Bad Cap Replacement Help
  • Clem16
    Trained Welder
    • 17
    Hi, I just aquired a motherboard that was "junked" because it was not working. It posts fine but as soon as windows starts to load it imediatelly powers off. Upon closer inspection of the board the end of one of the capacitors is noticibly buldged out and has some brown buildup. There is another capacitor which has a slight buldge but has not blown out yet. These are the only two capacitors on the board showing any sign of trouble every other capacitor has a different color plastic covering.
    The board is an Intel Desktop Board Model E210882
    The writing on the capacitor says (the best I can read it): nichicon 560uF6.3V 105 deg C A0310.
    Both capacitors that show signs of trouble are identical.
    The motherboard is an older board but nonetheless I'd still be pleased if I could repair it.
    It would be nice if someone cuold help me identify a replacement capacitor I could buy as I did not see a capacitor with the same microfarad rateing listed on the website.
    Thanks. ~Clem
    "He strains to hear a whisper who refuses to hear a shout." - Robert Jordan
  • TheLaw
    • Jan 2011
    • 477
    Re: Bad Cap Replacement Help
    There are many other sources for motherboard-grade capacitors. Examples are: Mouser.com, Digikey.com, Farnell.com, Newark.com.
    You are missing one key think from the capacitor and that is the series of capacitor. On Nichicon capacitors, it is on the otherside of the strip that goes down the side of the capacitor and above the word Nichicon. It will be two letters and then (M). You will probably see something like HN (M), HM (M), HD (M)...Something along those lines. And where is it on the motherboard? Next to the CPU in a group of other capacitors or freelancing on its own?
    • Clem16
      Trained Welder
      • 17
      (Key Think? )
      Its a HN(M), Sorry I was in a rush typing that out as I was late for work and I missed that bit of info.
      This is the orentation of the capacitors on the motherboard.
      Looking down on the board. Processor at the top, ram slots to the right.
      The capacitors are to the imediate left of the four ram slots. One at the top and one at the bottom.
      I tried to post a picture. Sorry the resolution is so low its only a cellphone camera.
      The Red arrow is the capacitor that has bulged out on the top. The capacitor indicated by the black arrow is one that has an ever so slight buldge but is not spewing anything out yet.
      Let me know what you think thx!
      • TheLaw
        • Jan 2011
        • 477
        Ah. Nichicon is a very dependable brand. However, they had some problems with the HM/HN line back in roughly 2003-2006. (Somewhere in there). That board looks atleast that old. You can do a direct replacement. Get a new Nichicon HN. You won't get any bad ones.
        http://www.mouser.com/ProductDetail/...IUekSuXVuyg%3d
        You might want to get it off a different source. Mouser has some pretty high shipping rates. About $5 is the cheapest I've seen, even if what you bought only weighed 0.05oz
        Replace both. If there are any other capacitors marked HN/HM on that board or KZG (not Nichicon), you want to repalce those as well.
        • Clem16
          Trained Welder
          • 17
          Thanks!
          The Shipping from mouser is like $20. For like 10 capacitors! OUCH!
          • TheLaw
            • Jan 2011
            • 477
            Originally posted by Clem16
            Thanks!
            If you live in the US, use US Priority Mail, or try Digikey, Farnell.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              E210882 is not a model number, it's basically a factory number..
              Every model that comes out of that factory will have the same number.
              Australian law requires it to be there or it can't be imported down under.
              Nichicon HM and HN series manufactured between 2001 and 2004 were defective.
              - Manufacturing error..
              You're doing something wrong with the mouser shipping calculator.
              Someplace there is a screen that lets you choose shipping method.
              The methods have different prices.
              Mouser and Digikey shipping should be about the same if you're paying attention at checkout.
              Mann-Made Global Warming.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                A0310 = 10th week of 2003.
                If it's an HN or an HM it's bad.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  The (M) - is not part of the series name.
                  It's the uF tolerance code for +/-20%
                  - Dr Seuss
                  • TheLaw
                    • Jan 2011
                    • 477
                    I know that. But it's much easier to find the series if you first find the (M)
                    • Clem16
                      Trained Welder
                      • 17
                      No I am in Canada. I'll keep you informed of my efforts.
                      I work janitorial at my college here and the janitorial closet also houses the computer services "junk room" they toss lots of stuff out. I asked and policy is if its in the junk pile any student is free to take it if they want. Since I work everyday I can quickly see if there is any new goodies that show up.
                      This board board is one among several I have pulled out of the junk pile. So if I am able to fix it by replacing these defective capacitors, I'm going to be happy
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        No I am in Canada.
                        We are dinged $8 USD for shipping and handling from digikey.
                        --- begin sig file ---
                        --- end sig file ---
                        • Clem16
                          Trained Welder
                          • 17
                          Upon closer inspection there is also a 2200uf10v Nichicon marked HM(M) It does not have any physical signs of damage yet, but it is probally just a mater of time before it goes. I dont see any others marked like that. There are some others marked HD(M) , VR(M).
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            HD should be fine.
                            VR are rated for 85C and -sometimes- go bad.
                            [VZ are quite cheap and a good 105C replacement for VR.]
                            ""it is probally just a mater of time before it goes.''
                            Yup,
                            They are like flower buds on a bush.
                            They don't necessarily all 'bloom' at once but it's usually pretty close together.
                            - Dr Seuss
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              If I remember correct the problem with Nichicon HM/HN had to do with some factories overfilling them, so there is a small possibility that yours belong to the good ones...?
                              • Clem16
                                Trained Welder
                                • 17
                                So I ordered a few replacements from mouser for the three HN(M) ones. When they come in I am going to replace the one that is physically showing signs of damage. Test it to see if it works. Then probally replace the other one that possibly has issues as well but has not broken open yet. Then I am going to test it again and if everything works great I might use it for a bit but I will probally replace the other one that has the HN(M) markings since I did order a replacement for it as well. Then I should have a good board with which to tinker.
                                Considering I got the board for free including 3.0ghz p4 processor. for like 12$ for replacement parts I am happy. If it works great I have a new board. if it doesnt hey atleast I had fun. and if it does I have several other boards that are flaky I have not had a look at yet to see if its the caps. and a friend has a stack of boards someone gave him that I know have blown out capacitors. So I should be able get quite a few boards up and running here again
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  As already noted the date code is 2003. They are bad.
                                  - Dr Seuss
                                  • Clem16
                                    Trained Welder
                                    • 17
                                    Hey could someone explain or point me to a good explanation of how to read the markings on a capacitor.
                                    Also, in the descritpion from Mouser for a capacitor what does the 3.5LS mean?
                                    "Aluminum Electrolytic Capacitors - Leaded 6.3volts 560uF 8x11.5 20% 3.5LS"
                                    • Clem16
                                      Trained Welder
                                      • 17
                                      Right, I ordered replacements for all of them with that date code.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        3.5LS = 3.5mm Lead Spacing
                                        Normally 8mm diameter caps have a 3.5mm LS and 10mm caps have a 5mm LS but there are exceptions.
                                        - Dr Seuss
                                        • devsigner
                                          identify capacitor for MacBook Pro with rare logic board 820-02037-06
                                          by devsigner
                                          Hi
                                          While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
                                          resistance tests show a rising resistance value, indicating a capacitor.
                                          The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
                                          i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
                                          It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
                                          11-28-2025, 01:39 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • boosti45
                                          Macbook pro logic board replacement parts quesion
                                          by boosti45
                                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                          08-21-2024, 05:23 AM
                                        • artvandalai
                                          Where can I get compatible capacitor for replacement?
                                          by artvandalai
                                          Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                                          12-28-2024, 10:15 AM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
