Dead K9N Neo-f
  • Joun
    • Jul 2011
    • 191
    • Greece
    Dead K9N Neo-f
    Hello to everyone!
    I am new to this forum and I have to say I am really impressed with the amount of information that exists here..
    I have to say about myself that I am an electrical engineer and I deal with electronics for hobbie( or lately I think it is starting to be a side a side job..)
    I have a pretty decent collection of tools and more than 25 years of experience as a hobby.
    Lets get to the point now: I have a dead K9 neo-f motherboard..Before I found your forum I thoght it might be the BIOS's fault so I found I new one and replace it..
    Of course nothing changed..
    I now have to ask you if it is possible for capacitors to look OK and still be bad..I have desolder a few and measure them, the measurements were very strange..Since I have bought my capacitance tester mainly for impendace measurments I cant rely on it very much..
    One last question: do you think I should invest on an ESR meter ?
    Thank you..
  • c_hegge
    • Sep 2009
    • 5219
    Re: Dead K9N Neo-f
    Those capacitors you de-soldered are Chemi-con KZG series. It is VERY common for them to fail without bulging. I'd try replacing them. The other caps are panasonic (the black/gold ones with the T-vent) and sanyo (the green ones). I can also see some el-cheapo Teapo caps there too (the blue ones with tristar vents) The KZGs and teapos have to go, the rest can stay.
    • Joun
      • Jul 2011
      • 191
      • Greece
      Re: Dead K9N Neo-f
      I will replace the ones you mentioned..
      The problem is that where I live the only way is to order them so it's gonna take a while..
      I'm thinking to buy a lot of cheap ones since I am not sure it's only the capacitors to blame..When I have the proper experience I'll start buying decent ones.I'm saying I don't want to waste good quality caps only to discover later that my motherboard still doesn't wakes up.
      What about the ESR meter?Do you think it's necessery?
      Thank you for your answer.
      • tron
        • Apr 2009
        • 47
        Re: Dead K9N Neo-f
        yes
        first ESR meter, if you like
        to fix SMPS and PCB
        with clarity of the
        internal resistance
        of the cap
        heres a nice one
        http://www.radiodevices.info
        but there are other ones
        • Joun
          • Jul 2011
          • 191
          • Greece
          Re: Dead K9N Neo-f
          Well since my Russian are a little rusty(don't know any at all,I'm Greek) I fell more confident ordering from an English speaking site.The truth is I have heard very nice comments for the ESR meter you have just linked me..
          I also have that in mind(more pricey for sure): http://www.peakelec.co.uk/acatalog/jz_esr60.html
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Dead K9N Neo-f
            Originally posted by tron
            heres a nice one
            Last I heard those were out of production due to parts shortages.
            Originally posted by Joun
            What about the ESR meter? Do you think it's necessery?
            Depends on how often replacing caps comes up in your life.
            You can't find bad low ESR caps without one but if replacing caps is not something you do frequently then an ESR meter may not be worth it.
            [That is for you to decide....]
            Many hobbyists get by with simply replacing all bloated and all 'suspect' caps.
            'Suspect' = caps with known issues which you can find out about by asking or reading here.
            'Suspect' = if they aren't bad yet they probably will be soon enough so you might as well replace them.
            I probably repaired 30 or more boards before I even owned an ESR meter.
            The times it helps:
            - To find bad ones that aren't bloated.
            - When you pull all the 'Suspect' caps off a board that won't work and they all check good - you'll know the board has some other problem like a bum 'good brand' cap or a blown MOSFET or chipset.
            - When you want to replace as few caps as possible to test the board and see if it's worth recapping.
            - To check new caps before installing because once in a great while a 'dud' does get through.
            So, you don't HAVE to have one to do cap work but I highly recommend owning one if you FREQUENTLY do cap work.
            Mann-Made Global Warming.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Dead K9N Neo-f
              As to KZG. - Just replace them.
              They go bad often enough it's not worth chancing they won't go bad later if they aren't already.
              - Dr Seuss
              • Joun
                • Jul 2011
                • 191
                • Greece
                Re: Dead K9N Neo-f
                Thank you for your answer..
                And what do you think about my idea of getting a lot of cheap caps(like 10 for $1) and replace all of MB caps just to check if it is their to blame or to look somewhere else?
                P.S Blown MOSFET or chipset? Should I check here for "usual suspects"(I mean in which part of MB they fail often) or somewhre else?
                Sorry for the too many questions rookie on recapping here( I even learn such a word exists two days ago..)
