Weird Yellow Caps
  • PedroDaGr8
    • Oct 2006
    • 130
    Weird Yellow Caps
    I have to replace some caps on an old HP AMD computer (old socket 462). Two of them are GSC (big suprise there ) 10V 1000uF's. The others I can not find a logo on them anywhere. They seem to have a very very very subtle bulge (could be manufacturing defect even it is so subtle) but I don't trust them because they are in the main VRM, which is in a riser PCB off the board LOL. They are bright yellow with black markings on them (arrows with o's in them). 4 of them are 6.3v 680uF and 2 are 4v 820uF. Which seems odd to me, because they are all the same size. I tried to take a picture but they all came out blurry. Any recommendations on caps would be great. The computer serves as a terminal in my fathers dental office for the dental assistants to look up digital x-rays, schedules etc. so it needs to be as stable as can be, but it will not be taxed extra hard.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Weird Yellow Caps
    from the values you gave they must be these fujitsu
    https://www.badcaps.net/forum/showthread.php?t=597
    • PedroDaGr8
      • Oct 2006
      • 130
      yep those are it. Odd I searched for yellow black capacitors and that thread never came up. Hmm. Now it is time to figure out what I want to replace them with.
      • Big Pope
        Approved Vendor
        • Dec 2005
        • 426
        Suggest better to recap with reliable 1500uF 6.3v Ultra Low ESR E-Caps, instead of these old yellow Fujitsu polymers.
        My SAMXON Capacitors Database HERE!!
        X-CON is a new brand for SAMXON's Polymer Capacitors.
        • Newbie2
          • Sep 2005
          • 885
          I know Big Pope going to suggest "SAMXON"
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • Big Pope
            Approved Vendor
            • Dec 2005
            • 426
            I think you should misunderstanding my meaning, I am not suggest "SAMXON", i just suggest to use with ultra low ESR caps. Rubycpn MCZ and UCC KZJ are also recommand, i am never hard sell "SAMXON". But, if anyone want to try, welcome. More choices must better for consumers.
            • trodas
              • Jan 2006
              • 770
              • Czech republic
              I would go with Samxons, but that is just me and my very good experience with them.
              Ruby MCZ could be interesting to try, but hard to source - at least for me impossible...
              Oh the other hand, Samxons GC offer par-to-par specs with impossible to source MCZ Rubys and the GA Samxons are even far better that this, so the only one question remain - if the GA aren't too good for the old 8RDA+ design - it may or may not cause ringing and oscilations witch increase the overheating and decrease the overclockability by increasing ripple...
              GC would be a smart choice there, GD for the small ones and RS Samxons for the little caps witch could bring big problems when not changed too
              "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
              "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
              • tazwegion
                • Jun 2006
                • 444
                As have many forum members, depending on where you are Rubycon, Panasonics etc. might be easily sourced also
                Viva LA Retro!
                • 2ntense
                  • Oct 2006
                  Found this forum searching for cap info.
                  I have a xbox360 and the yellow/black 4v 820uf behind the left controller port seems to have a "ball bearing loose" sound. Is this possible? Only asking cause the 360 finally took a crap on me and I'm trying to fix it. Thought maybe it was just overheating but now I don't know.
                  Bryan
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Can you provide some pics? and what exactly do you mean with "ball bearing loose"? does it generate noise? I would be somhow suprised if MS haven`t forced his OEM`s to use some minimum quality. What exatly is going wrong with the box? The more details you give, the better the advice you may get. In generall it is possible that some parts are starting to emit a hizz if things are getting worse. But usually the coils are more prone for that kind of anoyance, but singing caps are common too.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      isnt there a coil next to the cap. that will be making a hissing noise.
                      • gg1978
                        • Dec 2004
                        • 431
                        Bryan
                        That's the position sensor that tells the xbox if its sitting down flat or up on edge, so it can adjust the 4 quadrants of the "Ring of Light" to reflect current controller ID related to the screen in multiplayer games.
                        It's fine.....
                        • trodas
                          • Jan 2006
                          • 770
                          • Czech republic
                          willawake -
                          True, but I do remember that prior to explosing of my caps I heard this noise too. Usualy hi-pitched one, but it depends on circuit.
                          To tell long story short - the excessive riple of dying cap could and does make the coil resonate
                          2ntense - please provide detailed picture and read type of the cap/what is writen on it? Witch company made it? It is bulging? Smelling?
                          • 2ntense
                            • Oct 2006
                            I'll post pics soon. "ball bearing loose" means, remember that game you hold with all the little steel balls and you try to get the balls to sit in each hole, thats what it sounds like. NO hissing or singing caps sound from my discription. The Xbox after almost a year of perfect working order began to freeze up last night. It was during a game and then would boot back up only to freeze again after a few seconds. So i let it sit for an hour or so then fired it back up. Demoed Tony hawk for about 5 minutes then it froze again. Seems to be a heat issue now but can't be totally sure.
                            thanks
                            • 2ntense
                              • Oct 2006
                              Bryan
                              It's fine.....
                              No kidding! If that's the case then I have other issues. Man I would not have thought of that.
                              • 2ntense
                                • Oct 2006
                                Here is a pic of the caps I'm talking about
                                • willawake
                                  Super Modulator
                                  • Nov 2003
                                  • 8457
                                  • Greece
                                  sounds like HDD or optical drive failure
                                  • Rainbow
                                    • Aug 2005
                                    • 1375
                                    The right yellow cap seems a bit bulged. Replace both with 2200uF caps.
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      The Iwill DVD266U-RN has 4 of those little yellow critters (680@4v I believe). I've seen a few boards with them bulging a bit, and replaced them with MCZ's. No more issues after replacing them, and the crappy Hermai's they were loaded with...
                                      <--- Badcaps.net Founder
                                      Badcaps.net Services:
                                      Motherboard Repair Services
                                      http://folding.stanford.edu/
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • gonzo0815
                                        • Feb 2006
                                        • 1600
                                        Are those solid polymer caps? if you can obtain some snyo oscon, i think this should be the best solution, but any ultra low ESR cap like Rubycon MCZ or similar wit increase cpacitance should be ok.
                                        • nick3092
                                          Mid/late 80's Nichicon Yellow Caps
                                          by nick3092
                                          I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                          08-28-2022, 03:56 PM
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
