Re: Failed MCZ rubycons
ELNA is a large vendor, and their capacitors are used in a lot of high-end equipment. I wouldn't touch the HM(M) series, much like KZG or MCZ.
No point of risk when you can get something better like panasonic or sanyo.
Absolutely not. The MBZs (which are much larger than the MCZs) are set to take most of the heavy load, and they are not going bad at all!
System board manufacturers design the boards in a very specific manner. If the MCZs failed catastrophically (along with the cruddy KZGs!), yet the MBZs and other rubycons are fine... something is wrong with those series of capacitors.
The cause of failure is due to the poor electrolyte used in the MCZs, and nothing else. Capacitors should be stronger than that.
