Options
Posts
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    How to not recap :)
    I find this image in guide about "what to do" when huge heatsink blocking the way:
    LOL - a GSC crap! And on such long lines, damn, I won't recommend such long lines to anyone, but by all means - have fun
    Anyone did that on overclocked machine and did not lost overclocking potential?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • VILE DISRUPTION
    • Jun 2006
    • 47
    Re: How to not recap
    Shit. That is suicide. GSC. Who did this? Wait, i dont want to know.
    Stats Reset Every Month.
    My Forums
    • tazwegion
      • Jun 2006
      • 444
      If you look at the extreme lower left of the picture... you can just make out yet another GSC, suffice to say the board is most likely heavily populated by same
      Simple... a GSC fanboi!
      * shakes head *
      Viva LA Retro!
      • Super Nade
        • Jun 2006
        • 294
        Why in the world would you want such ΓΌberlong leads?
        Q6700 @ 3.6 GHz
        Zippy GSM-6600P
        Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
        Abit IP35Pro
        ATi HD4870
        • gonzo0815
          • Feb 2006
          • 1600
          For the very reason they stated: to allow bigger HSF and solve clearance problems. As long as the rig is working why not. Shure, i would also prefere shorter wires, as i and most readers here are aware of the problems this may cause. This is not intended as an recap.
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • Syseng
            Lenovo P14s Gen 5 SVP unlock
            by Syseng
            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
            06-22-2025, 07:44 AM
          • jeyoung12
            Samsung QN50Q60t lines on screen
            by jeyoung12
            Hi all
            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
            So....i don't know what end of the C ribbon to work with...
            02-26-2024, 10:38 AM
          • Rubenlily
            Samsung QE50Q67TAU - horizontal lines
            by Rubenlily
            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
            I'm no expert but I've done the tape...
            08-16-2023, 01:12 PM
