LG TV recall re. bad X-class capacitors
  • japlytic
    • Oct 2005
    • 2086
    • Valve/tube stuff, cartoons
    https://www.productsafety.gov.au/rec...0%9D-smart-tvs
    I can't seem to find any infomation about this problem affecting overseas models.
  • andrewsawesomr
    • Jun 2022
    • 108
    • United States of America
    • Coding, Electronics, Music
    Re: LG TV recall re. bad X-class capacitors
    Can't be too safe, though, right?
    I wonder if it was the design of the circuit board or the quality of / a defect in the capacitors.
      master hoarder
      • May 2008
      • 12182
      • Fixing stuff
      Good questions.
      I don't think the design of the circuit would be at fault here. At least according to the article, it's the X-caps that fail... and X-caps are only used to filter line RF / EMI to/from the TV. So they are connected to line voltage only. With that said, I'm more inclined to think the X-caps themselves are failing. But why? -Now that's another question. Perhaps LG switched to some other manufacturer if they were short during production. Or maybe the manufacturer of the X-caps had a slip-up in production that somehow went past Q.C.
      Would have been nice if these consumer warning sites provided more details. I'm sure an EE or qualified tech (or a team, rather) has already determined the issue. Would be nice if they shared details with the public, though. But I guess that will never happen. Unplug you TV and call tech support. ... (Or if you ask me, just unplug your TV permanently and don't bother with it anymore, as there's nothing worth watching on TV... but that's really only my opinion, of course. )
        • 31557
        maybe the voltage is underrated or they are before the switch.
        • PeteS in CA
          • Aug 2005
          • 3589
          • USA, Unsure of Planet
          • Reading, Education, History, Christianity
          I wonder if the problem is partly not doing well with lower quality power and/or lots of thunder storms, as some parts of Oz might have.
          PeteS in CA
          • redwire
            • Dec 2010
            • 3916
            It's an old issue? bad quality X-caps that they already were giving free power board replacements back in 2020 for the issue.
            I think it got escalated to recall status because the koreans just keep putting this kind of stuff off. Affected LG TVs are giving a pop-up recall message.
            Everything is downstream of the fuse... but... "T12A" MOV, 4 film X-caps 684, 474 275V like on a PSOL-L651B.
            So the cap does smoke bad when it breaks down and shorts, before the fuse pops I guess.
            "Certain 65” and 77” LG Smart TVs manufactured between February 2016 and September 2019.
            "Affected models include those manufactured in
            2016:
            • 65E6
            • 65G6
            • 77G6
            2017:
            • 65B7
            • 65C7
            • 65E7
            • 65G7
            • 65W7
            • 77W7
            2018:
            • 65W8
            • 77C8
            • 77W8
            2019:
            • 65W9
            • 77C9
            • 77W9
              • 31557
              275v caps in a 250v country?
              yea, that just screams "long service life"
              • PeteS in CA
                • Aug 2005
                • 3589
                IIRC, back when agency-approved X caps were commonly rated for 250 VAC, European mains voltages could range up to 264 VAC. That said, even with a nominal 240 or 250 VAC, a 275 VAC cap is going to experience surges above that rating - due to inductive surges when motors kick in, due to large load changes, due to lightning, etc..
                The failure mechanism here is cumulative over time. Surges cause arc-overs that "self heal" (= the metallization is cleared back from the hole) that leave a tiny amount of conductive carbon residue. These small conduction points accumulate until the cap heats into a sort of thermal runaway and sudden unpleasant things happen.
                PeteS in CA
                • redwire
                  • Dec 2010
                  • 3916
                  The "275V" marking is part of the Class X2, meaning it's rated for use across mains, up to 275VAC plus transient overvoltages.
                  X2 is impulse rated to 2.5kV (X1 to 4kV) but there is a MOV first in the LG power supply it looks like to clamp far below that. The parts see mains all the time 24/7.
                  So the caps are likely failing due to crappy quality. Like a Rifa situation. They are physically quite small for their ratings which is always too good to be true when they are half the size of competing parts.
                  The recall is for 9,400 sets I think, just part of a production run.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    21 years ago, that sure didn't help with my Deer DR-250-ATX!
                    A thunderstorm also killed the Crotched Mountain campus internet in July, 2001. The internet was down for easily roughly 1 week to possibly 2 weeks!
                    That was on top of random power outages due to the at least one of the campus generators, along with PSNH (Public Service of New Hampshire) at that time.
                    But most of the power troubles that were campus-generator-related, was mostly 2000 and maybe 2001, IIRC.
                    The campus generator setup that they had, is famous for getting us through the ice storm of January, 1998!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8753
                      • Fixing Failed Fuhjyyus
                      Has anyone seen a fire caused by a Rifa?
                      I suppose the problem is that it causes bad publicity even if it doesn't cause a fire, it sure causes a lot of smoke that may imply fire but it never catches on fire.
                      I've heard of plenty of old Tek scopes smoke up and keep ticking due to bad Rifas... of course people are scared if they will cause additional damage by running their scope after the Rifa goes up in flames...
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        IIRC, saw them in videos. They are common in Apple IIs! (and Apple IIIs most likely)
                        Arc A770 16 GB
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8753
                          Tektronix scopes too. I wonder if the spot welder has them ...
                          • dragon3x
                            by dragon3x
                            power on.
                            Here are some examples :
                            switching supply area).
                            than 6.3 V.)
                            03-21-2025, 02:46 PM
                          • mario_split123
                            PCChips/Hsin Tech M537 V3.1 Old motherboard capacitors
                            by mario_split123
                            Hello everyone !
                            I am new to this forum and also a begginer/hobbyist in electronics. I have a question about an old AT motherboard model PCChips/Hsin Tech M537 V3.1. It hasnt been powered on for 30 or so years.
                            I have read that it is not safe to power it on after such a long time because capacitors can suddenly burst. When I inspect capacitors I cant notice any visible damage,leak,corrosion or bulged capacitors.
                            What are your suggestions ? Replace all capacitors maybe or ?
                            Thank you in advance for your answers !
                            02-17-2026, 07:18 AM
                          • slybunda
                            AA and AAA battery charger capacitors?
                            by slybunda
                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                            it has inside:
                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                            2 x 470uf 16v LZ105c branded as G.Luxon
                            not heard of these brands are they any good?
                            iv attached photos of the charger and the board inside for an idea on the type of...
                            12-24-2023, 04:41 AM
                            After all of...
                            07-13-2024, 08:14 PM
                          • Cama
                            Solar Inverter - SMH-II - 2 missing capacitors
                            by Cama
                            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                            My model is : EASUN SMH-II 7 KW
                            Mother Board : P/N 18947-002401250250
                            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                            Thank you...
                            09-12-2025, 02:50 AM
