Capxon Capacitors?
  • Krankshaft
    • Jan 2007
    • 2328
    Capxon Capacitors?
    What do you guys think of Capxon capacitors or as I call them Crapxon capacitors .
    No doubt they're trying to play off the Samxon name.
    I have read in the bad caps sticky that they are on the bad caps list but I have read in other places. Where people think they're ok and use them on power supply recaps.
    I personally stay away from them I'm more of a Nippon Chemicon/Panasonic kinda guy.
    What are your thoughts?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Capxon Capacitors?
    i think they are ok in psu never seen them in anything else. i think they were before samxon though?
    nobody took issue with rubyCON nichiCON chemiCON so what the hell....
    • toastygoodness
      • Jul 2005
      • 813
      haha i've always wondered the what the con meant.
      • yanz
        • Nov 2004
        • 910
        for me, i have found same failed capxon caps on several psus so i dont consider them as good caps.
        the blue capxon can fail with visible damage. the black one can fail without showing any sign of damage.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          >> rubyCON nichiCON chemiCON <<
          >> i've always wondered the what the con meant <<
          CONdenser - The old name for caps. [Still used in some places I think.]
          Mann-Made Global Warming.
          - Dr Seuss
          • Krankshaft
            • Jan 2007
            • 2328
            Oh duh .
            I know the name condenser since I used to repair and read old tube radio service manuals where they referred to them as condensers.
            An even funnier thing I read in an old manual was something to the extent of.
            When you are soldering wires together and you need a third hand.
            They said to hold the wires together with one hand with the soldering iron in the other and to put the solder in your mouth and bring the solder into contact with the wires.
            Solder + Mouth = Bad
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              I've been known to put the iron in my mouth...
              .. but not just after holding it with my toes.
              - Dr Seuss
              • anchorbeach
                • Nov 2009
                • 1
                CrapXon is a good name for these elctrolyitical turds.
                I replaced them on mother boards, power supplies and audio boards. They are garbage.
                My $2000 42 inch Samsung commercial grade monitor is filled with them. I just replaced a half dozen of them and they took out the motherboard for the MajicNet feature along with them. Lucky I have a spare board
                • Chuck F.
                  • Nov 2009
                  • 5
                  On the weekend I picked up an Viewsonic 17" LCD monitor cheap which I've fixed already. Replaced a couple of Capxon's that had a bit of crusty brown residue on top. Monitor was a little short of four years old. Not a bad little unit, the base needs some weights.
                  Chuck
                  • i4004
                    • Oct 2006
                    • 2029
                    yes, there is doubt, because (same as willa said) i think they're acutally older than samxon...
                    there are much better companies, and much worse(with more screwed up series ie overall bigger number of junk caps in the field)...
                    stay away if you can do better.
                    • gblades
                      • Feb 2008
                      • 8
                      I reconditioned the powersupply in my Thompson Sky HD satellite received at the weekend. These boxes are well known to have poor power supplies.
                      All the capacitors were capxon and I replaced all 15 of them. Two were so bad the ESR meter thought they were still in circuit. One other had a poor ESR and one had a poor ESR and a cap readong of almost half what it should have.
                      • seb30
                        • Apr 2010
                        • 2
                        I repaired an Acer AL1916W by replacing C200, a failed 220uF CapXon.
                        They must be on the bad list.
                        SeB.
                        • cjb2611
                          • Jun 2011
                          • 1
                          Just stripped down my Philips WC3500D Micro Hi Fi and replaced 3 failed CapXon's on the Power Supply. All had bulging tops and one had brown residue on the top. These caps are rubbish.
                          • Evil Lurker
                            Warranty Voider
                            • Feb 2011
                            • 454
                            Yup, they are garbage. Just got done replacing the caps on a Westinghouse TV power supply... got caps in there now scavenged off other junked PCB's... god only knows what their rated at series wise but hey it comes on now.
                            Seen enough of them failed to add them to my crap caps ranking list... they are somewhat better than fuckyoos and worse or about the same as OST.
                            • FrodoOne
                              • Jun 2011
                              • 1
                              Forum members may be interested in the following posts on
                              http://www.tomshardware.com/forum/24...-light-flashes
                              relating to problem with capacitors in a ViewSonic VX922 monitors.
                              The solution given there by 'drumerman' on 17 December 2008 is a number of faulty capacitors in the power supply.
                              At least one other on this site ('graw2' on 9 August 2010) has advised that these capacitors are all CapXon and I can verify this, since I have just replaced five swollen CapX capacitors in a faulty ViewSonic VX922 monitor.
                              I am well aware that capacitors with faults of this nature have been around for over five years but this is the first time I have become aware of at least one of the brands involved.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Actually faults of this nature have been around closer to 90 years.
                                Just wasn't in the news.
                                - Dr Seuss
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6301
                                  I believe the same here.
                                  ASRock B550 PG Velocita
                                  Ryzen 9 "Vermeer" 5900X
                                  Arc A770 16 GB
                                  eVGA Supernova G3 750W
                                  Alienware AW3423DWF OLED
                                  • Digital Technophile
                                    revrse engineer
                                    • May 2011
                                    • 144
                                    I had these GL and KM series condensitors in my Samsung Syncmaster 906BW. The two standing up were bulging from both ends. Fortunately the monitor stopped powering on before they completely burst. I did have the sense to replace them with Nichicon caps. I did the recap before joining the forum. I ended up using Nichicon HE's for the bigger ones and PW's for the smaller ones. I haven't had problems since.
                                    If you voted for Obama in 2008 to prove you weren't a racist, you'd better vote for someone else in 2012 to prove you're not an idiot!
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      condensitors is cooler than capacitators.
                                      - Dr Seuss
                                        revrse engineer
                                        • May 2011
                                        • 144
                                        Yeah, but capacitators do make good salads, don't you find?
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                          by sam_sam_sam
                                          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • Ady2017
                                          Are there any datasheets available for Elna RJG capacitors?
                                          by Ady2017
                                          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                          05-25-2025, 02:19 PM
                                        • ctroxtell
                                          Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                                          by ctroxtell
                                          I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                                          01-03-2025, 08:57 PM
