How many of you have seen failed Panasonics!?
  • keldeo
    • Feb 2022
    • 30
    In my experience, I've seen failed Taiwan/Chinese caps, obviously as I'm sure all of us had. I've also seen the defective Nichicon and Chemi Con series. Even seen failed Rubycons (MBZ I think?) if they are exposed to a lot of stress and heat. I've never seen failed Panasonics until now! Not just one, but 3! Also in seemingly random locations on the motherboard. Next to the RAM and CPU, but not t part of the VRM. It felt like I spotted a Unicorn, so I had to make this post. Motherboard is a IPIBL-LA. OEM from HP.
    Unfortunately, I do not know the history behind this PC, it also had no HDD, so I don't have an estimate of the hours on it. I bought it for about $1, as it was on a pallet with nearly 40 PCs in total and I bought the entire pallet.
    • 31293
    FL do fail, they were never sold retail, just special order for motherboards.
    probably too small for their spec so they got hot..
    also, FC can leak from the base after a decade or 2.
    • keldeo
      • Feb 2022
      • 30
      I see, I never knew that about the FCs. I guess given enough stress/heat/time any cap can fail, even Panny.
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • survivalbloke
        MacBook Pro 13" Touchbar, model A1706 - Critical software update failed
        by survivalbloke
        This machine came in with a no power complaint after a liquid spill. The only damage I found was on the two USB-C boards, so I replaced those, and the machine charges and fires up. However, if the internal LCD is connected to the logic board, when it boots, I will get a critical update failed warning and the only options are to shut down or try again - it's a loop. I am able to start up fine in safe boot. If I disconnect the internal LCD, I am able to boot normally to the OS. The customer doesn't want to invest any more money beyond what I already charged. Unfortunately, based on what I...
        11-21-2025, 01:12 PM
      • Zarithya
        Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
        by Zarithya
        I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
        11-02-2025, 06:26 AM
      • paparazzo79
        HDD in external enclosure failed, may I use external enclosure with other HDD?
        by paparazzo79
        Hello.
        I own Seagate Expansion drive which for me unknown reason has failed yesterday.When connecting to PC I am getting access denied message and whole partition in Disk Managment is in RAW format.
        So I dismantled the case thinking I may use the inside HDD as internal sata device in a computer but even like that I am getting access denied message.
        The drive is Sagate Exos.
        My question is may I use the enclosure with other internal drives (I own 3 internal 3.5 inch WD drives with 13TB capacity)?
        I mean maybe that is even not advisable since electronic card (from pic...
        10-28-2025, 01:01 PM
      • Lostdotfish
        KZG caps failed on a NOS motherboard - never been used...
        by Lostdotfish
        This is a new one on me. I picked up a new old stock DFI 865PE Infinity board recently. It's completely new, never used. While inspecting it I noticed some unexpected bulging caps...
        All of the 6.3v 1500uf caps had failed in place, despite the board never seeing use and being stored sensibly. I pulled the 16v caps that are the same series as a precaution and will replace them all.
        10-15-2025, 04:29 AM
