Spot welder capacitor blew up
  • shanedev93
    • Jan 2023
    • 8
    • ireland
    Spot welder capacitor blew up should just replacing them fix it? The board is very dirty gonna remove it and clean it an see if I notice anything wrong that could cause this issue.
    Video of the smoke show
    https://youtube.com/shorts/AFJgRbsHGhs?feature=share
    • 31293
    Re: Spot welder capacitor blew up
    no, dont risk it.
    clean the board up and post pictures.
    if a diode went short-circuit and hit the cap with AC that would do it - and do it to the replacement too!
    • redwire
      • Dec 2010
      • 3912
      It kinda looks like a Rifa
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yea that is a Rifa capacitor, just replace all of them with the same values.
        Just look for the safety rating of it and replace with the same or better Y or X class capacitor.
        • shanedev93
          • Jan 2023
          • 8
          • ireland
          yes its a RIFA a quick google they seem to be famous lol
          best way to clean this board? im using iso alcohol and a brush but it seems to be just moving it from one place to another
          • shanedev93
            • Jan 2023
            • 8
            • ireland
            this is the same as mine is it ok to use these? or is there a better equivalent?
            https://uk.rs-online.com/web/p/film-...B&gclsrc=aw.ds
              • 31293
              what is on the side of the old one?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                Yay yet another RIFA thread!
                Was really hoping not...but sounds like my Tektronix scopes need to get it's RIFAs swapped soon...
                Sure hope the Kemet buyout made them better...
                • shanedev93
                  • Jan 2023
                  • 8
                  • ireland
                  same as the above link above
                  • redwire
                    • Dec 2010
                    • 3912
                    There is more info written on the side of the Rifa capacitors, the top just says 0.1uF. They're X caps I guess 300VAC or more.
                    You would need the lead spacing mm and voltage rating to find replacements.
                    For cleaning the board, I use a gentle toothbrush and a little compressed air- not too much which makes static electricity and damages things.
                    The welder has had a hard life, between the rust/water and dust.
                    • shanedev93
                      • Jan 2023
                      • 8
                      • ireland
                      ive ordered the ones in the link above they look to be the same to me
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        The only way to get this board clean would be with soap and water.
                        I would not submerge things like the buzzer or relay though.
                        So best to use maybe a toothbrush and be quite liberal with it, but not submerge it fully...
                        You can then wash that off with the IPA and after drying it should look much better
                        • redwire
                          • Dec 2010
                          • 3912
                          I would not use Rifa/Kemet PME261's as replacements, the one you picked is ordinary PME261 "General Purpose AC/DC, Metallized Paper" and has no ratings for across the line use. Those are another part number PME271M or PME271E.
                          Rifa oddball sizes are the only LS=20.3mm parts, but I would stuff in a standard 22.5mm part which would fit.
                          The reason to worry about it is there is no fuse for these and they would totally destruct the board in fire.
                          • shanedev93
                            • Jan 2023
                            • 8
                            • ireland
                            i used a tin of electrical component cleaner had lots of pressure worked rather well
                            • shanedev93
                              • Jan 2023
                              • 8
                              • ireland
                              i just got the ones in the link as i have no clue of a suitable replacement lol
                              they look the same have the same part number pme 261 jc and they seem to work. have you got a link to what you would you use? might change them in the future
                              • MORETTIGIAN
                                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                by MORETTIGIAN
                                Title:
                                Description:
                                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                I did not notice it detaching, so I am unsure of its original location on the PCB.
                                Procedure performed:
                                - Removed backplate
                                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                - Reapplied thermal compound
                                - Reassembled card
                                Observed behavior after reassembly:
                                - GPU powers on and operates normally under...
                                09-18-2025, 12:14 PM
                                New Super Capacitor 5v DC Battery Spot Welder with a 12 volt power supply
                                by sam_sam_sam
                                This is a new item at Battery Hookup that I bought I have always wanted to buy a good capacitor battery stud welder but they are to expensive for my budget that I want to spend on one this was surprisingly moderate price for what it can
                                It came by FedEx today so I decided to try it out on some tabbing that my battery stud welder has a little issue making constantly welded with out having to redo some because it would not get hot enough to do it properly
                                Well right out the box when the super capacitor charges up with the setting as follows does a very good job the first...
                                05-21-2023, 04:28 PM
                              • spleenharvester
                                Reverse engineering of DoCreate DHJ567 handheld spot welder
                                by spleenharvester
                                Hello everyone
                                I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                05-08-2025, 02:52 PM
                              • littlejohn
                                Sunkko 737g battery spot welder
                                by littlejohn
                                I bought this welder to spot weld some 1.5mm tabs onto batteries , which kinda worked , now I'm given some batteries that have 4.2 mm tabs that are found in Makita , dewalt and snap on battery packs . Can I modify it to do this ? The triac is a Q6040K7 which shows 6.3 vac and 36 amps output and don't know if it is accurate due to the short on time when foot pedal is triggered ....
                                11-09-2025, 01:27 PM
                              • vionescu
                                Zotac 1070 mini blew off a capacitor
                                by vionescu
                                Hi, last night my zotac 1070 mini blew off a capacitor. I've had a look and identified it to be C336 capacitor and maybe the R005 resistor. Does anyone have any idea what kind of replacement capacitor I need to get to fix it or any boardview schematics for the card?...
                                03-19-2022, 01:09 PM
