What does everyone think about Panasonic FRs?
Panasonic FRs
Re: Panasonic FRs
I've used some of them, they seem to work just fine. They measure a slight higher on ESR compared to FM series. But they should have a fair bit longer life.
And then you just have to live with the odd looking of the cap, missing logo.
I've sourced mine from RS Components.Comment
Re: Panasonic FRs
FR ESR & Ripple is virtually identical to FM.
For most sizes it IS identical.
.Attached Filesif you find these attachements useful please consider making a small donation to the site
Mann-Made Global Warming.
- Dr Seuss
Re: Panasonic FRs
Panasonic FR is all about super long life with decent ESR. Rubycon ZL and YXG are good comparisons and are almost as good as UCC LXY and LXZ. They aren't anywhere near the ripple and ESR of modern Vcore capacitors. Compare FR to UCC KZJ or Nichicon HN.
FR won't be showing up on motherboards any time soon, even the ultra durable ones.Comment
Re: Panasonic FRs
Nope.
FR are clearly better than ZL and ~FAR~ above YXG.
FR have better Ripple and ESR than ZL and YXG aren't even close.
The only common cap FR compares directly to is FM.
8x20mm FM ... 1560mA - .030 ohm
8x20mm FR . 1560mA - .030 ohm
8x20mm ZL . .. 1250mA - .041 ohm
8x20mm YXG .. 1050mA - .069 ohm
10x20mm FM ... 2180mA - .019 ohm
10x20mm FR . 2180mA - .020 ohm
10x20mm ZL .. . 1820mA - .023 ohm
10x20mm YXG .. 1400mA - .046 ohm
FR are in effect a long-life FM.
[Although FM never has problems that way anyway.]
.Last edited by PCBONEZ; 07-27-2011, 10:17 AM.Mann-Made Global Warming.
- Dr Seuss
Re: Panasonic FRs
I know that audiophools like the ZL and ZLx series but if you search audio applications in Rubycon's application guide -NONE- of those will come up at all.
http://www.rubycon.co.jp/en/tech/application.aspx
- So, I'm not sure where the audiophools got that idea. - It wasn't from Rubycon.
They do come up under SMPS applications and some other things.
That's what those series are 'for'.
If they happen to make audiophools happy then I'm glad they're happy.
I've always considered them sort of 'happy' anyway. - LOL.
- Dr Seuss
Re: Panasonic FRs
I can't tell the difference but the experts say it so it must be true:I know that audiophools like the ZL and ZLx series but if you search audio applications in Rubycon's application guide -NONE- of those will come up at all.
Source:
http://www.referenceaudiomods.com/Me...gory_Code=RUBYComment
Re: Panasonic FRs
I thought FR was just miniaturized FM...
They have come in handy for me in the past.Comment
Re: Panasonic FRs
Never believe a salesman.I can't tell the difference but the experts say it so it must be true:
Source:
- Dr Seuss
Re: Panasonic FRs
A lot of FR are smaller than FM for whatever uF.
But by can size they essentially match FM.
Thing is FC and FM are often oversize for their uF as compared to other brands and sometimes that's a problem.
FR are definitely a handy series.
- Dr Seuss
Re: Panasonic FRs
These capacitors are very fastCareful system matching is ultimately necessary, as these capacitors can show you the systems faults (usually the lack of AC mains correction)
Audiophiles are nuts.
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
...1 Photo11-20-2024, 08:52 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by stecosHi everyone!
I happened several times, in the search for help from the web, to consult this very interesting forum.
So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
Having said that I come to the gist of my post on the forum as the title suggests.
For my passion for technology I'm now collecting several... -
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
- Loading...
