Capacitor leg stuck in mother board
  • umjohn
    • Dec 2010
    I have done much searching but have not found anything helpful. I have a computer mother board with three bad capacitors. I have removed all three capacitors, however two capacitors each left a leg behind in the board. What is the best way to get the hole cleaned out, if possible?
    Thanks,
    Umjohn
  • Toasty
    • Jul 2007
    • 4171
    Re: Capacitor leg stuck in mother board
    Is there enough of the leg left to grab onto? If so, grab it with tweezers and heat the hole it's in from the other side using fresh solder on your iron and keeping a little pull on the leg. It should come free. If not, you may need to use a needle to push the leg out. Someone to hold the board for you while you work is a plus.
    See: https://www.badcaps.net/pages.php?vid=32
    Toast
    veritas odium parit
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      add solder both sides.
      i would use some small pliers not tweezers.
      try heating alternate sides and working it.
      • mathog
        • Mar 2010
        • 2655
        Sometimes that happens on the ground plane leg of a badly damaged capacitor. In that case the problem with both tweezers and pliers is that they act as heat sinks, which is the last thing you want when the ground plane is already sucking heat away from the solder. For this reason, I come down on the tweezer side of this debate, since the tweezers cool the wire less.
        There are ceramic tweezers which, being insulators, would be great for this application, but they tend to be really expensive.
        Whatever you do, apply no significant force to that leg. Once the solder is fully melted it will come out easily. If the solder is not fully melted yanking on it may damage the motherboard.
        • cookieCAM
          ICDEZ_CAM
          • Feb 2011
          • 26
          I'd:
          Get A DE-Soldering Iron (DE) People Never Look At DE
          Heat It Up
          Get Flux
          Get Some Flux On The Iron
          Get Your Mobo
          Put It On The Area
          Then CAREFULY Blow On The Mobo Surface
          Wait For It To Cool
          AFTER Cooling Pull And Twist A Little Bit CAREFULY
          Pull It Out
          Thanks, cookieCAM (Cam)--Updated:March 2011
          • smason
            • 1652
            Or, add solder, both sides, heat and insert the leg of a new cap in the bottom, forcing the broken one out the top.
            • cookieCAM
              ICDEZ_CAM
              • Feb 2011
              • 26
              Thats Risky
              • cookieCAM
                ICDEZ_CAM
                • Feb 2011
                • 26
                Originally posted by cookieCAM
                Thats Risky
                Because,
                That MIGHT Push It Through But, It Might Also Solder As 2 And Make Too Big Of A Hole And Then When You Do Fix It, It Won't Make Contact Or Even Solder In.
                That Bight Be Fixed By:A LED Light,Soldering Stuff,Cabel,Lots Of Led,A New Cab,Wire Strippers,A Few Hours Of Time.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  using a desoldering tool would of probably been the best way to make sure the leg came out with ease, so you woulden't have to pull it out afterwards
                  I use the hakko 808, its good priced, and works good as long as you keep the the solder channel clean
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • duwane
                    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                    by duwane
                    Hi All.
                    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                    10-17-2023, 07:48 PM
                  • mferna14
                    Apple 820-01958-A logic board stuck on 5V .19amp
                    by mferna14
                    Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
                    02-21-2025, 03:42 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
