Need pce-tur capacitor datasheet
  • Koda
    • Aug 2011
    • 317
    • Macedonia
    The caps are 1500uf 16v pce-tur capacitors, markings pce-tur 105C 08-01.
    Can't find neither the datasheet nor the manufacturer website. Are these low esr or GP caps?
    Guns don't solve problems. I'll take 12
  • japlytic
    • Oct 2005
    • 2086
    Re: Need pce-tur capacitor datasheet
    What are these capacitors being used in?
    For a linear power supply, general purpose units are fine, but for switching power supplies, low-ESR units are required.
    • Koda
      • Aug 2011
      • 317
      • Macedonia
      They aren't used yet
      Got my hands on some of these for 3c each and I'm thinking of using them of trial recaps to see if something will work after recap then replace them with good brands but I wouldn't want to put them in a mobo and risk damaging a mosfet or something.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Might help your search
        PCE is not the name of the manufacturer. The capacitor of a company called "CEC International Holdings Limited". CEC please refer to the item.
        Capacitor mainly see: PCE-TUX, PCE-TUR, PCE-TUL, PCE-TUT JPCE PCE
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          they are junk... thats a crap brand.
          just so you know.
          sigpic
          (Insert witty quote here)
          • Koda
            • Aug 2011
            • 317
            • Macedonia
            Yeah, pretty much got that, that's why I will use them for trial recaps. Also found out that the tur series are GP and the tul series are low esr type.
            • Scenic
              o.O
              • Sep 2007
              • 2642
              So far I've only seen those PCE-TU_ caps in very old Seasonic PSUs.
              They were still fine (visually), and there were no stability problems yet, but I've replaced them anyways cause I couldn't really find anything good about them on the net..
              • Agent24
                I see dead caps
                • Oct 2007
                • 5038
                • New Zealand
                Enermax also used to use them.
                If anyone finds datasheets let me know!
                EDIT: Had a bit of a search around and... Jackpot!
                CEC Datasheets now here: http://starwatcher-circuits.net23.ne...C/CEC/CEC.html
                -David VanHorn
                • Koda
                  • Aug 2011
                  • 317
                  • Macedonia
                  Thanks man!!! Killed myself searching for those datasheets. How did you find them? And one more thing... there are no 1500uf in the tur series datasheet and I have those.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5038
                    • New Zealand
                    They were in the web archive. I did a search for PDFs in http://www.0759.com
                    The only ones that seemed to be there were from 2004 (but there were many more archives of just the web page themselves) so it's possible the 1500uF came later or is a non-standard size for that series.
                    In any case if you measure the can size of yours and then see what values of ripple correspond to that size for the next closest values you will get some idea of what their rating should be.
                    But those JPCE capacitors are a tricky one... the list from 2004 on that site shows only the datasheets I have, but there are photographs of other series like TUT which aren't listed there. Whether that is a newer series or made by a different company and rebranded for CEC or something I don't know. That Japanese capacitor list site says something about the CEC capacitors maybe having something to do with Samsung, But Google can't translate well so I don't know what that is actually about.
                    If anyone finds or has newer datasheets let me know and I'll put them on the site
                    -David VanHorn
                    • Koda
                      • Aug 2011
                      • 317
                      • Macedonia
                      I actually read somewhere that these caps can be quite reliable although not of the best quality.
                      • Recycler
                        • Feb 2012
                        • 16
                        Sorry to dig up an old thread, just wanted to report that I bought 20 of these Pce-tul caps, 1000uF / 25V.
                        Comparing them with the usual chinese junk, they are pretty good.
                        In my country it is impossible to get Nichicon, United Chemicon, Rubycon for example.
                        The CEC caps are somewhat higher and smaller, making them OK for power supply's but for LCD monitors I think the won't fit.
                        Cheers.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5038
                          • New Zealand
                          Which country is that?
                          -David VanHorn
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            South America.
                            https://www.badcaps.net/forum/showpo...&postcount=173
                            --- begin sig file ---
                            --- end sig file ---
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5038
                              • New Zealand
                              What about this guy? http://myworld.ebay.com/egekecu/
                              Seems to ship worldwide for free. Can't get much better than that.
                              -David VanHorn
                              • mariushm
                                • May 2011
                                • 3799
                                I have sent a few capacitors at a time to people that needed them here on the forums, not making a business out of it just trying to help when I can.
                                It would cost me about 1.6$ in postage to send about 4-5 capacitors to South Africa... it's strictly a weight issue. Once I'd get over 50 grams or so of weight, it goes up to about 3$ in postage.
                                If you need something in particular, feel free to ask me and if I have here what you want, I can give them to you at the original digikey price.
                                Otherwise, might wanna check RS-Online, they have a "South Africa" site but not sure about the shipping fees : http://za.rs-online.com/web/?%20&cm_..._-MainWorldMap
                                The "Export" site of Farnell may also be working for you but again not sure about the shipping fees, best thing would be to make an accound and check (or easier get into live chat with them).
                                http://export.farnell.com/jsp/home/h...n_EX_DIRECTEXP
                                I know for me in Romania, the shipping fees are very reasonable.. 20 RON (~ 6$ / 4 Euro) no matter how small or large the order is...
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5038
                                  • New Zealand
                                  South America ≠ South Africa
                                  But I don't think we know specifically which country in South America he's in?
                                  I would say the big name companies would ship but probably for too much money. Even to New Zealand, DigiKey is a total ripoff.
                                  -David VanHorn
                                  • mariushm
                                    • May 2011
                                    • 3799
                                    Hmmm ... why the hell did I read South Africa? I guess that's what happens when you just wake up and start posting.
                                    Anyway, it doesn't make a difference, outside the European Union the postage is about the same so if he needs something particular, I may be able to help.
                                    But I guess the links are not suitable anymore.
                                    Recycler, go to rs-online.com and farnell.com and click on the "South America" links or whatever your country is and see the shipping terms and costs - both are good online stores with quality parts.
                                    • MORETTIGIAN
                                      by MORETTIGIAN
                                      Title:
                                      Description:
                                      Procedure performed:
                                      - Removed backplate
                                      - Reapplied thermal compound
                                      - Reassembled card
                                      09-18-2025, 12:14 PM
                                    • Prolog
                                      by Prolog
                                      12-01-2024, 08:27 PM
                                    • ajdrenter
                                      Picking caps for Antec SU-380
                                      by ajdrenter
                                      In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                      https://www.badcaps.net/forum/showthread.php?t=14159
                                      It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                      05-13-2023, 10:40 AM
                                    • chth96
                                      by chth96
                                      12-22-2023, 04:34 AM
                                    • chth96
                                      by chth96
                                      06-02-2024, 07:31 PM
