Nichicon HM/HN/HZ scheduled for discontinuation
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Nichicon HM/HN/HZ scheduled for discontinuation
    lots of power supplies have > 16V caps, and most polys have really low capacitance at such high voltages. This can throw things off on power supply type circuits
    we don't have to find a certain brand series, just any series that is equivalent in specs (and reliability). This is why i'm making the cap database. zeerrrg let me ask you guys a question, is M ohm ohms / 100 or 1000
    • mariushm
      • May 2011
      • 3799
      M would be MEGA (one million) ... m would be milli
      milli - a thousand
      it's subdivisions of SI units ... 1 meter = 10 decimeters = 100 centimeters = 1000 millimeters
      1 inch = ~ 2.54 cm
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        No, HV is miniaturized HD ...
        At my, now, previous employer I compared HD with HE for a very different usage than what folks here do. I was not impressed. Then again, I was subjecting the things to 7X-10X (not a typo!) the rated ripple current, not anything like P/S or VRM usage. Generally, Nichicon PW, PA & HE, Panasonic FC & FM, Rubycon ZL, and UCC LXZ and KZE series did best in my torture test. That was over 3 years ago, BTW.
        PeteS in CA
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Did anything blowup in your torture test? And how did you torture them?
          Its a shame that they are discontinuing them.
          Muh-soggy-knee
          • mockingbird
            • Dec 2008
            • 5484
            Pete, are you sure you are recalling the results of your tests correctly??? HD should be precisely equal in spec to ZL, KZE and FM... I am very surprised at what you're saying. Are you suggesting that HD is a dud series??? I find this difficult to believe, as it has a proven track record.
            I'm not familiar with Nichicon PA, it's probably a discontinued series, but PW is equivalent to Panasonic FC and UCC LXZ... These are refered to as "borderline" low-ESR caps... HE is a step up between HD/FM/ZL and and the borderline low-ESR series of caps... UCC has an equivalent series - "KY". These are both proven series with good track records, but not as impressive in spec as Nichicon HD!
            • RJARRRPCGP
              • Jul 2004
              • 6304
              PA appears to not be discontinued. And it has lower ESR than PW.
              But looks like the ESR is still too high for motherboards, at least for many motherboards.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • mockingbird
                • Dec 2008
                • 5484
                #27
                You're right, I just pulled the spec sheet off their site.
                It's very close to Nichicon HE:
                6.3v 2200uF 10x25mm
                Nichicon PA:1680 0.033
                Nichicon HE:1650 0.042
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  6.3v 2200uF 10x25mm
                  Think the ESR is still too high for motherboards?
                  Arc A770 16 GB
                  • mockingbird
                    • Dec 2008
                    • 5484
                    #29
                    Motherboard grade caps and regular low-ESR caps are in two completely different classes.
                    Ultra low-ESR caps have a unique electrolyte, there's probably some really expensive element in it that drastically changes and improves its properties compared to ordinary caps... Look at any ordinary cap and then look at it's motherboard-grade series equivalent. The ripple rating is often drastically higher and the ESR always far far lower, and all this with often significantly lesser dimensions!
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      #30
                      My memory is OK mm, though I appreciate your concer . The torture was the extreme ripple current at which I ran the things - 7-10X the rated ripple ccurrent, ~22 hours a day, 7 days a week until the things vented (or as happened with a couple of 12.5mm diameter parts, the lead wires fused). Evidently, when you go that far beyond the ripple current rating, the ESR is not the critical factor in how long they lasted. What is, I'm not sure. It's worth noting that all of the series that did well, relatively,nwere 5000 and 10000 hour rated series. Nichicon HD, UCC KZG and KZH, and Rubycon YXG and YXH did poorly.
                      Nichicon P* and H* series have different electrolyte types; ditto UCC LX* vs. KZ*; ditto Panasonic FC vs. FM. Rubycon is "all in" with the electrolyte type used in H*, KZ* and FM where low Z caps are concerned.
                      PeteS in CA
                      • PeteS in CA
                        • Aug 2005
                        • 3581
                        #31
                        If you need a useless fact to complete your day, there was a Nichicon PA series back ca. 1980. It was, for the time, a low ESR series, matching against UCC's RX series and Sprague's 672D series. The current PA series came out, IIRC, in 2008.
                        PeteS in CA
                        • mockingbird
                          • Dec 2008
                          • 5484
                          #32
                          Fascinating...