                • ipman
                  • Jul 2011
                  • 159
                  Re: Dead K9N Neo-f
                  Joun, since you are quite close to Romania, there is somebody who makes a good ESR meter here.
                  The page is here: here
                  Shipping should not be too much, the meter costs around the equivalent of 40 euros, and since we are in EU you do not pay custom fees.
                  • Joun
                    • Jul 2011
                    • 191
                    • Greece
                    Re: Dead K9N Neo-f
                    Ipman thanks for the link,I wasn't aware of that..
                    I guess that you're using it yourself?
                    • tron
                      • Apr 2009
                      • 47
                      Re: Dead K9N Neo-f
                      ESR-micro v3.1 model is available
                      and the sitemanager speaks English
                      Atlas ESR70 is even better,
                      because it protects itself from
                      occasional discharge
                      • Joun
                        • Jul 2011
                        • 191
                        • Greece
                        Re: Dead K9N Neo-f
                        Thanks for the info..
                        I'm waiting for an answer from the non-English speaking sites.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          Re: Dead K9N Neo-f
                          Hi Joun! I am from Greece and Thessaloniki too!
                          Geia!
                          I will send you a pm in Greek trying to answer your questions.
                          Generally, I agree with what the previous users said.
                          Btw welcome here!
                          • Joun
                            • Jul 2011
                            • 191
                            • Greece
                            Re: Dead K9N Neo-f
                            Well it is true what they say, there are Greeks everyware..
                            • ipman
                              • Jul 2011
                              • 159
                              Re: Dead K9N Neo-f
                              Yes, I am using it for almost half year. Nice tool, decent quality.
                              If you are interested, I can translate the specs.
                              In the mean time here's the construction details
                              Please note that I don't have any commercial interest in this, just trying to help.
                              • Joun
                                • Jul 2011
                                • 191
                                • Greece
                                Re: Dead K9N Neo-f
                                I have already translate the specs(thanks Chrome!) and I have send email to x-roast, waiting for his answer about shipping and way of payment..
                                You say it's worth it right?
                                • ipman
                                  • Jul 2011
                                  • 159
                                  Re: Dead K9N Neo-f
                                  Works as it should for me, can't find any complaints about it.
                                  I use Maha "true 9,6V" 8 cell rechargables instead of normal 9V PP3 block, which gives the meter way more than 10V at full charge. It will not enter stand-by because of that (was conceived this way) and the display is brighter.
                                  Still, it has reversed diode protection inside and will not self-discharge capacitors as Peak ones do, but price is way lower.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Re: Dead K9N Neo-f
                                    I'd still use good caps.
                                    Leave leads a little long until board is tested.
                                    If board is trashed pull the caps for later.
                                    If board works finish trimming the leads.
                                    Look for cracks, pits, or shinny spots that indicate something melted inside.
                                    On all the IC ships really.
                                    Those are just most common to get blown by a cheap PSU or bad caps.
                                    Most mobo MOSFETs are near the CPU and RAM sockets/slots.
                                    You are looking for the brand and/or series caps that are problems.
                                    Have to check them all really but definitely look at the mobo, in the PSU, and on the video card.
                                    - Dr Seuss
                                    • Joun
                                      • Jul 2011
                                      • 191
                                      • Greece
                                      Re: Dead K9N Neo-f
                                      Thank you for the tips Pcbonez..
                                      • double_DD
                                        How can I be sure that my EC chip is dead?
                                        by double_DD
                                        As the title suggests, how can I be sure that my EC chip is really dead?
                                        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                        03-12-2025, 07:47 AM
                                      • disorder
                                        ps5 edm-033 dead after hdmi/usb ports destroyed
                                        by disorder
                                        hello guys,
                                        i need help to repair a edm-033 ps2
                                        history : as always hdmi port and usb ports destroyed after unplugged
                                        after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                        so i changed it
                                        now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                        but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                        i don't see any projection of liquid metal on pcb.
                                        01-14-2025, 12:48 PM
                                      • Beton
                                        Finding a dead short component
                                        by Beton
                                        Hi guys!
                                        I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                        So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                        I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                        I have a bench PSU and if I try to inject voltage the voltage...
                                        12-10-2021, 01:05 PM
                                      • zunasthegreat
                                        Chieftec GPS-450-AA with dead 20N60C3
                                        by zunasthegreat
                                        Hello everyone hope all doing well!
                                        I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                        09-01-2024, 07:12 PM
                                      • FiguringITout
                                        MSI Raider GE75 - Not posting, probable dead CPU
                                        by FiguringITout
                                        Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                        Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                        07-25-2024, 07:27 AM
