Failed MCZ rubycons
  • EIBM
    MBZ > KZG
    • Apr 2012
    • 18
    Re: Failed MCZ rubycons
    Originally posted by mockingbird
    Where can you even get RJF? Their stuff aint easy to come buy. For the prices he's charging, you could have done a lot better just buying Nichicon HM/HN/HZ from the owner of this website...
    ELNA is a large vendor, and their capacitors are used in a lot of high-end equipment. I wouldn't touch the HM(M) series, much like KZG or MCZ.
    No point of risk when you can get something better like panasonic or sanyo.
    Originally posted by LLLlllou
    It's possible that IBM under speced the caps in those locations. It might have called for something in the HZ range, and rather than go with polymers, they just figured the MCZ would be able to handle the abuse. Even a Rubycon can only take so much abuse before it fails.
    Absolutely not. The MBZs (which are much larger than the MCZs) are set to take most of the heavy load, and they are not going bad at all!
    System board manufacturers design the boards in a very specific manner. If the MCZs failed catastrophically (along with the cruddy KZGs!), yet the MBZs and other rubycons are fine... something is wrong with those series of capacitors.
    The cause of failure is due to the poor electrolyte used in the MCZs, and nothing else. Capacitors should be stronger than that.
    • mockingbird
      • Dec 2008
      • 5488
      #42
      I would absolutely trust HM just as much as Sanyo or Panasonic...
      How do you know? I still haven't seen the inside of the PSU.
      • UraBahn
        Scrapheap Hound
        • Nov 2004
        • 165
        Erm, can we stop this before it erupts into a flame war? Please?
        Some people like Nichicon, some don't. Some prefer Elna, others... would rather want to save money and/or use something else that may be closer to home or in stock.
        Each to his own. Either way's fine by me. Just as long as nothing pops in huge numbers (or cause fires, data loss, hair loss, sterility etc.) I got no beefs with anyone's choice.
        I was hoping to collect date codes on the borked MCZ. Perhaps some pics of the hardware and cases involved would be helpful too, so we can try to go somewhere with this thread. PSUs too would not be a bad idea to log as well.
        I had a theory... given how spotty MCZ failures are, I wonder if, perchance, it's a certain combination of PSUs, motherboards with certain *specific* design/thermal factors, heat AND dirty wall power? It could be that in some cases, certain PSUs could be the culprit, while in other cases it's the motherboard having a subpar VRM, etc. And the other point brought up by LLLlllou is valid too. And... just perhaps... maybe Rubycon DID make a bum batch. That's what I want to find out.
        Also, just because it's X big-name highfalutin company does NOT mean they won't try to cut corners at some point! *cough*Antec*cough*
        The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
        I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #44
          There is really no reason not to trust HMs (and HNs). Ok, they had a problem back then, but there is not a single incident of 2005 and later made HM/HNs failing.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I have heard reports of some 2005 ones having issues. Personally I chuck the 2005 ones as well just to be safe.
            sigpic
            (Insert witty quote here)
            • severach
              • Aug 2007
              • 1055
              I've seen spotty mass failures of Nichicon HM early 2005. Surely it took many weeks to clear out the faulty formula from every supply room. While I've only seen failures within the first 6 weeks of 2005 I only leave them alone after the 20th week of 2005.
              Unfortunately after 2005 usage of HM is so rare that it's hard to tell how they stack up against the competition. Either that or they are so good that boards with them rarely show up on the service desk.
              sig files are for morons
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Yes there is -> https://www.badcaps.net/forum/showthread.php?t=17506
                better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #48
                  *2006
                  • ahmedtou
                    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                    by ahmedtou
                    help me please
                    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                    I will share all the details with you, including the disc information.
                    Code:
                    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                    Current Profile: BD-R
                    Disc Information:
                    Status: Empty
                    State of Last Session: Empty
                    Erasable: No
                    Free Sectors: 12,219,392
                    Free Space: 25,025,314,816 bytes
                    Free Time: 2715:27:17 (MM:SS:FF)
                    Next
                    08-27-2025, 08:49 AM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
                  • keldeo
                    How many of you have seen failed Panasonics!?
                    by keldeo
                    In my experience, I've seen failed Taiwan/Chinese caps, obviously as I'm sure all of us had. I've also seen the defective Nichicon and Chemi Con series. Even seen failed Rubycons (MBZ I think?) if they are exposed to a lot of stress and heat. I've never seen failed Panasonics until now! Not just one, but 3! Also in seemingly random locations on the motherboard. Next to the RAM and CPU, but not t part of the VRM. It felt like I spotted a Unicorn, so I had to make this post. Motherboard is a IPIBL-LA. OEM from HP.
                    Unfortunately, I do not know the history behind this PC, it also had...
                    11-22-2025, 02:36 AM
                  • survivalbloke
                    MacBook Pro 13" Touchbar, model A1706 - Critical software update failed
                    by survivalbloke
                    This machine came in with a no power complaint after a liquid spill. The only damage I found was on the two USB-C boards, so I replaced those, and the machine charges and fires up. However, if the internal LCD is connected to the logic board, when it boots, I will get a critical update failed warning and the only options are to shut down or try again - it's a loop. I am able to start up fine in safe boot. If I disconnect the internal LCD, I am able to boot normally to the OS. The customer doesn't want to invest any more money beyond what I already charged. Unfortunately, based on what I...
                    11-21-2025, 01:12 PM
                  • Zarithya
                    Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
                    by Zarithya
                    I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
                    11-02-2025, 06:26 AM