                          I'm not surprised with KZG and YXG/YXH. KZG is known to use an inadequate electrolyte and YXG/YXH have a mediocre spec. I'm curious about KZH but I'm seriously puzzled with HD which is spec for spec identical at least in classification to KZE yet you say KZE outlasted HD in the torture test. Care to speculate? Also, may I ask where you sourced your KZH? I've not seen that stocked anywhere (Or Nichicon PA for that matter).
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Originally posted by Shocker
                            By the way, the table says you replaced the 220uF 16V RLS on the -12V with 330uF 6.3V SEPs.
                            That was a mistake. I have fixed it. If you look at the picture, you can see that the SEP next to the blue (-12V) wire is 16V
                            • mariushm
                              • May 2011
                              • 3799
                              #34
                              Fascinating...
                              Keep in mind he's talking about particular tests, done with 7-10x the ripple the caps are rated for.
                              He's not talking about performance of the capacitors at the rated specs so you can't form an overall conclusion about them.
                              • TCKTMB
                                • Jun 2011
                                • 56
                                #35
                                Here is what I got from my contact at Nichicon:
                                The main reason is that all our comp has already decided to discontinue water base series and now their customer are searching for another supplier
                                We will not accept orders in those 2 series . The only water base parts we will still manufacture HD and HE series.
                                Rick Massett
                                Nichicon (America) Corporation
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  I hope this doesn't put Topcat out of buisiness. This really sucks.
                                  sigpic
                                  (Insert witty quote here)
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    It's not looking good....but we'll see what transpires... I could always continue on with Panasonic from digikey or mouser....but I'd no longer be able to remain competitive....so yea, that's not a good choice either. Panasonic wouldn't even talk to me, I tried back when Rubycon dumped MBZ and MCZ.
                                    <--- Badcaps.net Founder
                                    Badcaps.net Services:
                                    Motherboard Repair Services
                                    http://folding.stanford.edu/
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3581
                                      #38
                                      My employer at that time was a noticeable share of Nichicon's North American sales. We had Nichicon people coming to us from their main office in IL. Ditto for UCC. Rubycon had a local sales guy; Panasonic was rep'ed by a Mfr's Rep outfit. So, except for Panasonic, samples for my testing came directly from the companies.
                                      TCKTMB's contact's info is less than clear to me. I wonder if the meaning is that MB mfrs and computer companies are switching to polymer caps. If that is what's happening, look for similar moves from UCC and Panasonic. And if that's what is happening, then people who do repairs on "older" equipment are going to be in some difficulty.
                                      PeteS in CA
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16958
                                        FWIW, if this does kill off badcaps.net, it won't be for a while. I have a decent stash right now, and in conjunction with a good friend of mine, we're working to put in an emergency order before they stop production....just hoping they accept the order. April 2013 will be the official 10 year anniversary of Badcaps.net. The business was started in 2001, but I registered the domain name in April 2003. That's a pretty good run for any small business! ...and if the business dies or I sell it, fear not, the forum will ALWAYS remain!
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          @ Topcat, have you tried sourcing Sanyo/Suncon WG caps?
                                          My concern with using Pannies from Digikey or Mouser is that they don't sell the FJ series (which is equivilant to Nich HM and Ruby MCZ), so they may not be a suitable replacement for all boards. In any case, though, you would still be competitive enough for international orders, as Digikey and mouser charge $50 or so for overseas shipping bs $8 from here.
                                          • DrewPhillips
                                            Capacitor Diarrhea - Nichicon PL Series
                                            by DrewPhillips
                                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                            03-02-2025, 10:18 PM
                                          • nick3092
                                            Mid/late 80's Nichicon Yellow Caps
                                            by nick3092
                                            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                            08-28-2022, 03:56 PM
                                          • chth96
                                            Is there datasheet for nichicon LXJ series?
                                            by chth96
                                            I want to calculate capacitor ESR referring to below guide.
                                            https://forum.digikey.com/t/calculat...-from-tan/2633
                                            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                                            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                                            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                                            11-20-2022, 08:11 AM
                                          • chth96
                                            Is there any datasheet for nichicon RT(M) series?
                                            by chth96
                                            A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                                            https://www.badcaps.net/forum/troubl...e-been-blew-up
                                            and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                                            But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                                            I have spare console...
                                            11-28-2023, 03:36 AM
                                          • spiros.p
                                            EV dsp,replace the nippons lxz with nichicon fw ?
                                            by spiros.p
                                            Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
                                            12-19-2023, 12:26 AM
