Panasonic FRs
  • TCKTMB
    • Jun 2011
    • 56
    Panasonic FRs
    What does everyone think about Panasonic FRs?
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Panasonic FRs
    To early to tell so far for if they last.
    but also they look generic
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • Rob Northen
      • Jan 2010
      • 137
      • Denmark
      Re: Panasonic FRs
      I've used some of them, they seem to work just fine. They measure a slight higher on ESR compared to FM series. But they should have a fair bit longer life.
      And then you just have to live with the odd looking of the cap, missing logo.
      I've sourced mine from RS Components.
      • TCKTMB
        • Jun 2011
        • 56
        Re: Panasonic FRs
        Yeah they look and feel cheap but so far haven't heard anything bad about them. Life and ESR ratings are very close to ZLH but they can't match the ripple rating. Not sure how I feel about them yet.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Panasonic FRs
          FR ESR & Ripple is virtually identical to FM.
          For most sizes it IS identical.
          Mann-Made Global Warming.
          - Dr Seuss
          • severach
            • Aug 2007
            • 1055
            Re: Panasonic FRs
            Panasonic FR is all about super long life with decent ESR. Rubycon ZL and YXG are good comparisons and are almost as good as UCC LXY and LXZ. They aren't anywhere near the ripple and ESR of modern Vcore capacitors. Compare FR to UCC KZJ or Nichicon HN.
            FR won't be showing up on motherboards any time soon, even the ultra durable ones.
            sig files are for morons
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Panasonic FRs
              Nope.
              FR are clearly better than ZL and ~FAR~ above YXG.
              FR have better Ripple and ESR than ZL and YXG aren't even close.
              The only common cap FR compares directly to is FM.
              8x20mm FM ... 1560mA - .030 ohm
              8x20mm FR . 1560mA - .030 ohm
              8x20mm ZL . .. 1250mA - .041 ohm
              8x20mm YXG .. 1050mA - .069 ohm
              10x20mm FM ... 2180mA - .019 ohm
              10x20mm FR . 2180mA - .020 ohm
              10x20mm ZL .. . 1820mA - .023 ohm
              10x20mm YXG .. 1400mA - .046 ohm
              FR are in effect a long-life FM.
              [Although FM never has problems that way anyway.]
              - Dr Seuss
              • TCKTMB
                • Jun 2011
                • 56
                Re: Panasonic FRs
                ZLs are more for high end audiophiles, ZLH ZLJ are a better comparison.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: Panasonic FRs
                  I know that audiophools like the ZL and ZLx series but if you search audio applications in Rubycon's application guide -NONE- of those will come up at all.
                  http://www.rubycon.co.jp/en/tech/application.aspx
                  - So, I'm not sure where the audiophools got that idea. - It wasn't from Rubycon.
                  They do come up under SMPS applications and some other things.
                  That's what those series are 'for'.
                  If they happen to make audiophools happy then I'm glad they're happy.
                  I've always considered them sort of 'happy' anyway. - LOL.
                  - Dr Seuss
                  • TCKTMB
                    • Jun 2011
                    • 56
                    Re: Panasonic FRs
                    I can't tell the difference but the experts say it so it must be true:
                    Source:
                    http://www.referenceaudiomods.com/Me...gory_Code=RUBY
                    • mockingbird
                      • Dec 2008
                      • 5488
                      Re: Panasonic FRs
                      I thought FR was just miniaturized FM...
                      They have come in handy for me in the past.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Re: Panasonic FRs
                        Source:
                        Never believe a salesman.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Re: Panasonic FRs
                          A lot of FR are smaller than FM for whatever uF.
                          But by can size they essentially match FM.
                          Thing is FC and FM are often oversize for their uF as compared to other brands and sometimes that's a problem.
                          FR are definitely a handy series.
                          - Dr Seuss
                          • lti
                            • May 2011
                            • 2557
                            Re: Panasonic FRs
                            These capacitors are very fast
                            Careful system matching is ultimately necessary, as these capacitors can show you the systems faults (usually the lack of AC mains correction)
                            Audiophiles are nuts.
                            • BigPete
                              Panasonic Heatpump Dryer Repair
                              by BigPete
                              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                              Unfortunately the whole machine has to come apart to fix it.
                              I have...
                              11-01-2025, 06:40 PM
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • AquaMan Ua
                              by AquaMan Ua
                              05-17-2025, 09:40 AM
                            • stecos
                              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                              by stecos
                              Hi everyone!
                              For my passion for technology I'm now collecting several...
                              11-28-2022, 11:39 AM
                            • aa10aa10
                              Panasonic Toughbook CF-33 mk1 BIOS repair
                              by aa10aa10
                              Good day,
                              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                              01-21-2025, 06:13 AM
